Question about Kolcraft Lil' Limo 46880 Twin Seat Stroller
Why does the front seat not recline all the way back
2 Suggested Answers
tshot2020
  • 23 Answers
SOURCE: seat stuck in recline
http://www.kolcraft.com/Media/S70-R1_ZT001.pdf
Posted on Apr 21, 2009
HONDA ACCORD Seats Front Assembly Recliner went down and won't go up
I wouldn't ruin anything by trying things yourself
I would have a dealer check it out
The dealer I used in the past, has a seat specialist come
in on Wed only, around 5:30 after the service bays close
& one service writer hangs out until that person fixes a
couple vehicles seat issues
Jun 12, 2012 | 1995 Honda Accord
The passenger front seat will not recline - how can I fix
2010 Equinox drivers side won't recline.
Found the cable popped off recline mechanism.
Pulled back the lower seat panel near the recline lever after removing one torque screw located on said panel which is on the back of seat. Works great now. By the way, Freedom Chevrolet in San Antonio, Tx, without diagnosis, wanted to charge my girl friend $860 to replace the whole assembly.
Feb 10, 2010 | 2005 Chevrolet Equinox
How do i remove the front seats of a 1998 Pontiac Grand Prix?
On W-Body vehicles, the front seats are secured to the floorpan by two front hook attachments and two rear bolts installed to nuts welded to the floorpan.
The manually operated two-way front adjusters provides only fore and aft movement of the seat. When the seat adjuster handle located on the front seat is pulled up, the seat adjusters unlock, permitting travel of the seat. When the seat is in the desired position and the seat adjuster handle is released, the seat locks in place.
A power operated six-way seat adjuster is available. The adjusters are activated by three 12 volt, reversible, permanent magnet motors with a built-in circuit breaker. The motors are energized by a switch bolted on the seat side panel.
The three motors drive the front seat and rear vertical actuators and a horizontal actuator. When the adjusters reach the limit of travel, torque is absorbed through the rubber mounted grommets located between the motor and the support. An overload relay is provided in the circuit and will open should excessive stall be applied.
The optional 60/40 split bench front seats have seat back head restraints on the driver's and passenger's seat back. The head restraints are designed so they cannot be removed from the seat back without first inserting a small rounded tool inside the head restraint support tube to release the locking tab. The 60/40 split bench seat is equipped with a reclining mechanism on both the driver's and passenger's side. The recliner lever is located on the outboard side of the spring cushion. When the lever is pulled upward, the spring loaded dual linear reclining unit located in the cushion frame is released, allowing the seat back to be pushed rearward or allowing the spring loaded reclining unit to bring the seat back forward.
Bucket seats are equipped with manual reclining mechanisms. An optional six-way power seat adjuster is available. Some bucket seats are equipped with inertia seat back locks. This system allows the seat back to fold forward without requiring the occupant to release a locking lever or access to the rear seat area. During a sudden stop or deceleration, or if the front of the vehicle is nose down, the inertia system of the seat back lock will engage, holding the seat back in its rest position. A release lever is provided to allow manual release of the seat back lock when the vehicle is in the nose down position. The release lever is located at the lower rear outboard corner of the seat back.
Some W-Body vehicles (notably Pontiac coupes) have passenger front seats equipped with an E-Z Entry device. This is actuated, in an unoccupied seat, by completely folding the seat back forward disengaging the adjuster, and sliding the front seat forward to gain access to the rear seat area. To return the seat to its normal position, return the seat back to its rest position, and slide the entire seat rearward, engaging the adjuster.
W-Body rear seats are available in several styles including a rear seat with an integral child restraint device.
Sep 01, 2009 | 1998 Pontiac Grand Prix
1994 Cadillac Deville front seat recliner broken
Not a very common problem. You can get either the part from the dealer, or the seat from the junk yard. It will have the piece you need to correct the issue.
May 27, 2009 | 1994 Cadillac DeVille
Camaro - broken reclining seat mechanism
the recliner is the outside seat hinge and has 4 bolts holding it to the seat cushion and seat back.The seat covers need to be pulled back to gain access to bolts.Can be done with seat in the vehicle.
May 27, 2009 | 1991 Chevrolet Camaro
Reclining seat
On the front of the seat, below the harness adjuster, is a handle (on mine, it's red). Pull that handle out while pushing back on the top of the seat.
Feb 15, 2009 | Cosco Alpha Omega Elite 5-Point 22-155
2001 Nissan Altima - Seat Back stuck in the recline position.
where is the overload protection circuit for power seat of nissan altima 2001 , the seat does not move back and front let me know if i could do the seat move
Jan 18, 2009 | 2001 Nissan Altima
Cosatto duo traveller in slate
on this style of prame the front seat does not recline only the back one does.
Sep 11, 2008 | Cosatto Baby Gear
Front seat stays in the reclined postion..
The seat position is changed through the use of a cable that runs through a flexible tunnel, under the seat. In one case that I'm aware of, this cable got stuck around a projecting seat spring under the seat. When the seat was reclined and moved backward or forward, the cable caught on the seat spring and the seat had insufficient slack in the cable to release from the reclined position.
Jul 22, 2008 | 2000 Ford Focus
Kolcraft Lil' Limo 46880 Twin Seat Stroller Logo
27 people viewed this question
Top Kolcraft Baby Gear Experts
Timothy Shotwell
Timothy Shotwell
Level 1 Expert
Bill Boyd
Are you a Kolcraft Baby Gear Expert? Answer questions, earn points and help others
