Question about HP DeskJet 1000cxi InkJet Printer
Why wont my hp deskjet 3511 print
Deskjet 1000 output tray open but error says it is closed
  • 263 Answers
SOURCE: deskjet f2100 series
what kind of software did you use or did you just install the printer with the computer drivers i need more info about this problem
Posted on Jan 05, 2008
  • 3 Answers
SOURCE: HP Deskjet 5150 - top cover open
I had the same problem, and the cause turned out to be the cover switch not being fully pushed in. On the underside right edge of the top cover, there's a little triangular protrusion that pushes down a black rectangular button (the cover switch) when the cover is closed. The problem occurs because the flimsy top cover is made of plastic and flexes slightly when you close it. This means that sometimes, the right edge of the cover won't seat properly even though it appears as if the cover is closed all the way. When this happens, the triangular protrusion isn't fully pressing the switch down.
To test if this is this is happening, send a print job to the printer and wait for the "top cover is open" error message to appear. Next, open the top cover door and locate the cover switch. It's a little black button in a rectangular hole at the right edge of the doorway near the ink cartridges. Take a pen or a car key and use it to push the cover switch down. You can also use your fingertip to do this if it's skinny enough. If you keep the cover switch pressed down, the power button should start blinking to indicate a print job is coming through. If the print job actually starts printing, then you know the problem was the cover switch.
In my case, all I had to do the fix the problem was close the cover and make sure it was fully seated by firmly pressing down the right edge of the cover until I heard a plasticky "click" noise. After that, the problem went away.
Hope this helps.
Posted on Sep 16, 2008
guide2u
  • 461 Answers
SOURCE: HP deskjet F4140 Error light on & I can"t print
please reset your printer. turn off your printer, leave it for 30 sec and turn it on again....
If you still have problem try to re install the catridges again, follow below instruction
http://etech.maiila.com/hp-deskjet-f4140-all-in-one-printer-catridges-installation
Good Luck
Posted on Nov 01, 2008
SOURCE: HP Deskjet 3940
I have a problem with this printer as door open masseg kindly help me to expedite this issue.
Hassan Tariq
e-mail: stariq_68@hotmail.com
Posted on Nov 15, 2008
SOURCE: system error in printer hp deskjet 3320
Normal 0 In XP go to Control Panel
Open System
Click the Advanced tab
Click Settings under Performance
Click the Data Execution Prevention tab
Make sure Turn on DEP for all programs is NOT checked, check Turn on DEP for essential Windows programs.
Posted on Feb 10, 2009
Tip
EZ steps to install HP printer in Windows 7 without Installation software
  1. Make sure that the USB cable is not connected to the product. If the USB cable is connected to the product, disconnect it.
  2. From the Windows taskbar, click the Windows icon, and then click Devices and Printers. The Devices and Printers window opens.
  3. Click Add a printer. The Add Printer window opens.
  4. Click Add a local printer.
  5. Click Use an existing port.
  6. Click the Use an existing port drop-down list, select LPT1: (Printer Port), and then click Next.
  7. Under Manufacturer in the Install the printer driver window, click HP.
  8. Under Printers, select approriate drive from below list provided and then click Next.
  9. In the message window, click Finished.
  10. Connect the USB cable to the product, and connect the USB cable to the computer. A Device driver software was not successfully installed window opens.
  11. Click Close to close the window.
  12. In the Devices and Printers window, right-click the name of the product and then click Printer Properties. The Printer Properties window opens.
  13. Click the Ports tab.
  14. Click the drop down menu, and then change the port from LPT1 to USB or DOT4.
  15. Click OK.
  16. In the Properties dialog box, click the General tab.
  17. Click Print Test Page.
Determine the appropriate compatible driver
Deskjet 3320, 3325, 3420 and 3520 -------------Deskjet 3600 *
Photosmart 7600 series------------------------------ Deskjet 5600
Deskjet 5850 ---------------------------------------------Deskjet 5600
Photosmart 130, 145, 230 and 245 ---------------Photosmart 330 *
Photosmart 7350 and 7550 --------------------------Deskjet 5550
Deskjet 6122 and 6127 --------------------------------Deskjet 990c *
Deskjet 3820 -----------------------------------------------Deskjet 970cse *
Deskjet 656 ------------------------------------------------Deskjet 660c *
Business Inkjet 1100d ---------------------------------Business Inkjet 1000
Business Inkjet 1100dtn ------------------------------Business Inkjet 1000
Deskjet 9300 ----------------------------------------------Deskjet 1220c *
Deskjet 9650, 9670, 9680, 9680gp---------------- Deskjet 9800
* Available only through Windows Update.
(Happy Printing)
Regards
Rizwan
on Jan 29, 2010 | Office Equipment & Supplies
My hp deskjet 2050 output tray open error
fata error during installation in hp deskjet 2050 printer
hp printer not uninstalled .
how to uninstall driver hp deskjet 2050
Jun 07, 2013 | HP Deskjet 2050 All-in-One Printer
I am getting an error message say that my output tray is closed but it is actually open, what to do?
According to your problem reopen the output try or replace it. Check the settings of the printer. Then reboot the printer and the system both. It will solve your problem.
Jun 27, 2011 | HP DeskJet 1000cxi InkJet Printer
I had the same error message when nothing appeared to be wrong. The sensor in my printer was set far back from the plastic edge. It must be a light sensor because when I shined my desk lamp in the direction of the tray it started working. I haven't seen a similar post like this so I want to throw it out there.
HP deskjet 3845 will not feed paper to print. Is the green light suppose to blink? Not sure where paper needs to go to get proper feed
Paper goes in the bottom tray. Take a small stack and place it in the bottom tray and push it in until it stops. It will feed out of this tray, print it and output it to the top tray.
Jul 12, 2010 | HP Deskjet 3845 InkJet Printer
HP Deskjet F2180 gives error "cover open"
Make sure your printer cover and the paper tray is properly closed. If they are, see if the sensor for the cover has any deffects
Jan 11, 2010 | HP Deskjet 2360 InkJet Printer
Cant i run a stand alone self test on my deskjet
o check printing capabilities, print a Self Test Report. In order to print such a test follow the next steps:
  1. Turn the printer on and place media in the tray.Set the width adjusters to fit tightly against the sides of the paper in the tray.
    1. Press Power button while opening and closing the printer access door four times.
    2. Release the Power button.Your printer will print a test report.
Oct 28, 2009 | HP DeskJet 3740 InkJet Printer
HP DeskJet 1000cxi InkJet Printer Logo
48 people viewed this question
Seeker5211
Seeker5211
