Question about Craftsman YT 4000 42" Briggs Stratton 24 hp Gas Powered Riding Lawn Tract
Drain gas tank on craftsman yt4000 tractor ??
Hightower971
  • 183 Answers
SOURCE: gas tanks rupture on craftsman lawn tractors
2 of them, one is take it to craftsmen and see if they will fix it as a manufacturing defect, or you can replace the tank yourself. There is a putty that you can use, just go to the auto parts store and tell them what you need. Some of them can't be used on gas components so be careful or you will be right back in this mess, only with a bigger mess on your hands.
Calvin.
Posted on Apr 24, 2009
wadembly
  • 448 Answers
SOURCE: Craftsman lawn tractor model new battery drains quickly...
it could be the stator in the engine check the voltage with the volt meter when its running if its low check connections on battery & voltage if its below 12.5 volts then its the stator but the only thing is the engine should run with-out the battery so there is something else going on there is a fuse in the electrical system if theres a short that fuse will blow & engine will stall
Posted on Jun 08, 2009
huffman49
  • 235 Answers
SOURCE: how do I drain gas from tank craftsman ys 4500?
try pulling the hose off from the carb and hang it into a pan so that gravity will help it drain into the pan...good luck
Posted on Apr 12, 2010
  • 11 Answers
SOURCE: I have a Craftsman 42 in. 15.5 hp lawn tractor
check an see if the cabuerator is getting fuel and check make sure sparkplug is getting continous fire from the coil
Posted on Sep 13, 2010
  • 6468 Answers
SOURCE: what oil do you use in the YT4000 lawn tractor with 24 hp v-twin
10w-30
Posted on Apr 08, 2012
Owner's manual for craftsman YT4000 model 917.288561
Bob, Check the attached links, Craftsman Riding Mowers instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
http://lawnandgarden.manualsonline.com/manuals/mfg/craftsman/yt_4000.html
Craftsman 28925 YT 4000 24 HP 42 Yard Tractor Manual
Apr 05, 2016 | Craftsman Garden
Craftsman tractor lt2000 with 17hp Kohler won't start. Ran fine last week. Rebuilt carb, changed oil, and new plug & fuel filter month ago. Has spark and fuel. Cranks but won't fire.
Hi Mike:
It's trying to make you crazy.
I have a model YT4000 and it is a PITA to start when cold.
I pull the air filter, toss in a bit of gas to prime it, and it starts instantly.
I'd suggest that you give yours another try. 3 or 4 times of a couple of seconds each. If it doesn't go, pull a spark plug and see if it is wet or dry. Wet indicates getting gas but no spark. Dry indicates not getting gas.
While you have the plug out, check the spark... Hot & blue.
Hope this gives you some more to work with.
Jun 22, 2015 | Craftsman Garden
Why won't my Craftsman YT4000 tractor start after removing the deck?
Deck Height switch isn't engaged or pushed in when you remove the deck and it will not start. No current can flow until this switch is pushed in.
Jul 26, 2014 | Craftsman Garden
Craftsman Snowblower Won't Start
If you did not put gas stabilizer in your fuel tank when you stored your machine the gas will turn into varnish. Try draining the gas and put new gas and try to start it. Good luck
Jan 04, 2014 | Craftsman Garden Tractor Snowblower...
How do I get my Craftsman YT4000 to catch grass into the bag again?
do you have bagging blades in place? reg blades will not lift enogh
May 23, 2012 | Garden
How do I drain gas from tank craftsman ys 4500?
disconnect fuel line from fuel filter, snake fuel line over to left side of engine. Remove gas cap and fuel will empty out of fuel tank.
May 15, 2010 | Craftsman 21 Hp 42" Deck, Ys 4500 Lawn...
Mar 27, 2010 | Craftsman 21 Hp 42" Deck, Ys 4500 Lawn...
Craftsman YT 4000 42" Briggs Stratton 24 hp Gas Powered Riding Lawn Tract Logo
122 people viewed this question
Top Craftsman Garden Experts
Dean Gruber
Roland W VanLue
Roland W VanLue
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
