Question about Brother SE-270D Computerized Sewing Machine
Speed controller How do you turn off the speed controller
  • Brother Master
  • 7,365 Answers
I have an old elna lotus sp sewing machine and need to reduce the speed on the foot control is this possible
The Lotus should have the integrated foot controller and power cord in one. Some of these had a switch on the foot controller which reduced the power to half speed. That's the only way to adjust the speed other than the foot on the pedal. The later models Air Electronic have a slide speed control on the front face of the machine which made life easier.
May 06, 2017 | Elna Sewing Machines
I would like a wiring schematic for the speed control transformer and light on a old Necchi Mira sewing machine, please.
the light wires are not to be connected to the speed control but have a separate circuit to the on / off switch
if you have the light connected to the speed control then as the resistance to the motor is decreased it affects the power available to the light
May 31, 2016 | Necchi Sewing Machines
I was given a brother cs-8150. The manual says it will operate without foot feed. I tried to use auto sew and machine tells me to change speed controller mode to off. Where do I do that.
Not able to find any online instructions for your machine, so here goes. There may be some confusion as to what foot feed means.
I believe foot feed refers to the feed dogs. When you disable the feed dogs (drop them), then you must manipulate the fabric manually--used mostly for darning or free motion quilting. In essence the feed dogs are no longer moving the fabric for you. Instead, you manually move the fabric and control the speed at which it stitches with your foot control. Perhaps that is why you need to turn off the speed control because you will determine the speed with your foot.
Foot control refers to the foot pedal that you use to control the speed that the machine sews (much like the gas pedal in your car). Some machines have the ability to sew without the use of a foot control unit. To do so, there is usually a button or lever somewhere to start and stop the machine. When activated, the machine will continue to stitch until you stop it.
Hopefully this will help you find a resolution.
Mar 28, 2016 | Brother Sewing Machines
How do I slow the speed of the machine down in order to quilt
use a smaller stitch. DO NOT PUT YOUR FOOT ON THE PEDAL SO HARD
Jun 28, 2015 | Sewing Machines
What is the difference between a variable and non-variable speed sewing machine foot control?
variable foot control==the farther you push it...the faster the machine goes....
non variable....only has stop...and run....
Jun 05, 2015 | Sewing Machines
My sewing machine has power, but is not turning the gears. What is the problem, and should I bring it into sears for repair
If you can turn the hand crank and the needle moves up and down, then the gears are probably alright.
It could just be the floor pedal is oxidized and not making good contact so isn't allowing electricity to get to the motor. If you know anything about electricity, you can bypass the floor control pedal and just briefly put the full power to the motor and see if it runs full speed, then you know it is just the speed control floor pedal.
Feb 23, 2015 | Kenmore Sewing Machines
Bernina 1000 can i add speed control?
Yes you can replace the foot control if it is no longer regulating the motor speed of your machine.
Jul 15, 2012 | Bernina 1008
How do I make it go slower? How do I turn the fabric without it going off track?
Unless you can control the speed yourself by the foot control the only other way is to buy an electronic foot control, that will give incredible control
Oct 18, 2009 | Janome MyLock 644D
When I step on one side of my foot pedal the machine works, but pressure on the other side does not turn the machine on.
That foot pedal had a feature of High speed on one side of the pedal and low speed on the other. Either your speed control unit inside the pedal is slightly burnt or the spring inside the pedal has moved out of position slightly. Even dirt could be the culprit if it found it's way into the speed control unit inside the pedal.
Oct 07, 2009 | Husqvarna Viking 1
I need to know how to thread a bobbin?
TRY THIS, itma not be your model, but should help Title:
ac093.jpg Pre-tension disk ac094.jpg Bobbin winder shaft ac095.jpg Bobbin
1. Pull up the spool pin as far as possible, and then put a spool of thread on this pin. windingbobbin_a0991.jpg
2. Pass the thread around the pre-tension disk. Make sure that the thread passes under the pre- tension disk.
windingbobbin_a0992.jpg ac098.jpg Pre-tension disk c_b4.jpg Pulling it in as far as possible
Caution If the spool of thread is not in the right place, the thread may tangle on the spool pin.
3. Pass the end of the thread through the hole on the bobbin from the inside of the bobbin. windingbobbin_a0993.jpg
4. Put the bobbin onto the bobbin winder shaft and slide the bobbin winder shaft to the right. windingbobbin_a0994.jpg
5. Turn the bobbin clockwise, by hand, until the spring on the shaft slides into the groove of the bobbin. windingbobbin_a0995.jpg ac099.jpg Spring on the shaft ac0991.jpg Groove of the bobbin
7. While holding the end of the thread, gently press the foot controller or press start/ stop button (for models equipped with the start/stop button) to wind the thread around the bobbin a few times. Then stop the machine. windingbobbin_a0997.jpg
Note
  • If the sewing machine is to be operated using the foot controller, connect the foot controller before turning on the machine.
  • When the foot controller is plugged in, the start/stop button cannot be used to start sewing (only for models equipped with the start/stop button).
Caution Make sure you follow the instructions carefully.
If you do not cut the thread completely, and the bobbin is wound, when the thread runs low it may tangle around the bobbin and cause the needle to break.
9. Slide the sewing speed controller to the right (to set the speed to fast).
(For models equipped with the sewing speed controller.) windingbobbin_a0999.jpg ac0992.jpg Sewing speed controller
10. Press the foot controller or press start/stop button (for models equipped with the start/stop button) to start. windingbobbin_a18.jpg
11. When the bobbin seems full and begins spinning slowly, take your foot off the foot controller or press start/stop button (for models equipped with the start/stop button). windingbobbin_a19.jpg
12. Cut the thread, slide the bobbin winder shaft to the left and remove the bobbin. windingbobbin_a191.jpg
13. Slide the sewing speed controller back to its original position (for models equipped with the sewing speed controller). windingbobbin_a192.jpg
Caution Not winding the bobbin properly may cause the thread tension to loosen, and may break the needle.
woundbobbin3.jpg ac0993.jpg Wound evenly ac0994.jpg Wound poorly
Note
  • When the sewing machine is started or the handwheel is turned after winding the thread around the bobbin, the machine will make a clicking sound; this is not a malfunction.
  • The needle bar does not move when you slide the bobbin winding shaft to the right.
Sep 02, 2009 | Brother LS-2125 Mechanical Sewing Machine
Brother SE-270D Computerized Sewing Machine Logo
88 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
