no symptoms told is engine dead, or is DTC for O2 set.?
no clues told to put helpers on target.
are you asking which fuse blew or why it did.?
a fuse has 2 end both ends are 12vdc key on
if one end is now 12v but near 0v the fuse is BLOWN
no better test exits. doing that with a DMM. (a live test)
well the fuse is blown and 02 love to short the 2 heater pins
or wires at it burned and shorting, loves to....
no engine told so exact answers are not possible
the service manuals are by country ,year, make,model, engine and transmission, if driveline problems and is.
gen 1 is DODGE:
3.9 L (238 cu in) Magnum V6
4.7 L (287 cu in) Power Tech V8
5.2 L (318 cu in) Magnum V8
5.9 L (360 cu in) Magnum V8V6
USA drawings, show.
OXY fuse is
Fuse A1 , 10 amps. a1 is hot if ASD is not dead keyon.
same fuse A2 if A1 is hot, and A2 is dead, the fuse A1/2 is blown
all 4 OXY sensors run off that one FUSE
now lets talk why pin A1 WOULD BE DEAD
WELL THE ASD IS DEAD. IS WAY .
ASD GOES DEAD FOR ONE PRIME REASON, SPARK IS DEAD.
THIS MAGIC LOGIC IN THE PCM PREVENTS CRASH AND BURN.
3 CAUSES ARE.
1: PCM SEES ANY COIL SPARK FAIL (DETECTED)
2: PCM SEES CMP DEAD.
3:PCM SEES CKP DEAD.
OR PCM FUSES BLOW, TO IT. SURE
. PCM RUNS ASD ALL BY ITSELF AND ITS RULES.
Why not start problem by telling it first.
engine dead, cranks ok.?
or runs for 1 to2 second and ASD drops and sure stalls.
The amin board is faulty. Contact any service technician. These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/
Blinking codes details to many popular brand TVs are given. Surf the site with patience. If blinks continue without any pause, the main board is faulty.
Go to http://www.kohlerengines.com/manuals/landing.htm and enter your engine model number as instructed on that page. Kohler generally has service manuals avaialable on their site.. As an example, there are 2 service manuals for 16HP vertical-shaft engines available there (Courage and Magnum series) and 3 service manuals for 16HP horizontal-shaft engines (K, Magnum and Triad series).
Howdy, We use a 2005 Magnum for our parts delivery car, and have had
many problems related to starting, misfire, and magically dead
batteries. Unfortunately this car is plagued with electrical problems,
most are intermittent but all can be fixed. I suggest getting yourself
a factory service manual and following the electrical system test procedures
included. In our Magnum we found a faulty rear defrost relay that was draining the battery. Grab yourself a repair manual, we got ours from promanuals.net
does your acer still underwarranty..? if yes, then return it to the store where you bought and let them fix it.. i think there's something wrong with your LCD screen...
u can concert with me on my mail id [email protected] with ur model number of laptop than i can trobleshoot the problem thjanx enjoy good luck plz vote on my comments
