Question about 2005 Jeep Grand Cherokee Alternator Mean Green
Free mechanical advice online
So i replaced the battery ten days ago because i came out of work and it was dead i was able to get a jump from my friend and we went to walmart and bough a brand new battery. well on my way home from walmart my battery light came on and my friend told me [ he is a machanic but just isnt a 100 percent sure as to what my resulting problem is] it is the alternator when that light comes on. so i have been using my moms car because she doesnt want me to get stranded. well out of those ten days i have started my jeep every other day, but about three days ago i came out and my new battery was drained and wouldnt start. so i went online and found an alternator in b condition from a salavage place. me and my bf uninstalled the old one and replaced it with the one from the salavage place... we jumped started my car because the battery was dead and within minutes the battery light came on as well as my: abs light, my passanger driver seat belt [no one was sitting there] my E brake light and my traction light, and then shortly after my gauges for my gas and my RMPS both went down to zero as if the sensor for the gauges is broken. so we unistalled the used alternator and brought it to auto zone- i had the kid check it three times because if i didnt need to spend money for a new one i wasnt going to; all three times the alternator passed. so once again we went back to my house and installed this same salvaged alternator again... we let the cables sit on the battery for about five minutes because it was completely dead. and then we jumped it and it roared right up but again all the lights on the dash came on again and the gauges did the same thing again. I read that if i reved the engine to 25 rmps that it might rekick the magnets in the alternator because maybe it had been sitting and when i took my foot off the gas it slowly started to die. my boyfriend and i dont have a voltometere but it is a brand new battery and i had the alternator checked three times .... it still could be the alternator but for all those sensor lights to come on i dont think that is the alternator. as for the car dying i dont know what to do besides to spend 120 dollars for a brand new one, but i am at wits ends. if anyone knows what sensors or maybe what fuses to replace for this weird situation im ready to try it, but i have checked the two fuse boxes under the hood of my car and i didnt see any with a broken fuse. so doesnt anyone think that maybe it could be one of my engine spark plugs that could be fried.... I can tell you my engine light is not on, and the light isnt broken so i just couldnt see that being the reason..... AHHH please help!
  • beautifulsporter101 Jul 12, 2013
    and just so we know it isnt a mean green alternator it is just an alternator
  • 4 Answers
I had a very similar issue with my Blazer. Truck died pulling into my driveway one night...I got an alternator and replaced it right then, jumped it and let it run to charge the battery. Ran fine for a couple of days then one DAY it wouldn't start when I came from out from the store. I knew the alternator was good because it was brand-new. Bought a new battery and put it in. truck started but I noticed that the voltmeter gauge wasn't showing the normal 14volt charge. I went to Autozone to have them check the alternator, it checked fine with the hand-held machine in the parking lot so I pulled the new alternator off immediately and took it inside to be tested on the big machine...It tested good 3 times. After a little discussion about the problem they agreed to give me another new alternator (it was still under warranty). I put it on in the parking lot and VIOLA!...problem solved. The synopsis is this...the bad alternator damaged the old battery so it wouldn't accept and store the 14volts that the new alternator was putting out. The extra "pull" from the damaged battery, in turn, damaged the internal voltage regulator on the NEW alternator. Through this 2 week process I was getting weird warning lights on the dash and various other oddities. New alternator + new battery = problem solved = no headache/worry = happy! Good luck!
Posted on Jul 26, 2013
  • 5,280 Answers
Don't spend money on another alternator. Spend money to have it properly diagnosed, I mean the charging system. The used alternator is probably good after 3 tests. There may be a fusible link between battery and alternator, an in-line fuse, or a maxi-fuse (under the hood) between battery and alternator. Or Colin may be right about the computer-which again means diagnosing the problem.
Take your battery off and have it charged up-someone you know must have a battery charger. You can charge it up with it still on the vehicle, but first remove the negative battery terminal.
Possibly, all the lights came on because battery was drained and alternator was not putting out power. Once you fix the charging system or circuit, everything may resolve out. But you should start with a freshly charged battery.
Posted on Jul 13, 2013
  • 22,156 Answers
Sorry not an expert on american versions of this vehicle as they do differ from europeon ones .Ours are mainly diesels but as this is a 2005 model and no doubt a gas guzzler by europeon standards try 10 dollars a gallon but all this aside if its showing all these warning lights on the dash then i think you may have a fault with the computer as the low battery voltage could have damaged the computer ,not sure on this but it does happen quite often with renaults of a certain age so i can only advise you to ask a local mechanic to have a look for you and check it out .without my head under the bonnet sorry hood and my number two hammer in my hand i couldnt tell you ,only wish i could but its difficult to diagnose this sort of fault from alicante spain
Posted on Jul 12, 2013
How do you tell if it needs charged or not?
Hi Kelly, A fully charged battery is 12.4 to 12.6. and when the motors running it's 14.3 to 14.6... Three reasons your battery is flat (isn't charging), You have a faulty battery, A power drain or you have a faulty alternator... Clean your battery terminals and If you don't have a multimeter then Try jump starting your flat battery and driving your car for at least ten minutes then turned the motor off and try starting it WITHOUT jump start, If the battery's still flat then it's the battery, If your car starts straight away but won't start the next day then you have a power drain... If you jump start your flat battery and go for a ten minute drive but during that drive the motor dies without turning off the key then it's the alternator....
A mechanic or an auto electrician can usually test Free of charge if you can get it there....CHEERS..
Apr 16, 2016 | Cars & Trucks
Why is battery draining ford 2002 Taurus SES
Remove negative cable from battery, connect a test light to negative terminal, opposite end off light to negative battery post. ( let sit for 3 to 5 minutes). Then start pulling fuses, when the light goes out that's your bad circuit. God-Bless! Its worth a try.
Oct 01, 2015 | 2002 Ford Taurus
Post your question in the Cars or Ford cars category.
Nov 24, 2013 | Office Equipment & Supplies
Battery wont jump start
possible but my money is on a bad battery. have a load test done on the battery. I suspect that the over heating problem is not completely fixed as water pumps will still pump water as long as they can be turned . Probably all that was done was to tighten the drive belt . Unless the pump seal was worn out and you were loosing coolant.. Clicking noise when trying to start is bad connection or dead battery.
Nov 16, 2013 | Toyota RAV4 Cars & Trucks
My 2001 ford focus would not start a couple days ago the person that looked at it said it was the cable that connects to the battery terminal .Now it has dont it again this time it want jump start all the...
You need to fix or replace the cable and then charge the battery with a charger. Jump starting with a dead Battery will sometimes trigger the Security system and it will prevent starting.
Most likely your Battery continued to run down because the charging system could not get the electric back into the Battery. So as you drove, the Battery was getting weaker because of the bad connection of the cable.
Charge the Battery, fix the cable, and then go to Autozone or Oreillys for a free scan or charging system test. They will hook up testing equipment and find out if anything needs replacing. The testing is free.
Mar 18, 2011 | 2001 Ford Focus
I have a 2000 Denali that just turned over 200,000 and has never given me any problem until 2 weeks ago. I went to start it and it turned over and acted like it wasn't getting any fuel but wouldn't start...
Well, if you jumped the battery and it started, maybe you need a new battery. Get that checked out first. Also, when was the air filter replaced? I would probably take to an indy shop if it wasn't the battery or air filter because it could be a bunch of things: starter, fuel pump, fuel filter or fuel injectors.
Dec 31, 2010 | 2000 GMC Yukon Denali
I have a 95 nissan altima, its battery went dead two days ago and we jumped it and it started fine and ran fine. Last night it started sputtering and stalling. now everytime i try to start it it runs real...
Make sure the battery and alternator is working. Get battery and alternator checked. It did not jump timing. Autozone will do it free and Walmart will check your battery. Lets try this and get back with me
Dec 11, 2009 | 2005 Nissan Altima
Brand new battery is dead with nothing left on. Bad ground?
Remove positive battery terminal from battery & put a 12 volt test light in line between cable & battery post. As long as 12 volt light is illuminated, you have a draw. Start pulling & re-installing fuses, one at a time,until you see it dim or go out. If it goes out, you found your draw. If it dims, slight draw, such as radio memory etc. if all else fails, make sure you know where they all go, then pull them all, and start putting back one at a time. When light comes on bright, you found the circuit causing the draw.
Jul 03, 2009 | Dodge Intrepid Cars & Trucks
Battery on a porsche boxster is dead will not start up
If the battery is VERY dead it may take quite a while jump start the car. You may have to run the car with the good battery for five or ten minutes to get enough charge in the old battery to start the car. Other wise a very dead battery will just "soak up" the electricity from the good battery. If your battery was old to begin with it may be unserviceable. I would take the battery out and take it to an auto parts store that can charge and test it. They will usually do this for free.
Jun 20, 2009 | 2000 Porsche Boxster
2006 Ford Truck (Diesel) Just Clicks, Won't Start
had the eact same thing happen on my diesel and it turned out to be the alternator which had fried oine of the batteries.... you could put a charge on them and it would run for a week or ten days and then nothing.. clean the cables charge it up and it would go again... finally it just stop taking the charge and I look deeper and replaced the batteries ran fine for two weeks then dead again... alternator finally finished itself off... problem had been a little intermittent till then.. good luck
Nov 15, 2008 | 2006 Ford F-250 Super Duty
2005 Jeep Grand Cherokee Alternator Mean Green Logo
158 people viewed this question
Top Mean Green Alternator Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Mean Green Alternator Vehicle Part and Accessory Expert? Answer questions, earn points and help others
