Question about Nordic Track NordicTrack Elite zi Treadmill
Machine lights up, will incline to level 5 but nothing else works. Belt /motor doesn't move, and does not take any input either manual or pre-programmed. reed switch checked and adjusted. Is it a board issue?
  • 64 Answers
SOURCE: unit powers on but belt won't move (motor problem?)
You problem is with the motor controller. If everything works but belt want turn 99% of the time it's the motor controller. Call if you'd like more information. 404.456.2327
Posted on Jun 08, 2009
bwinton
  • 83 Answers
SOURCE: Treadmill Incline Works, belt does not move
Check the drive belt. It may be loose or broken. If the belt is loose, then to tighten the drive belt, start by removing the front cover. loosen the bolts around the motor then tighten the drive belt by tightening the motor adjuster bolt. Once the drive belt is tight, tighten the motor back down.
Posted on Apr 30, 2010
  • 218 Answers
SOURCE: My nordictrack a2250 turns on, the incline works,
the motor controller is bad and needs replaced
Posted on Aug 13, 2010
  • 42 Answers
SOURCE: NordicTrack T5.3 belt stopped working. It's only 1
HI, its seems like the belt on the motor has either slipped off, or you just need to tighten it. best way to find out is to take off the front pannel showing the motor. then stand on the treadmill. start it and you will see the problem.
Posted on Nov 21, 2010
SOURCE: Nordic Track A2250 Pro stuck inclined
My Nordic Track Treadmill A2250 is stuck on the 12% incline position and it wont go back down and I have tried to reset it by turning it off, switching the reset button to off and then on or even unplugging it several times. What would be my next move?
Posted on Feb 13, 2011
My console comes on. I am able to change speed and incline but my walking belt does not move. Could it be the motor has gone bad?
1) Lube the deck belt, maybe you have a worn deck belt, use 100% silicones or wax, check your instr. manual
2) Lube the rollers bearing with wd-40 very well
3) Test the drive belt motor, for cracking or worn belt
4) Test the input voltage motor, if there are the motor need repair, please go to my personal TIPS for motor help
5) Test the output voltage board, for input voltage motor, if there are NOT the board is faulty, see the block dia
God bless you
Dec 04, 2012 | Exercise & Fitness
My Reebok v6.80 treadmill turns and lights up but won't go.
1) LUBE the deck belt,you have a WORN deck belt, this happen because you didnot lube according with the schedule maintenance
29 LUBE the rollers bearing too
3) Test the drive belt motor, for worn or crack, or adjust if is possible
5) Test the output voltage board, for input voltage motor, if there are NOT the board is faulty.
God bless you
Nov 28, 2012 | New Balance 1400 Treadmill
Everything works except the Treadmill motor ? Incline works OK, belt doesn't turn at at all. Model EPIC View 550
1) You have problem with LUBE deck belt, this happen because the lack of maintenance, you must lube EVERY week, use 100% silicone lube. Maybe you have WORN deck belt,
2) LUBE the rollers bearing too, use wd-40
3) Test the drive belt motor, see for break, or worn, and replace or tension by 1/4"
4) Test the input voltage motor, if there are the motor need repair. see my personal TIPS for help and troubleshooting.
5) Test the output voltage board, for input voltage motor, if there are NOT the board controllers is faulty. God bless you. see the block diagram attached.
Nov 25, 2012 | Epic View 550 Treadmill
My Sole f83 will not start. initially Fans run, can raise/lower. will act noemal until motor should run/doesn't. then raise/lower function stops. If I try to use speed buttons LS light shows. moto
LUBE or wax the deck belt, this happen because you do not have schedule maintenance according with the owner manual. The machine shut down for autoprotection in electronic system Do it NOW.
2) LUBe the rollers bearint too with WD-40 only for rollers
3) Test the drive belt motor, for worn or cracking belt, replace or adjust it
4) Test the input voltage motor, if there are the motor need repair, see my personal TIPS for troubelshooting help.
God bless you
Nov 15, 2012 | NRS Sole F83 Treadmill
Treadmill nordictrack c 1900 motor doesn't run, belt doesn't turn
1) Lube the deck belt, in according with the instruction manual.
2) Lube the rollers bearing, with the i. manual
3) Test the input voltage motor, if there are the motor need repair
4) Test the output voltage board, for input voltage motor, if there are Not the board is faulty. God bless you
Jun 02, 2012 | Exercise & Fitness
Incline and decline wont move, so the belt wont move either. Have a jazfit treadmill
1)LUBE THE DECK BELT, INMEDIATELY.
2) tES THE MOTOR INPUT VOLTAGE, IF THER ARE THE MOTOR NEED REPAIR.
3) tEST THE OUTPUT VOLTAGE BOARD, FOR INPUT VOLTAGE MOTOR, IF THERE ARE NOT THE BOARD IS FAULTY.
4) tRY TO RUN THE SOFTWARE CALIBRITATION.
SINCERELY.GOD BLESS YOU
May 08, 2012 | Exercise & Fitness
I have proform CT 400 treadmill, belt does move. motor seems to be frozen, on control board red light blinks twice then stops and after few seconds blink again twice. Incline and every thing else work
Dear Sir:1) Lube the deck belt, maybe you have a deck belt worn, and need replace.2) Test the input voltage for main motor, if there are the motor need repair or replace.3) Test the output voltage from main board for input voltage motor, if there are NOT, the board is faulty.4) See the drive belt and replace it.See my personal tips for HELPsincerely. God bless you
May 03, 2012 | Proform Exercise & Fitness
My treadmill won't start. It sounds like it is inclining when I insert the key but nothing lights and it is not moving.
Dear Sir:
Inside test the fuse and replace use DVOM, or reset the c.breaker
2) Adjust the reed switch see the diagram attached, clean,and tight the connector very well. Tigh the ribbon cable from keypad + connector from display board vs lower board
3) Lube the deck vs deck belt, this produce enough friction.
4) test the input motor voltage,if there are the motor need repair or replace
5) Test the output voltage from the m.motor board for the input motor voltage, if there are NOT the board is faulty.
6) Try after your fix, the software calibration for diagnose, and troubleshooting.
May 01, 2012 | Proform CrossTrainer Treadmill
Treadmill will not level out and motor sounds all the time
If the incline moves but only just a bit, it could be a problem as simple as the gearbox on the motor being jammed. We remove the motor from the treadmill, reconnect the wiring, and then try to run the incline motor outside the treadmill. Many times, this will unjam it if that is the problem and then reinstalling it in the treadmill will get it to work. If you have the same problem or it doesn’t run outside the machine and you can hear it try to work, you need to replace the incline motor.
Jun 27, 2010 | Proform 575 Crosstrainer Treadmill
Manual Treadmills vs. Motorized Treadmills
Treadmills come in two basic varieties, just like lawnmowers: manual and motorized. But, unlike a lawnmower, you will generally get a better workout from a motorized treadmill. Manual Treadmills - Getting Going On a manual treadmill, the action of your feet against the deck moves the belt. Pros * You provide all of the motive power and exercise your lower body. Cons * It can be difficult to get the belt moving intially. That straining against the belt can stress your joints. * You may have to raise the incline of the treadmill significantly to make it easy enough to get the belt moving. * Once the belt is moving, however, you would have to stop and get off to change the incline, so you are stuck with one incline level during each workout. Motorized Treadmill Advantages * The belt is moved by the motor, you don't have to strain to start it. * On many treadmills, you can adjust the speed and incline while you are still walking or running. On others, you may have to get off and adjust the incline manually, but you just have to turn on the treadmill to start the belt again. Manual Treadmills - Speed With a manual treadmill, you go only as fast as you push yourself. If you slow, it slows. If you stop, it stops. Motorized Treadmill Speed and Workouts The speed is adjustable and many motorized treadmills have workout programs that adjust the speed to give you a varied workout. This pushes you to go faster. The constantly moving belt of a motorized treadmill motivates you to keep up. Costs Manual treadmills are relatively inexpensive, in the $100-200 US range. Motorized treadmills for home use cost from $750-$5000, and generally the more you pay, the better you get. Most motorized treadmills under $1000 have underpowered motors and are less sturdy and have fewer options for adjusting the incline, programmed workouts, etc.
Dec 01, 2008 | Endurance TF3i Folding Treadmill
Nordic Track NordicTrack Elite zi Treadmill Logo
35 people viewed this question
Top Nordic Track Exercise & Fitness Experts
Matt Olenzek
Matt Olenzek
Ross Metcalfe
Ross Metcalfe
 Atlanta Fitness
Atlanta Fitness
Level 1 Expert
Are you a Nordic Track Exercise and Fitnes Expert? Answer questions, earn points and help others
