Question about Water Heaters
Where is Anode Rod on rheem model 41vrp40n power vent water heater
2 Suggested Answers
  • 13 Answers
SOURCE: rheem model 41vrp40n power vent water heater won't
"Pres sw open" means there is insufficient air flow. either the vent if blocked, or the blower turns too slow/ or died.
Posted on Feb 12, 2010
Anode rod Installation for Rheem Water Heater Model 41VR40N
Anodes last a very long time. It will be on a pipe plug going into the machine. As long as most of it is there, it's ok.
Nov 29, 2013 | Water Heaters
Replacing a rheem power vent water heater
1) Avoid Rheem.
http://waterheatertimer.org/pdf/Which-is-best-gas-water-heater.pdf
http://waterheatertimer.org/How-to-install-gas-water-heater.html
2) Maintain water heater. Pay yourself 10$ a month in future replacement costs.
http://waterheatertimer.org/How-to-maintain-water-heater.html
3) Read product manual for power vent specifications.
Keep in mind that power vent on top of heater can sometimes cover access to anode rod located on top of tank.
Dec 21, 2012 | Water Heaters
Rheem 21VP50-1P - power vent running non-stop.
Rheem does not post service manuals, but other manufacturers do.
Copy following link for troubleshoot by type of gas control valve.
http://waterheatertimer.org/How-to-troubleshoot-gas-water-heater.html#intellivent
Also, scroll up on same page, on right side for heading title 'Pressure switch' for troubleshooting the pressure switch.
Don't forget to check anode rod to protect steel tank from rusting.
http://waterheatertimer.org/Replace-anode-rod.html
Oct 12, 2012 | Rheem Water Heaters
Rheem model 41vrp40n flashes twice and stops working
Error code means that you have electronic gas control valve.
Copy following link to identify gas control valve, read error code meanings for each, and download service manual relevant to each gas control, but not specifically Rheem since rheem does not post service manuals.
The fact that water heater restarts, means that water heater is getting gas, getting sufficient air for combustion, thermister is ok, gas pressure is good, etc.
The fact that you unplug and replug water heater and it works, shows that you have power vent model.
Since water heater worked correctly before, 2 flashes with Rheem power vent model could mean that pressure switch has failed.
Jul 29, 2012 | Water Heaters
Where is anode located mdel no. 82yp30-1
Question posted under Rheem water heater.
Model number does not describe water heater.
Model number posted in question does not appear at Rheem, and does not appear in a web search for water heaters.
Here are options:
1) Add a comment and describe water heater in detail so expert can access more information
2) Contact Rheem.
http://www.rheem.com/Contact.aspx
3) If this is tank-type water heater, the anode is located on top of heater.
Look for 1-1/6" hex nut located under a plastic plug.
Some anode rods are connected to the hot-water nipple.
Sometimes the top cover has to be removed to find anode hex nut.
I have used impact wrench on anode, and could not remove in some cases.
4) More resources:
Sep 17, 2011 | Rheem Water Heaters
I need anode rod for my rheemglas fury model # 81V52DT. do you know what the part # is or maybe the dementions. There seems to be several diffrent ones out there. Thanks
Anode rods are generic and available from local plumbing supply store or internet.
Just cut it off so it drops into the tank without touching the bottom or sediment on the bottom.
If there is not enough room above the tank to install new rod, then buy anode rod with sausage links.
Open following link for Rheem parts: page 7 shows anode rods
http://waterheatertimer.org/pdf/Rheem-parts-list.pdf
Jul 02, 2011 | Rheem 81VP6S/430126 Water Heater
Where is the anode rod located on the rheem 81VP20s
Anodes are located on top of water heater.
There are no hard fast rules for location, either by model number or brand.
Most times the manual is likewise vague.
1) There is hex head visible on top of tank.
2) Hex head is located under a plastic cover
3) Hex head is located under metal top, so remove screws holding top, and lift top off to view hex head
4) Anode is connected to hot water nipple.
5) With 9-12-15-and lifetime tanks, you can have 2 anode rods, and each has to be made of same material to work properly. Usually magnesium-aluminum instead of aluminum.
But if you inspect and change anodes frequently to prolong life of tank, then one is as good as the next.
Open following links shows Rheem anode rods
http://waterheatertimer.org/pdf/Rheem-Ruud-anode-rods.pdf
http://waterheatertimer.org/pdf/Rheem-Ruud-water-heater-parts-guide.pdf
Tech resistor anode rod has resistor added to prolong life of anode.
You can cut rod off to fit size of tank. You want anode 5-6" from tank bottom so sediment build-up doesn't reach anode.
Anodes are standard 1-1/16" hex head.
http://waterheatertimer.org/images/Water-heater-anode-006-200.jpg
http://waterheatertimer.org/Clean-sediment-out-of-water-heater.html
Add a comment with your experience so others with same-similar problem can benefit.
Also take advantage of fixya expert assistance live.
For a price, expert works with you while you work on water heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
Apr 01, 2011 | Rheem 81VP20S/430157 Water Heater
Water Heaters Logo
27 people viewed this question
Top Water Heaters Experts
Donni Steen
Gil Shultz
Are you a Water Heater Expert? Answer questions, earn points and help others
