Question about Mach Speed Technologies TRIO TRIO-STEALTH PRO METAL-7C 4.0 STEA
Screen replacement need instruction how to open a Trio Stealth Pro to replace a cracked LCD
    Master:
  • 193 Answers
I have a great link on youtube and i also have pics and video to,. its very easy to crack the case. there are 2 tiny screws next to the on button and the micro card opening
once u remove those use a thin blade or i used a file to carefully pop the back off by going around very carefully. some have a speaker and wire attached to the back. so dont just pull it apart,
Posted on Oct 14, 2013
Trio stealth tablet will not go past logo
This may be unrelated, but if you let the tablet go to sleep it will drain the battery. I found this out with my Stealth Pro about three months ago, I imagine it is more of an Android issue. It would not startup or go past the opening logo until I had charged it enough. This may also be the case if the battery is damaged or will not take a charge, in theory.
Aug 21, 2014 | Mach Speed Trio Stealth Pro Trio Stealth...
Trio Stealth G2 HYpe tablet will not connect to wifi. Had been working but now can't get the wifi to turn on.
I had intermittent trouble with connecting my Trio Stealth Pro 7" tablet to my secure wireless. I have since upgraded my DSL modem / Bridge and have not had an issue since. You should contact your service provider if you have had the same equipment for a number of years.
May 28, 2014 | Mach Speed Trio Stealth Pro Trio Stealth...
Battery
Take the back cover off. Remove the battery.
Mar 25, 2014 | Mach Speed Trio Stealth Pro Trio Stealth...
Screen not working
Need a hardware replacement you need to change the screen or check if the connectivity from logic board to your screen is ok.
Mar 22, 2014 | Mach Speed Trio Stealth Pro 7 7" 4 GB...
Trio stealth pro wont connect to pc
trio tablet ge wram when chargeing and want power up
Feb 26, 2014 | Mach Speed Trio Stealth Pro Trio Stealth...
Removing duplicate widget from Android tablet homescreen
Keep your finger on the widget until it changes colour then drag it to the waste bin on the screen and let go. Depending on tablet,software etc waste bin could be centre top of screen, taskbar bottom of screen or at the side but it will be there.:-)
HTH
Jan 09, 2014 | Mach Speed Trio Stealth Pro 9.7cm 4.0 Trio...
What number do u do if ur trio stealth pro is not working
More then likely you powered the unit on before it had enough of a charge to operate, Chargers for these types of tablets are way to little power for these things, will hold the charge when you use it but will not charge the unit when you use it, needs to go into standby to charge. Hold the power button and see if you can get a reboot screen or a turn unit off screen. Turn the unit off fully let it charge up alll the way then powere the unit back on. Should reset it. If not look for a small hole in the unit that says reset. push this and see what happens.
Nov 28, 2013 | Mach Speed Trio Stealth Pro Trio Stealth...
Mach Speed Technologies TRIO TRIO-STEALTH PRO METAL-7C 4.0 STEA Logo
142 people viewed this question
Top Mach Speed Technologies Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Mach Speed Technologies Audio Player and Recorder Expert? Answer questions, earn points and help others
