Question about Radio Communications
Wwhat is the value of r239 in a galaxy saturn
Galaxy saturn turbo service manual
check out www.cbradio.nl:servicemanual they have a Saturn and it should be the same as the turbo . Good luck.
Feb 25, 2017 | Galaxy Radio Communications
Recive trimmer on a galaxy saturn
Its a lot more work then you think but it can be done . you should do a serch for a service manual online and work off of it.
Jun 15, 2012 | Galaxy Radios DX-99V 40-Channels Base CB...
Where is the valve gasket located on a 1996 Saturn CR
Around the edge of the value cover. The value cover bolts to the engine head (top) and the gasket fastens between the cover and the heads, All the cover and gasket do is direct the oil on top the engine values to flow back down into the engine block after this been pumped on top of the value stems. Gasket breaks and you have oil around the engine an on the ground. Also smoke when your driving around.
Apr 01, 2011 | Saturn SC2 Cars & Trucks
Galaxy saturn ...roger beep just chirps no beep
either a capacitor has changed value or someone changed it. with the board facing you --front right where the mic connector would be on a mobile unit is were the roger beep components are. make sure none are blown or no resistors are burnt. We can restore it back to a factory beep if you would like.
Dec 17, 2010 | Radio Communications
Rolling Frequency Counter
I'm giving this info from the Master Edition of C.B. Tune-up manual Volume 1 year -1995. The original price of this info was $39.95 But I have had people help me with radio info. so here it is---- on page 60 it says [ Model ] : Galaxy Saturn ( and export models using the same Freq. counter module ) The most common problem with the { Galaxy Saturn } is after it has been on for awhile the read-out becomes unstable. And sometimes it will quit all together. This problem has been traced to a Zener Diode inside the freq, counter module. The square silver box located right behind the speaker. The Zener Diode inside marked D-603. This is a 2.4 volt , 1/4 watt diode next to IC-609 the ( LM-7808 ) regulator. REMEDY: change D-603 to a ( 2.4 volt , 1/2 watt diode) This should restore normal operation. {{{{ 357 - MAVERICK }}}
Mar 13, 2009 | Galaxy Radios DX-2517 CB Radio
Not a Galaxy DX-2517
its a mexican kraco clone,lol
Aug 09, 2008 | Galaxy Radios DX-2517 CB Radio
Radio Communications Logo
Top Radio Communications Experts
eradiostore
eradiostore
Mike Charette
Are you a Radio Communication Expert? Answer questions, earn points and help others
