Question about Craftsman Garden
Briggs rider 14.5 hp runs wide open, won't idle down
  • 140 Answers
Possible a linkage problem. It may be stuck. Check it first.
Posted on Jul 13, 2014
4 Suggested Answers
  • 6468 Answers
SOURCE: 2002 sabre lawn tractor runs wide open cannot idle down
sounds like the governor gear is striped you need to open the engine to replace it
Posted on Jul 13, 2012
BAMOUT
  • 2478 Answers
SOURCE: what are the valve specs
.004" ON BOTH. Go you tube and on the line type in
adjust valves B&S 17.5 engine. WATCH THE VIDEOS.
Posted on Aug 02, 2012
  • 6468 Answers
SOURCE: My Kohler Command 20 HP running fine, shut down, won't restart. How should I troubleshoot this problem?
check for fuel try starting fluid if it fires on that then you have spark if it does not then you have a spark problem and seeing the command engine has two coils check the safety switches on the mower side
Posted on Aug 12, 2012
Why does my B&S engine runs wide open even with throttle off 20 HP
Check the cable connection down near the engine, it should be attached to the throttle lever, it is not uncommon for the screws that clamp the cable to come loose
Jul 04, 2014 | Briggs & Stratton Starter Scott's Equip...
Briggs
check the linkage on the top of the carburetor that controls the butterfly, it may be stuck. lubricate the shaft that runs through the carburetor with the butterfly attached to it. This is the Governor linkage
Jul 11, 2013 | Garden
My briggs and stratton engine throttle cable and throttle body wont engage,always wide open
Are you sure it's not a new style Briggs that uses the 'throttle cable' just as a shut off? Many new mowers on;y start and run at High Speed
Jul 05, 2013 | Briggs & Stratton Garden
Vanguard V Twin 18 hp. monted in Cushman Motor scooter, runs great at W.O.T and at on quarter throttle, misses at range inbetween
Sounds like your carb needs the fuel/air mix adjusted..uses all the gas at high speed but has excess at low speeds...find your adjusting screw and at med throttle slowly screw it clockwise until the engine starts to sputter then back it out until it starts to sputter again then continue to do this until you reach ideal mix where it runs the best it can..then go slowly through the throttle up and down..when set..unjust your idle speed screw to your ideal idle speed..if this dies not fix ..carb will bed cleaned or rebuilt. Good luck.. Note always push or pull your throttle handle slowly to position avoids gas load up causing sputter and backfire.
Mar 15, 2012 | Briggs & Stratton Briggs Stratton Vanguard...
Have 22HP BS V-Twin in a 2010 Husqvarna rider w/25 total hours. Recently won't cold start without priminig. It will crank and crank cold til the battery runs down. A shot of starting fluid and it runs...
nearly all petrol mower engines need to have the 'choke' engaged to start from cold. This enriches the fuel mixture, and is similar to priming. If there is a prime 'button' then you will probably have to use this all the time. This is normal.
However, you should check with your dealer to see if this is an unusual situation.
Aug 27, 2011 | Briggs & Stratton Briggs Stratton Intek V...
20 hp b&s runs wide open
sounds like the gov. fell out in to the oil pan. if you remove the gov. springs and let the gov. arm move up. it will fall out. no book will till you that. if that happend you will have remove the motor and pull the oil sump pan. and put it back to gether make sure you keep the motor up side down. untill you reajust the gov.
May 18, 2010 | Briggs & Stratton Briggs Stratton Intek V...
20 hp intec runs wide open
24 hp briggs. replaced cam, exhaust lobe was unhardened. now it doesnt fire on that cylinder. plug is wet. spark tester shows spark,please help.
Mar 30, 2010 | Briggs & Stratton Briggs Stratton Intek V...
Garden Logo
142 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
