Question about Fellowes Manufacturing 99666 Keyboard/Mouse
Keyboard hot keys
When any of the hot keys are pressed I get green writing on the screen Ie when internet key is pushed I see the word internet in green on the screen and then nothing the same happens when the e mail or search button is pressed I have uninstalled and reinstalled the driver several times. Any suggestions appreciated. RJ
  • Anonymous Nov 08, 2007
    i am having the same prroblem, fellowes kindly sent me a replacement keyboard but the problem is still there,
    Other hardware on my Abit ic7-g motherboard with p4 3.0ghz Prescott & 2* 512mb
    memory are, Logitech trackman wheel (with no software installed), Sony Ericsson
    dss 25 deskstand (with sony ericsson pc suite 3.1.1 installed) Logitech
    Quickcam messenger (with ver 8.48 software installed) 3 hauppauge nova-t pci’s
    (with drivers and remote software only), Creative soundblaster audigy 2 zs
    platinum pro sound card (with latest drivers and software from cd) nvidia
    fx5700le (with forceware driver ver 91.31) on a 21 taxan ergovision 2160 tc095,
    I am running directx 9c with Novembers updates and windows hass all the updates
    installed. I have spybot search and destroy and AVG installed.
    Do you have anything on your system that is the same as mine that could be causing problems?
  • tompet01ozno Dec 27, 2008
    Yes I have the same problem when I use the hotkeys all I et is green letters displayed on the screen with no action.
Green screen laptop
Press the "Function" key along the top row of your keyboard to toggle an external display; this key is different on each manufacture's laptop. If the external display has the same problems, your computer's video card or software is the problem.
Laptop Screen Is Distorted & Green ' Chron.com
smallbusiness.chron.com/laptop-screen-distorted-green-71653.html
Sep 03, 2013 | Aspire Computers & Internet
Turning off my green keys on HP pavilion desktop keyboard?
How to turn off Sticky Keys: disable the Ease of Access feature
Tip: use the Windows Ease of Access Center
How to turn off Sticky Keys: what are Sticky Keys and why turn them off?
Sticky Keys is a Windows Ease of Access feature that makes it possible to use keyboard shortcuts or type capital letters without needing to press more than one key at once. Normally, you'd hold down the Shift key while pressing a letter to type a capital, or hold down the Ctrl key while pressing 'S' to save a document. It's even trickier if you want to use a shortcut such as Ctrl-Alt-Del or Ctrl-Shift-Esc.
With Sticky Keys, you can press Ctrl, Shift or Alt, let go and then press another key - Windows will interpret this as pressing two keys together. You should also hear a beep if you have speakers connected.
That's great if you're disabled and can't press two keys at once, but what if you want to disable Sticky Keys?
How to turn off Sticky Keys in Windows 8
You can't press Shift another five times. Instead, you need to bring up the Start menu (or Start screen in Windows 8) by pressing the Windows key. Now type "ease of access" and click on Ease of Access in the list of results.
If you're using Windows 8, you need to click on the Ease of Access Keyboard settings result, and then it's a simple case of sliding the Sticky Keys toggle to 'off'.
If this does not help you. Let us know the below details to understand the issue bettery.
What is the OS?
What do you mean by hot keys? ex.......
Rgds,
Divya
Sep 02, 2012 | HP (395366-001) Keyboard
I am using Lenovo Y550 laptop. I want to use the Print Screen command but unfortunately there is no Print Screen key in this laptop. Could anyone please help me with regards to this issue. Thanks.
Most laptops do not have a dedicated print screen key, but instead have a function key (lower left of the keyboard, with some abbreviation of the word "function" on a key in a different color than the writing on the rest of the keys). Once you find the function key, look at the writing on the other keys that is the same color as the writing on the function key. One of those "other color" labels will be for print screen, and to use it, you hold down the function key at the same time as you push whatever key says print screen in the other color.
Jun 10, 2011 | Lenovo IdeaPad Y550 (41865GU) PC Notebook
Green function key locked on acer laptop
Hey, I've just been having this problem. Try pressing CTRL + SHIFT + FN all at the same time. I found out that I had to press them once to turn on the green keys, and then press them twice more to turn it off. I hope that works for you.
Feb 12, 2010 | Acer Aspire 4530-5889 Notebook PC
The upper case figs ie @ and " have swopped positions how do i get them back to their right postions
The difference in the @ and " symbols occurs between US and UK keyboards, where UK keyboards have the " symbol on the "2" key and US keyboards have the @ symbol on the "2" key.
Regardless of what physical drawing you have on the keyboard, you can change the actions of the keys by setting up the appropriate US or UK keyboard layout in Windows.
First, determine whether you'd prefer a US or a UK layout. In the US layout, pressing SHIFT+2 will write @. In the UK layout, pressing it will write ".
Now, from the Start menu, select Settings and go to Control Panel. Once there, search for "Regional and Language Options". Under the "Languages" tab there is a button labeled "Details". Press it, and a new window opens with the keyboard layouts. Use the "Add" button to select the keyboard layout you want (English, US or UK, Qwerty - not Dvorak), then Remove your old keyboard layout. Press OK and exit all the screens, you're done.
Hope this helps.
Aug 13, 2009 | Compaq Keyboard
I am observing on the left top of IE screen band
Start Internet Explorer. On your keyboard: * press and release the ALT key * press and release the T key * press and release the O key Click "use blank". Click "OK". Close Internet Explorer. Start Internet Explorer. You should now get a "blank" page.
Apr 26, 2009 | Microsoft Internet Explorer 6
LG r700 green keys wont turn off when using shift key in outlook
I was having the same problem - it was just driving me bananas. I figured it was a keyboard language, but when I checked my default it was still English (Canada) - US. I Tried the keys to switch between languages, I turned on and off the hot keys for input languages - all to no avail. FINALLY - I added a floating language bar to my desktop, and what do you think it was set at? That's right - bloody "Canadian French." I simply switched it back to "US" and problem solved. Now I just have to remember that for next time. . . . .
Mar 03, 2009 | LG NB E500-JAP51A Notebook
Internet..
Do you mean the internet explorer closes on you and you see the home page of the dash?
- Sounds like a corrupted file or issues with IE.
- are you viewing java script pages?
- I would do a master reset just in case. Just make sure to back up your phone first.
1. PRESS AND HOLD BOTH SOFT KEYS.
2. WHILE HOLDING DOWN SOFT KEYS, PRESS AND RELEASE THE POWER BUTTON, WAIT 3-5 SEC. (PHONE SHOULD POWER ITSELF ON BY DOING THIS)
3. RELEASE THE TWO KEYS SOFT KEYS.
4. WHEN SCREEN ON DASH LOOKS LIKE IT'S IN DOS FORMAT, PRESS SEND (GREEN ANSWER KEY)
May 27, 2008 | T-Mobile Dash Smartphone
Keyboard not responding
The keyboard has probably died. (It happens often). Here's a great inexpensive combo to replace your current one. https://www.amazon.com/Logitech-MK270-Wireless-Keyboard-Mouse/dp/B00BP5KOPA/ref=sr_1_1?ie=UTF8&qid=1491364851&sr=8-1&keywords=Logitech-MK270-Wireless-Keyboard-Mouse
Apr 03, 2017 | Dell Wireless Keyboard Optical Mouse w0147
Fellowes Manufacturing 99666 Keyboard/Mouse Logo
83 people viewed this question
Top Fellowes Manufacturing Computers & Internet Experts
Ekse
Alun Cox
Are you a Fellowes Manufacturing Computer and Internet Expert? Answer questions, earn points and help others
