Question about Zanussi Refrigerators
Zf56l zanussi fridge
Water is coming from under the fridge, NOT from inside it
catriver
  • 878 Answers
SOURCE: water dripping inside fridge
jeets, remove the bottom panel from the freezer by removing the 2 quarter inch screws up front. See if you have a sheet of ice under it. If you do, you probably have a frozen drain tube in back. When the unit goes into defrost the water is running down the air vents instead of the drain tube. If this is the case, you will have to remove the back panel in the freezer and clear the drain hole. Use hot water if it is frozen over....Catriver..post back.
Posted on Mar 15, 2007
SOURCE: WHERE IS THE WATER COMING FROM UNDER MY FRIDGE?
if you do a full defrost manuely, all the water on the evap. coil will melt and easily fill up the pan. Possibly door was not closed properly recently and there was a build up on the coil. Do a proper defrost and start again.
Posted on Aug 18, 2008
woodchuck789
  • 4066 Answers
SOURCE: Zanussi frost free fridge freezer leaking
Your drain tube may be stopped up with ice at the upper end because it drains too slow because it's stopped up at the lower end in the evaporator pan under the unit at the floor. It can get dust and mold in it. Once you get the ice out at the top a little pressure with a turkey baster will usually clear it out. Flushing it out with hot water and clorox may help. Make sure it drains quick enough to prevent refreezing. . The drain should be located below the evaporator coils on the lower back of the freezer.
Posted on Jul 01, 2009
toolkits
  • 1099 Answers
SOURCE: water dripping insie the fridge
Water accumulating on the ceiling of the refrigerator is usually caused by a clogged drain in the freezer section beneath the evaporator. The clogged drain will cause water from the self defrost cycle to leak into the divider between the freezer and refrigerator. This water may then freeze and cause condensation build-up on the refrigerator ceiling. The solution to this problem begins with unclogging the drain. It may also be necessary to remove the entire freezer/refrigerator divider to thoroughly dry the insulation in the divider. Occasionally the insulation needs to be replaced to prevent a recurrence of the problem. This can be a big job – you may want to hire a qualified appliance repair technician.
Posted on Jul 28, 2010
  • 1891 Answers
SOURCE: Leaks water inside fridge when
if this is a top mount freezer / the drain needs to be cleaned . it could be iced over or pluged with algi . hope this helps mm
Posted on Sep 01, 2010
Water runs down the inside back of the unit and freezes
Our fridge has a plastic hose running down the rear of the fridge and water was coming inside and running down inside the fridge walls and out the bottom of the door when we opened it. I called a repair man and he blew the plastic hose out and reinstalled it and had no trouble since. Our fridge has a water tray under neath the fridge that this hose is suppose to run into. The tray dries itself out so you don't have to empty it.
Mar 20, 2015 | Refrigerators
Zanussi frost free fridge freezer we have had two zanussi fridge free freezers in the past month that do not drain away the water from the fridge. The water builds up under the vegetable drawers and...
this is a common fault with them, when packing them some of the packaging blocks the pipe. if you use a net curtain thing that hold up the net curtain push it down the hole up and down a few times then look at the drain away at the bottom of the fridge take the bits out. should be fine then. it happen alot and to deferent makes and models.
Sep 16, 2013 | Refrigerators
We have got Zanussi Fridge/Freeze, water from the fridge area keeps running under the vegtable's drawer area, which I need to wipe/clean constantly.
Check that the little drain hole at the back is not clogged it sounds like this is the case,its easy to clean try something soft like a straw to push in to clear, Normally I get a mouthful of hot water and squirt this down the straw,Works well for me...Good luck.
Apr 04, 2011 | Zanussi Microwave Ovens
The fridge compartment was heavily iced on the back of the inside it has now stopped working both fridge and freezer compartments no longer work
The fan blower and/or heater assembly has failed leading to ice build up inside. However it could be more simple 'cos the drain from the freezer to the pan under the refrigerator is plugged up - most likely with ice. You can see this drain line behind the refrigerator. When the freezer goes through an automatic defrost this drain line is used to get the water out of the freezer. Try a thorough manual defrost to see if the line opens up - you will have quite a bit of water in the tray underneath and it might overflow. That is probably all you will have to do to fix this problem.
Basically three things to look for: clogged drain, bad defrost timer, bad mullion heater strip.
Dec 03, 2010 | Zanussi ZI918 / 12K Bottom Freezer...
I have a zanussi ZI 920/9K and the fridge has water under the salad drawer every day but the drain hole is not blocked - what else might it be?
two solutions
1...a door seal leak
2...you are puting food in that is warm or not covered and its the condensation from these that collects on the shinny surface of the salad drawer.....
remember,every time you open the door warm air from the kitchen replaces the cold air inside the fridge,it does not dry the air like a dehumidifier....
hence water droplets gather.....
Jul 05, 2010 | Zanussi ZI921 / 8FF Bottom Freezer...
Water drain
find where line comes out under fridge in pan and blow back through line with shop air. clean evap pan inside freezer by defrosting and cleaning pan.
Sep 24, 2009 | Refrigerators
Jul 01, 2009 | Refrigerators
Zanussi fridge /freezer
the drain located under the evap. maybe stopped up pour some boiling hot water into it and see if it drains underneath into the drain pan
May 06, 2009 | Zanussi ZEBF250W Bottom Freezer...
I have a zanussi fridge freezer combination, it is a frost free model, Im developing lots of frost in the freezer which never used to happen and the fridge is not getting cold, some condensation does...
Hello Mr Barnard
Welcome to fixya
You said, You have a zanussi fridge freezer combination, it is a frost free model, And you're developing lots of frost in the freezer which never used to happen and the fridge is not getting cold, some condensation does appear inside the fridge, it is 2years old.
Frost could mean a few things.
Is the freezer cold but the fridge not?
If so the freezer may be so full that the articles are covering the air vents in the back that share the cold air with the fridge.
I've have seen the freezers packed to the hilt!
More things to check.
Is the condenser in the back or under the front of the fridge. If it is under the front of the fridge you must remove the plastic grill`(The condenser is the thin black metal tubing that runs back and forth to make up your condenser). This needs to be free of dust and have air passing over and through it!
they sell refrigerator brushes for this at the hardware store.
I have had customers that never ran the brush under there ever and had 1 to 2 inches of dust and lint
under there between the tubes.After a few hours it was cool the next day it was cold!
The freon level pressure should be checked in case you have a leak.
The thermostat may be bad.
Let me know what works for you.
Huuum
Please remember to leave a rating!
Oct 05, 2008 | Refrigerators
LARGE WATER LEAK ON FLOOR
the reason is probably that the drain hole in the freezer (i assume this is a frost-free type) is blocked. take off the rear panel of the freezer and you will probably see a block of ice at the bottom. melt off with a hairdryer and free the drain with hot water making sure that water flows freely away
May 06, 2007 | Zanussi ZEBF250W Bottom Freezer...
Refrigerators Logo
16 people viewed this question
Top Zanussi Refrigerators Experts
Charles T Nevin
Charles T Nevin
Colin Stickland
Colin Stickland
Dan Webster
Dan Webster
Are you a Zanussi Refrigerator Expert? Answer questions, earn points and help others
