Question about Kenmore 53552 / 53554 / 53559
Kenmore Ice maker not producing ice, what are some troubleshooting steps?
My Kenmore Coldspot, Model 53552201, ice maker will not make ice. I have replaced the optics but it still not making ice. I have installed jumper between T and H on module but nothing happens. I measured for voltage across L and N and got nothing, but I had 120 volts at the plug where it snaps into module. What do I do next as far as troubleshooting or do I need to replace the whole module?
  • 172 Answers
SOURCE: Kenmore Coldspot w/Ice Maker Not Making Ice
hi LOP7,
In most cases you can easily solve this problem.
step one would be to make sure your freezer is getting cold enough. If you have icecream in your freezer is it frozen solid or is it soft. Most icemakers cycle around 0 degrees and if your freezer is not getting to 0 then it will not cycle and it will not make ice.
Step two would be to make sure you icemake is cycling. To do this simply lift the little shut off arm on your icemaker and wait about an hour then go back to the icemaker and drop the arm down. The icemaker should start going through a cycle. You should notice the arm slowly begin to raise and the ice dispencer fingers will begin to turn. Then you will hear it call for water. You may hear a humm.
If the freezer is cold enough and the icemaker is cycling that only leaves the inlet valve. replace the valve and enjoy the ice.
If the freezer is cold enought and the icemaker does not cycle, then you have a bad icemaker. Simply replace the icemaker and viola.
Third if the freezer is not cold enought 0 defrees. Then you may have a defrost problem. In this case post more info and I will be happy to help. Good luck mca0824@aol.com
Posted on Apr 30, 2008
TheMobilian
  • 8220 Answers
SOURCE: Ice maker not working Kenmore model 106.55226400
Look for an ice cube lodged in the fingers IM. Get a hair dryer and melt that dude. No ice cube? Add some water to the IM mold. If it kicks out some ice but makes no more then you is gonna need a water valve. If it don't kick out no ice then you is gonna need a ice mold thermostat. Either one is very easy and cheap to fix. let me know Kimosabe.
Posted on Mar 06, 2009
Maytag317
  • 1136 Answers
SOURCE: Kenmore side by side makes no ice
Hi, While you had the ice maker out, did you notice if there was ice in the inlet spout to the ice maker. Sometimes they get plugged.
Do you know if the ice maker advances at all?
Because you have voltage to the ice maker, if it does not advance you will need to replace the ice maker.
I hope this helps you. Please let me know if I can assist you further.
Vic
Posted on May 29, 2009
  • 415 Answers
SOURCE: Ice maker won't stop producing ice, even when bucket is full.
the arm that swing up and down maybe able to be ajst by bending arm and the water leaking down the icemaker. is it unlevel when if fills if not unlevel is it hooked up to an r/o system if it is when was the last time filter were replaced if not, does it have a water filter has it been changed lately.
Posted on Aug 20, 2009
  • 6 Answers
SOURCE: kenmore coldspot 106.556325 not making ice
could be your ice maker or your water valve
Posted on Aug 30, 2009
Kenmore coldspot model 106.71252101ice maker freezes ice but will not drop it does it need to be reset or what
The thermostat on the ice maker is out you will need to replace the whole ice maker assembly
Feb 14, 2015 | Kenmore Refrigerators
Kenmore coldspot model 106.58902800 ice maker does not dispense ice
Ice maker will not dump ice, makes it but will not dump ice.
Jan 30, 2012 | Kenmore Refrigerators
I have a Kenmore Coldspot side by side. The ice maker is not working.
Here is a tip that I wrote about the reasons why ice makers do not work.
Ice Maker Problems and Ice Maker Troubleshooting
heatman101
Nov 18, 2010 | Kenmore 56239 / 56232 / 56234 / 56236 Side...
The ice maker has stopped working, the motor is co...
heatman101
May 20, 2010 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Aug 20, 2009 | Kenmore 57029 Side by Side Refrigerator
Kenmore Coldspot side by side. The ice maker will
Hello. You will need to replace the icemaker. The swicth in the head is causing the arm to stay up and is not repairable. If you can get me the model number I can get you the part number.
Jul 15, 2009 | Freezers
Mar 06, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Ice maker
I have kenmore two door fridge. My icemaker is not working but the water dispenser is. Model#DU800DWGQ1 Serial#FJ1814737
May 14, 2008 | Refrigerators
Kenmore 53552 / 53554 / 53559 Logo
57 people viewed this question
Top Kenmore Refrigerators Experts
Sal DeAngelo
dweatherby
paulcarew
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
