Question about Vacuums
Undefined i have a 4l60e transmision it wont up or down shift on its own and starts out in drive
  • Vacuums Master
  • 17,162 Answers
The modulator or governer is bad.
Posted on Jul 14, 2013
I have lost my manual and I have never used it how do I get a manual?
Maybe you can get that los manual of your undefined deviceof some unspecified make and unknown model, if you provide some relevant information.
Actually, you too can do a ggogle search yoursel for that manual
Jun 19, 2015 | Vacuums
Won't start, i push the red start button but it wont start
Start by checking the power cord and switch. If not solved you will need to follow power down to motor looking for circuit break. If none check motor,
Feb 17, 2014 | Dyson DC25 Vacuum
Hoover U6434-900 started smoking while vacuuming. Now it will not start. Waiting 30 mins for the reset but still wont start.
Check the drive belt and then check to make sure the cleaning bar is free of hair. This will cause a burning smell. I know, I raised 4 girls.....
Nov 04, 2013 | Beam Industries 2900 Serenity Plus Central...
Undefined
I think it might be a problem of adapter. Some times due to heat adopter stops working. Now it is a time to buy new adapter.
Jul 23, 2013 | Vacuums
Undefined
The belt need a change.
Jul 15, 2013 | Vacuums
Undefined
What make and model?
Jul 14, 2013 | Vacuums
The foot pedal to go from drive to nuetral on my G series fell off and i cant seem to get it back in
The pedal assembly must be replaced,( part # 558401S), as it has a gear pressed to it which has come loose. The handle, switch plate, and upper motor cover must be removed first. To remove the plastic switch plate, remove it's screws and insert a flat screwdriver into the rectangular slot in it to pop it off. Four screws hold the upper motor shell in place. Next the switch button must be removed. The Techdrive assembly can be removed by removing the three screws on the bottom. Drop the drive down, and unhook it's belt from the gear on the end of the armature shaft. The pedal assembly can be removed by removing the remaining screw from the bottom of the drive unit. The N/D pedal has two parts - the pedal itself, and the shift cam. Observe carefully how these units fit together. After installing the new pedal and replacing the screw and washer to secure it, re-install the drive unit. The shift must be in the Drive position to install it, and remember to replace the belt. Be sure to line up the arm on the drive unit so that it engages the slot at the base of the handle pivot and re-install the other items.
Mar 06, 2011 | Kirby Ultimate G Bagged Upright Vacuum
How do you replace the drive/neutral lever (foot pedal) if it falls off? (The yellow and gray lever that you step on to put it into drive or neutral.) Not sure what happened but it just fell off. Now I...
The pedal assembly must be replaced,( part # 558401S), as it has a gear pressed to it which has come loose. The handle, switch plate, and upper motor cover must be removed first. To remove the plastic switch plate, remove it's screws and insert a flat screwdriver into the rectangular slot in it to pop it of. Four screws hold the motor cover in place. Next the switch button must be removed. The Techdrive assembly can be removed by removing the three screws on the bottom. Drop the drive down, and unhook it's belt from the gear on the end of the armature shaft. The pedal assembly can be removed by removing the remaining screw from the bottom of the drive unit. The N/D pedal has two parts - the pedal itself, and the shift cam. Observe carefully how these units fit together. After installing the new pedal and replacing the screw and washer to secure it, re-install the drive unit. The shift must be in the Drive position to install it, and replace the belt. Be sure to line up the arm on the drive unit so that it engages the slot at the base of the handle pivot and re-install the other items
Feb 28, 2011 | Kirby G5 Bagged Upright Vacuum
The tech drive has come off, how do i put it back in place.
Feb 26, 2011 | Kirby G5 Bagged Upright Vacuum
Vacuums Logo
19 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
