Question about Baby Gear
Brevi ovo stroller
Frame folds by pushing one button (the one that adjusts the height of handles), need new frame
Noggin
  • 944 Answers
SOURCE: Graco Metrosport stroller Model No 611198E
contact these guys for replacement parts; http://www.gracobaby.com/store/order/default.asp?N=10418+10413+10421&Ne=11 Hope this helps :)
Posted on Jul 27, 2007
  • 729 Answers
SOURCE: fixating mechanism in handle is broken
i can't figure out where your stroller handle broke! if there's a possibility that you could send me an image (close catch) on the broken part and rear view of the stroller, email it to me in jpeg or pdf type..... here's my email address... jyzomnix1@yahoo.com
we'd like to help you much...
Posted on Mar 02, 2008
SOURCE: Bagaboo Frog stroller white circle adjustable button out of order
see here: http://strollers.2y.net
Posted on Jun 22, 2009
  • 419 Answers
SOURCE: need repair on the handel of Rock star baby stroller
Your best bet is to contact Hauck UK. Their number is (0)1978 664362 and the website is www.hauckuk.com
I hope this helps.
Posted on Sep 14, 2009
  • 14 Answers
SOURCE: How to fold the Graco Stroller 6001BCL1
Take the carrier off by raising the handle and then lifting the handle with one hand as you pull the red handle on the back of the carrier with the other hand. Set the carrier aside and stand behind the stroller. There should be 2 matching plastic 'things' on either side of the stroller, just under the rubber handle. Put your thumbs on the rubber handle and your first 2 fingers on those plastic pieces. Pull those plastic pieces up with your 2 fingers and the stroller will collapse. I hope this helps!
Posted on Sep 29, 2009
How to fold mia moda 3 wheeler
Step 1
Inspect the stroller's wheels and handle to identify the type of brake mechanism it has. If the device is equipped with wheel-mounted brake levers and swivel locks, use the toe of your shoe to activate these mechanisms. If your stroller is equipped with a handle-mounted brake lever, push down on the lever to engage the brakes. Some models also come equipped with a secondary-locking mechanism located on one of the rear crossbars; use the toe of your shoe to activate this feature.
Step 2
Lift the handle or press the tab securing the backrest in place, located on the upper edge of the backrest or on the crossbars securing the rear of the backrest to the frame. Grip the edges of the footrest, then lower the component by pushing it into the desired position. Pull back the stroller's canopy.
Step 3
Grip the stroller's handle and lift the device upward; if the stroller comes equipped with a safety button, press the button as you lift. Use the toe of your shoe to push on the stroller's hinges until the frame begins to fold.
Step 4
Pull the halves of the stroller's frame together until you have completely folded the device; if the stroller comes equipped with a locking latch, engage the latch to keep the halves from sliding apart.
Audi Parts
May 23, 2012 | MIA MODA Atmosferra Travel System Stroller
Fixating mechanism in handle is broken
Ok, how is the frame broken ?
what is it made off ?
please reply with more info.
Mar 02, 2008 | Chicco 3WD Tech - Canarie Stroller
I need to know how to fold/unfold a Britax Italian Collection Sports Practicale
hi
this is from memory so bear with me
on the handle there is a button i think you slide this to the side and squeeze the button under the handle and push the frame to the floor untill
it stops on the saftey latches that are located on the sides of the frame press these (not sure if the is one each side)
continue to push down untill fully folded
to open (this is where im a unsure) do the same with handle buttons and put your foot on the frame between the rear wheels and slide the frame upwards untill it clicks into place you may have to pull up fast at the last moment
if this doesnt work please get back to me as i may have some instructions somewhere
Mar 12, 2011 | Baby Gear
I can't fold it
If the dreami carrycot or the maxi cosi car seat are attached, these will have to be removed first. Apply parking brake Release the handle bars by unclasping the silver clips on the frame. Push down handlebar to lowest height as you press in the silver button under the quinny logo on the very top of the handlebar( in the middle of the foam padding) with a downward thrusting motion. The chassis should then collapse for storing. To unfold then release the transport clip on the left hand side with the red sticker on it and unfold upwards adjust handlebar to required height and lock by closing the silver clasps either side of the frame. HTH
Jun 30, 2010 | Quinny Freestyle 3 XL Stroller
How do i put the chassis up and down
Push in the little white button on the frame handle and pull the 2 buttons on either side of the handle - if the frame doesnt fold doew gently move the handle a bit untul you hear a click then should fold
Jun 18, 2010 | Bugaboo Frog - Black Stroller
Fold and lock stroller
The handle twists after you press the red tab on handle, there should be a red little flap than is the way to hold collapsed. A bag???? buy a hockey duffel.
May 18, 2009 | Graco Quattro Tour Deluxe Travel System -...
Folding Quinny speedi Sx Stroller
In the middle of the underneath of the pushing handle, below where the hand brake lever is there should be a button. If there is, this is what you do.
1) put the foot brake on so the rear wheels wont turn.
2) unclip the clips on the frame that allow you to adjust the height of the pushing handle, they open up, and leave them open, like this the handle you push the buggy with should slide up and down.
3) pull this handle out to its tallest position
4) Hold the handle and press the button mentioned at the start in and hold it in
5) Then quite quickly push the handle down as though you were either pushing it to lower its pushing height, or shoving it away in a temper. It needs to be a firm and quick movement.
Ta da!! After a couple of tries it should click and fold up.
I hope this helps.
Apr 09, 2009 | Quinny Buzz Jogger
How do I fold my Zooper Sport?
OK, I finally figured out how to fold & unfold this ******!
To fold: Stand behind your stroller. Go to the joint in the middle of the push handle. You have to simultaneously push up on the button underneath the joint and pull back on the little trigger at the front of the joint. I've found that this will require both hands. Doing this will unlatch the joint, and you now need to push it forward to fold the handle into a "V" shape. Now look down to the crossbars just above the rear wheels, and you'll see a handle (kind of like on a sutcase) above a sort-of triangular-shaped piece of plastic. Lifting up on either of these will collapse the frame the rest of the way. Push the rear wheels as far forward (toward the front wheels) as you can, and it will latch shut. If you swivel the front wheels around to the rear, the stroller will stand on its own
To unfold: From above and behind your folded stroller, with it standing on its front wheels (as described above), place both of your hands on the side/corner joints of the rear push bar. From the top, run both of your thumbs down the back side of both rails. Your thumbs should hit a 'bump', then a slightly smaller 'bump' immediately underneath the first. That second 'bump' on each side is the latch that keeps your stroller folded. Squeeze both the latches on each side with your thumbs, and you should hear them unlatch. Now the frame is free, and you have to push down on the suitcase handle in the middle while lifting up on the center joint of the push bar. Pull back on the push bar until it latches, and then keep pushing down on the suitcase handle until the whole thing latches.
Jan 24, 2008 | Zooper CoolZone Sport Stroller
Bertini M5 Shuttle
hi I think I could help I bought a bertini shuttle as well if you stand behind the pram on the right run your hand down the right side of the hood there is a push up lever there mine is grey ok you need to push the grey? lever but also on the left and right there is a black lever you must push up al together hope this helps good luck from debbie
Jan 09, 2008 | Bertini M5 - TS City Stroller
Mutsy
Hi guys, I had this problem when I first got my urban rider - the trick is to put the seat on correctly in the first place. If you look under the front of the seat (when seat is facing away from mum/dad) you'll see 2 plastic hooks - these need to be hooked over the first horizontal bar of three that you can see (it has a small black plastic nobbly bit on it) then, as you were doing, push the handle and pull the 'tube' on the left. If the seat is facing you (child travelling backwards) it won't fold, neither will it fold with the carry cot attached.
Hope this helps! Tegans mum x
Nov 15, 2007 | Mutsy 4Rider - Pink Stroller Frame
Baby Gear Logo
15 people viewed this question
Top Baby Gear Experts
Dorel UK
Dorel UK
Jennifer Rock
Jennifer Rock
Are you a Baby Gear Expert? Answer questions, earn points and help others
