Question about WeatherWorks CH-1850SFW Riviera Stand (Pedestal) Fan
Fan makes clicking noise when oscillating
I have a stand up fan that, when it oscillates, it gets stuck when it turns all the way left or right and makes a loud clicking noise. When I push it or spin it, it usually stops, but then does it again the other way. I tried to turn it and take the screw out, but nothing works. Please let me know what to do. Thank you.
  • 2 more comments
  • HayleyBette Sep 02, 2007
    Thanks for telling me what was wrong... How do I fix it?
  • Anonymous Nov 17, 2007
    My brand new Sona standing fan with metal blades is powerful but makes loud noises, the sound of wind i think. Rather than discard it what can i do to the blade to reduce the noise?
  • lasabre Apr 18, 2008
    when turned on theres a loud squel sound and blades rotate slow
  • cafebreezy Jul 21, 2008
    My fan doesn't always oscillate, can I fix it myself? I know there is a little screw where it oscillates and sometimes if I turn it,it works.
  • 625 Answers
Inside the motor there is a nylon gear that is broken. the oscillation operates off a gear connected to the motor drive.
Posted on Aug 31, 2007
  • THOMAS MIERZWA
    THOMAS MIERZWA Sep 02, 2007
    the guard comes off by rotating several clips around the outside of the guard. there may be two rivets or screws at the bottom that have to come off. the blade is held on by the white knob. it is screwed on with a left hand thread. hang on to the blade and turn in a counter clockwise direction. pull off the fan blade. there will be a roll pin in the shaft. the roll pin must be removed. the two halves of the housing are screwed together. take out the two screws. the housing also has the bottom pivot for the oscillations. this is a rivet not a conventional bolt. rotate the motor armature by hand until it reaches its extreme direction and you'll see what's broken or stripped. on your computer find a parts place for your particular fan. nelson appliance may have the parts or can steer you to a place that will have parts.
SOURCE:
18 inch adjustable pedestal fan model s18902
Alice, Check the attached Lasko Fan video links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
18 Lasko Cyclone Oscillating Stand Fan model S18902
How to Assemble Lasko Pedestal Stand Fan in Minutes with No Tools
18 Lasko Cyclone Oscillating Stand Fan model S18902 again
Lasko 18 fan review
Jun 05, 2016 | Lasko Dryers
Fan will not oscillate anymore. it makes a clicking noise like it's stuck
follow this steps and fix it. God bless you
f the fan doesn't work at all, make sure power is on at the outlet, then test the power cord . Test the motor and replace it if it is faulty. Clean and test the speed-control switch and service it if it is faulty . If the fan works on only some speeds, clean and test the speed-control switch .
If an oscillating fan doesn't move from side to side, check the clutch knob, then the gear assembly. If the gear assembly is faulty, you can service it (see below).
If the fan blades turn slowly, check the blades for a loose hub and tighten if needed. If the fan shaft is noisy or dry, lubricate it.
Nov 14, 2013 | Tower Aloha Breeze Fan
Oscillating table fan makes banging noise when rotating
mcdevito75 here, Sounds like that oscillating swtich is either a little loose or could use a drop or 2 of 3 in 1 oil. Try to twist offf the oscillating swatch button and see if you can tighten it or put a drop of oil on it.
Jul 24, 2010 | Holmes Products Holmes HASF1304S-UC 12",...
Can an oscillating fan be stopped from turning? It is made by Dayton and is 24"..................
I have a large shop/garage fan on a 4-foot stand. It has oscillation connection that can be loosened using a knurled thumb nut.
Dec 12, 2009 | Dayton Dryers
I own two Marvin Floor / Box Electric Fans. It's
its extremely simple... when it does that put your hand on the oscollator cover and hold it with light pressure for a couple seconds then let go. it should work
Jul 10, 2009 | Marvin Dryers
Internal Part's Guide for Model A0J-1201 fan
there will be a oscillation driving counter wheel present inside it which is made of plastic tat would have got damaged or broken so replace the wheel then ur fan will start oscillating
Jul 28, 2008 | Accutek AOJ-1601 Stand (Pedestal) Fan
Accutek stand fan just hums, won't turn
That means the bearings are dry and have locked. Simply open the motor cover by removing the screw and pull the oscillation knob by rocking it side by side gently to have free access to the motor.
MAKE SURE THE FAN IS UNPLUG FIRST. Use cream type grease on both ends of the shaft. After applying the grease rotate the blades until they're freely and you feel the blades have released.
Place the motor cover back and the oscillation knob and plug-in the fan. Leave it on HIGH for 10-minutes or more to make the rotor loose with the grease.
Jun 15, 2008 | Accutek AOJ-1601 Stand (Pedestal) Fan
LASKO fan problem
Check for a loose wire in the wiring harness
Sep 01, 2007 | Lasko 2530 Elite WindTower Fan
WeatherWorks CH-1850SFW Riviera Stand (Pedestal) Fan Logo
6,151 people viewed this question
Top WeatherWorks Dryers Experts
Marvin
Marvin
Craig Butler
Craig Butler
Are you a WeatherWorks Dryer Expert? Answer questions, earn points and help others
