Question about Delphi Car Audio & Video
Need a wiring schematic for a 2007 chev silverado Delphi radio part number 28076179
In a 2007 chevy silverado with bose system colors I am told are speakers don't appear to match up
etirbynnor
  • 655 Answers
SOURCE: NEED TO KNOW WHICH WIRE ARE WHAT ON DELPHI TRUCK RADIO
You may wish to consider purchasing a wiring harness that will allow you to plug directly into the vehicle harness without tapping or splicing. Here's a link to one such item: This one appears to be for your vehicle.
http://www.sonicelectronix.com/item_5944_PAC+ADD-GM24.html
Installer.com shows the following color code for the radio and speaker wiring for the 2007 GMC Sierra.
Speakers
White: (LF+)
White/Black: (LF-)
Violet/Black: (RR-)
Violet: (RR+)
Green: LR+
Green/Black: LR-
Gray: RF+
Gray/Black: RF-
Radio
Black: Ground
Red: +12volt Acc Switched
Yellow: +12volt Battery Constant
Blue/White: +12v Remote Output (Amp Turn On)
Red/White: Reverse Light Trigger
Yellow/Black: Parking Break Trigger
Orange/White: Auto Illumination
Blue: Powered Antenna
Orange: Illumination
Brown: Phone Mute (optional)
I would recommend that you verify the speaker wires before doing any splicing.
Attach a speaker to a pair of test probes and leaving the harness in and working, probe the back of each pair as coded above to insure that they really are the correct wires. Most likely you will want to convert the rears to low-level, so start with those. Probe the Violet(+)/Violet Black(-) pair and you should get sound in your test speaker. Likewise, do the Green(+)/Green Black(-) pair.
The only other wire you would need from the stock radio for an external amp would be the blue/white turn-on lead and if your LOC has audio sensing turn-on, you may not even need that. Bring power to your amp directly from the battery (fused according to amp manufacturer recommendations) and find a ground within 3 ft or so of where you intend to mount the amp.
Hope this helps.
Posted on Mar 28, 2009
iadame
  • 676 Answers
SOURCE: need Radio wiring diagram 2004 chevy silverado 2500hd (oem plug)
Left Front Speaker(+) TAN ; Size: tab_tech.gif Left Front Speaker(-) GRAY ; Size: Right Front Speaker(+) L GREEN ; Size: Right Front Speaker(-) D GREEN ; Size: Left Rear Speaker(+) BROWN ; Size: Left Rear Speaker(-) YELLOW ; Size: Right Rear Speaker(+) BLUE ; Size: Right Rear Speaker(-) LT BLUE
Yellow -ignition
Orange-Constant +12 volts
Black - ground
If you need more info, please ask.
A rating is appreciated.
Posted on Jun 13, 2009
emissionwiz
  • 76109 Answers
SOURCE: just need to know what colors do what on my 01
2001 Chevrolet Silverado C3500 Car Stereo Radio Wiring Diagram
Car Radio Constant 12v+ Wire: Orange
Car Radio Switched 12v+ Wire: Yellow
Car Radio Ground Wire: Black
Car Radio Illumination Wire: Gray
Car Stereo Dimmer Wire: Brown
Left Front Speaker Positive Wire (+): Tan
Left Front Speaker Negative Wire (-): Gray
Right Front Speaker Positive Wire (+): Light Green
Right Front Speaker Negative Wire (-): Dark Green
Left Rear Speaker Positive Wire (+): Brown
Left Rear Speaker Negative Wire (-): Yellow
Right Rear Speaker Positive Wire (+): Dark Blue
Right Rear Speaker Negative Wire (-): Light Blue
Posted on Feb 05, 2010
  • 10 Answers
SOURCE: I am replacing the radio in my '97 chev silverado
easy fix is to go to a car audio retailer such as best buy an pick up a wire harness adaptor they generally cost 10 to 15 bucks this will save you the hassle of tracing down the wires however general wires are red-power black-ground blue remote amp turn on eight of the wires are for the front and rear speakers thier colors are paired an example would be solid green and then green with a black line these two wires are for one speaker +/- connections you can connect on speaker one at a time and then use the balance and fader control on the radio to check which wire are for front/rear and left/right speakers the factory radio has extra wires which usally control power antena,and dimmer switch for when you turn the headlights on
Posted on Jul 16, 2010
Testimonial: "perfect!"
muntejaya
  • 10421 Answers
SOURCE: I have a delphi delco radio from a 07' chevy
Hi, Please get the code here:
http://carsoundsystem.org/car-music-system-unlock-code/
www.solware.co.uk/download-products/unlock-car-radio.shtml
Regards, Jay__Otgfvcu
Posted on Feb 24, 2011
Color codes for pioneer dehx6700bt radio in a 2001 Chevy Silverado
Here are a couple of schematics that should help your job. Should just be a matter of compare the wire mission and color from both diagrams.
2001 Silverado:
http://stereowiringdiagram.info/2001-chevrolet-silverado-1500/
dehx6700bt:
https://search.yahoo.com/search?fr=mcafee&type=B211US679D20140529&p=dehx6700bt+radio+wiring+diagram
Hope these links work, good luck!
Mar 01, 2015 | Cars & Trucks
2007 Nissan Altima Stereo Wiring Diagram for Bose Navigation
None are actually color coded. The schematic has the wire colors on it next to the wire.
May 01, 2014 | 2007 Nissan Altima 3.5 Sedan
I need to install a RCA converter in a 2013 chev silverado 1500 need front speaker colors it is the one without Bose
use a small battery of around 9vs and touck the wires to see what speaker is what ,no good asking me colours as iam colour blind
Dec 17, 2013 | Cars & Trucks
2009 silverado radio color code
even if your vehicle does not have a bose sound system or onstar because its a silverado it will need a special wire harness to intergrate a new stereo. no bs . this does **** but i will be around 149.99 for this part(any car audio place will carry this part) pretty much you CAN NOT hardwire a deck in there and is best not to play around with the wires. hope this helps
Aug 27, 2010 | Car Audio & Video
2005 chevy silverado stereo wiring diagram
Are you trying to install a new stereo? If so will need to re-wire all your speakers because of the bose system.
And if im not mistaken your year truck might need a really expensive harness to install the radio. Here is a link to it.
http://www.crutchfield.com/p_120GMOS04/GM-Factory-Integration-Adapter.html?tp=3486
You should look into this too! http://www.crutchfield.com/p_120GMOS04/GM-Factory-Integration-Adapter.html?
May 22, 2009 | Car Audio & Video
Speakers
White: (LF+)
White/Black: (LF-)
Violet/Black: (RR-)
Violet: (RR+)
Green: LR+
Green/Black: LR-
Gray: RF+
Gray/Black: RF-
Radio
Black: Ground
Hope this helps.
Mar 28, 2009 | Car Audio & Video
Bulb replacement on 2004 Chev Silverado Radio
No it cannot but if you go on ebay im sure you can find a cheap replacement.
Mar 13, 2009 | 2000 Chevrolet Silverado
Car Audio & Video Logo
69 people viewed this question
Top Delphi Car Audio & Video Experts
Lawrence Oravetz
Andrew Taylor
Andrew Taylor
gmduvall
Are you a Delphi Car Audio and Video Expert? Answer questions, earn points and help others
