Question about Drills
HOW TO OPEN A performance power tool PHD850-2
TAKEN ALL SCREWS OUT BUT DRILL CASING WONT SPLIT ,WHY.
  • 130 Answers
SOURCE: jbl sonnet computer speakers
Check under the stickers, sometimes screws are hidden under rubber feet, and stickers. If there is a sticker you can rub it with your finger and feel if a hole is under it. Just look at how the rest of the screws are. If you have taken out 5 in the corners and a sticker or a rubber pad is in the last corner chances are its under that one. Also sometimes they use a rubber seal to create an air tight seal in the box. Sometimes this seal can be a little tacky and you need to pull on it a bit before it pops loose. If your sure there can be no more screws then it maybe stuck
Posted on Apr 05, 2006
bammbammfran
  • 159 Answers
SOURCE: DELL LCD monitor E151FPb turn white
If the screen is all white light then you can have a number of problems.
One could be a bad video board, the next could be a simple loose wire from the video board to the back of the lcd screen OR a simple blown fuse on the back of the actual lcd screen can cause the same thing.
Snaps are all sround these things and can be really stubborn at times. Best to start the bottom first then work up each side to the top.
Something flat, thin and with a decent sharp edge on it will help. A pocket knife held parallel to the joint between the front and rear plastic works, you can also sharpen the edge of an old credit card with a file (nail file works) This isn't as strong as a blade , but safer if you slip !!
Fran
Posted on Oct 11, 2008
SOURCE: how do i open up the casing
There are two ribbons holding the sections together. One is for the keyboard and one for the touchpad. They are hard work top get connected afterwards so expect some servere cursing .I found that asking my friend to do it with some forceps did the job admirably.
Posted on Feb 26, 2009
I also tried re-soldering joint L781 on the main power control board (see Solutions #2 and #7). It worked. My 15 inch Dell flat panel LCD is working again, white screen gone. The solder around the pin did looked different to to the other joints...a very slight gap around the pin as though it wasn't contacting properly. To locate L781, look at the bottom of the PCB (the side with the soldering) with the power plug socket at the edge closest to you. L781 is in the top left quadrant of the board, about 2 inches in from left, 1 inch down from the top. For good measure, I also tried the solution that suggested trimming a millimeter of the end of the two data ribbons that plug into the smaller control board, although I couldn't see anything wrong with the data ribbons. I did this at the same time as resoldering L781 so not sure if it made any difference.
Posted on May 02, 2009
  • 154 Answers
SOURCE: Poulan Wild Thing 2375 18" Gas Chain Saw throttle trigger broken.
top screw als on the sides, then pul;l apart
Posted on Aug 03, 2009
Dewalt Corded Drill won't turn on
TRY THIS TAKE THE DRILL REMOVE ALL SCREWS OPEN IT
FIND THE POSITIVE AND NEGETIVE ON THE MOTOR HAVE A 12 VOLT BATTERY AND 2 CABLES 1 RED 1 BLACK 6 F-LONG 1-CONECT THE POSITIVE CABLE TO POSITIVE ON BATTERY AND NEGETIVE TO NEGETIVE ON BATTERY NOW YOU CHECK THE MOTOR ON DRILL BY TAKING POSITIVE AND CONNECT TO POSITIVE ON DRILL AND NEGETIVE TO NEGETIVE ON DRILL IF THE MOTOR RUNS THE PROBLEM SHOULD BE SWITCH.YOU CAN BYPASS THE SWITCH SOLDER THE WIRES TO THE MOTOR AND USE IT IN THE MEANTIME. SCREW THE CASING BACK TOGRTHER
YOUR DONE VERY SIMPLE..
GOOD LUCK.
Feb 04, 2018 | Dewalt Air Tools & Compressors
Howto fix sliddig door wont open in or outside
If you have split the wood then the screws will not go in no matter what you do because it will continue to split. You could always try placing another board behind it to strengthen it and drill into it.
opcom 2010
Jan 04, 2013 | 2006 Toyota Sienna
Can't open Black and Decker 7252 drill
I would make this party buy you a new drill. My Dads words, SON DO NOT LOAN YOUR TOOLS.
Jul 11, 2017 | Drills
I have a new 7000 battery for my 6075D Makita drill. The drill won't turn at all. battery is charged. I wanted to take the drill casing apart. All the screws are out. the casing will not come apart near...
Makita engineers are sneaky bastards that's why. There's a special tool required to take the front off and another compression tool to compress all the parts back together. You got to find your local Makita service center and have them do it. They make these Makitas like Hondas, because they want to keep all the money and don't want you monkeying around and fixing the parts yourself for cheap.
I know, I know life's a b.tch sometimes.
Nov 11, 2010 | Makita Drills
How can I take a part my dewalt 12 volt drill
Hi there, Remove the battery and sometimes the screws on the drill casing are a torx instead of phillips so you will need a set of torx screwdrivers. Once you have removed the screws from the casing be very carefull when pulling the two casings apart, try to leave the chuck, motor and switch assembly in one half of the casing as it makes it much easier when trying to put it back together.
Jan 01, 2010 | Dewalt DC727KA 3/8" 12v Cordless...
Hi from dublin,my third dewalt dw054 impact 14.4v cordless drill,they all lose power,as if the switch does not work,but i think the motor is gone.. They all went the same way after two years..great drill...
Hi there, the first thing you need to do is check the carbon brushes, there will be two of these one at each side of the motor, if these are ok then test if power is getting to the motor, to do this you will need to split the casing on the tool in half. You may need a torx driver to undo the screws on the casing. Once you have removed the screws, very carefully split the casing making sure you leave the gearbox assy, motor and switch in the other half. Insert battery onto the unit and get someone to hold the motor in place just incase the machine starts. get a voltmeter, follow the wires from the switch to the motor and where the wires attach to the motor put the probes of the voltmeter and pull the switch to engage it. You should be gettting a good voltage now, If you are then the switch is ok. hope this is of some help
Dec 18, 2009 | Dewalt DW056 18 Volt Cordless Impact...
Working when posted but dead on arrival.bought on ebay . fuse and lead checked out ok.
where do you live and where did you get the drill from are the voltage ratings the same
May 01, 2009 | Bosch Drills
I have an Performance cordless Power drill model
Check these two places....
Performance Power and Macallister spare part enquiries to Solent Tools 023 80578057
www.solenttools.co.uk. If they can't supply they will give honest advice on who can.
This address is correct:
1 Hampshire
Corporate Park
Chandlers End
Eastleigh
Hants
SO53 3YX
But it is not Performance Power Tools HQ it is B&Q customer support office and their telephone number is 023-8025-6256 but for technical support or spare parts it's 0845 300 2577
Apr 22, 2009 | Black & Decker Pivot Plus Cordless...
Drills Logo
47 people viewed this question
Top Drills Experts
Are you a Drill Expert? Answer questions, earn points and help others
