Question about Garden
Husqvarna YTH20k46 wire harness diagram
Will not start when turned over
  • 3 Answers
SOURCE: Husqvarna riding mower. Wont start.
check your switch for your blades take it off(shut it off)
Posted on Sep 09, 2009
  • 3911 Answers
SOURCE: Backfire - Husqvarna YTH20K46
I find my 2148 runs much happier on the medium grade shell than on the cheaper gas. I did have a nasty POW, which resulted in bent pushrods, or perhaps the bent pushrods caused the POW. After replacing the pushrods, and adjusting same, the backfiring stopped altogether. knock on wood. The 21 is a B&S engine which has a propensity to the bent pushrods. Fortunately for me, my neighbor is a wiz at those fine adjustments.
Posted on Mar 24, 2010
SOURCE: I HAVE A HUSQVARNA YTH20K46. IT STARTS AND THEN
If it starts and dies on choke.. then try these two things. Take the bulb off of the carborater and clean it out and clean spray the 2 holes that put gas into the float bulb. Also change the spark plug. This will fix your problem!
Posted on Apr 04, 2010
BAMOUT
  • 2478 Answers
SOURCE: Husqvarna YTH20K46 Lawn Tractor Will not Crank due to battery issue
Check the start fuse, under dash and back side of engine.
Posted on Jun 02, 2012
  • 6468 Answers
SOURCE: connected a battery wrong and now Husqvarna YTH20K46 will not crank
look for a blown fuse there taped to the harness
Posted on Jun 06, 2012
Husqvarna YTH20K46 no power. HELP!
Not turning off sounds like an ignition switch problem. Not starting - then I think you should check the Low Tension side of the solenoid again to make sure there is current from the switch. If the solenoid's OK, the battery's fully charged with all the connections clean and tight, then it has to be the starter motor or engine. Check you can turn the engine by hand, if so then I would guess, it's probably the starter motor.
Good Luck
Apr 21, 2013 | Husqvarna Garden
Jun 02, 2012 | Husqvarna Garden
Connected a battery wrong and now Husqvarna YTH20K46 will not crank
I have a yth20k46 and when I turn the switch it won't turn over. I replaced the battery and spark plugs. what might be the problem
I also have a YTH20K46. During last mow (last week), I tried to turn off mower and would not turn off by key. I had to put it down to choke and then stand up. It created a backfire. Today I went to start it, now won't start. It does not turn over. Hour meter has no power. Tested battery & solenoid. Power to both. Key switch works fine. Any suggestions? Just had it serviced a few months ago. Oil, gas and all other things seem fine. Checked wiring, seems fine. Nothing melted or cut. Please help!
May 23, 2012 | Husqvarna Garden
Husqvarna riding mower modle yth20k46 that move very slow
The link rod from the petal to the transmission straightened out at the rear bend. Take it off and bend it slightly further to make it go forward faster. The 1/2" nut above where the rod connects to the transmission is adjustable to set it where it doesn't move when your foot is off the petal. Loosen it a bit and you can move the petal slightly forward or backward to adjust it. Depending on how much you bent the rod it won't take much adjustment. Re-tighten and try it out. It may take a few tries. Good luck!
Mar 17, 2012 | Husqvarna Garden
Husqvarna yth20k46 - When turning transmission does not work
I only had my mower 3 months and that problem started. I was told to change the drive belt, It got worse. Now the transmission will only drive the mower for about 15 min and will come to a complete stop. I have to let it sit about 30 min before the drive will work again. No solution yet but I'm looking at replacing the "sealed" drive assy. I do have a very healthy yard of St Augustine which is tough. I can mow a thinner yard a little longer.n
Apr 06, 2010 | Husqvarna Garden
Mar 22, 2010 | Husqvarna 23 Hp 48" Deck Yard Tractor
Sep 05, 2009 | Husqvarna 23 Hp 48" Deck Yard Tractor
Garden Logo
85 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
