Question about Garden
John deere hd45
How to fix a belt on a john deere hd45
  • 83 Answers
SOURCE: belt broken on riding lawn mower (john Deere LT
http://jdpc.deere.com/jdpc/servlet/com.deere.u90490.partscatalog.view.servlets.HomePageServlet_Alt
This link will send you to the illustrated parts list on the john deere site. It shows the belt routing in the part diagram. Hope this solves your headache.
Posted on Mar 30, 2009
SOURCE: how to replace belt on john deere 425
take a sharpy and outline it before removing
Posted on Jul 19, 2009
SOURCE: Belt change on a hydrostatic 265 John Deere
Instructions for changing main drive belt on John Deere model 265
HELP !!!!!!!!!!!!!!!!!!
Posted on Aug 28, 2009
mowerman1857
  • 389 Answers
SOURCE: v-belt route installed on 48" deck of John Deere LA130
http://jdpc.deere.com/pimages/PU00/PU00859________UN28APR08.gif
Copy and paste this in your address bar and it should take you to a picture of how to route the belt
Posted on Sep 18, 2009
  • 66 Answers
SOURCE: L120 JOHN DEERE
There should be adjustments on the tie rod ends connecting to the front axles. Loosen set bolt, make the adjustment and re-tighten set bold.
Posted on May 30, 2010
I need a drive belt routing picture for a John Deere x300 mower
For a routing or installation diagram, contact John Deere directly.
Sep 11, 2017 | John Deere Garden
John deere model FC420
Specifications
Engine HD45
Engine Model Number(Kawasaki FC420V
Horsepower (10.5 kW (14 hp)
Displacement (423 cc (25.8 cu.in.)
Crankcase Capacity w/o oil filter (1.3 L (1.4 qt.)
Crankcase Capacity with oil filter (1.6 L (1.7 qt.)
Spark Plug-Gap (0.64 mm (0.025 in.)
Spark Plug-Torque (20 N·m (15 lb-ft.)
Cylinders (One
Stroke/Cycle (Four
Lubrication (Full-Pressure
Oil Filter (Standard Single Element
Air Cleaner (Dual Stage
Engine HD75
Engine Model Numbe(Kawasaki FC540V
Horsepower (12.7 kW (17 hp)
Displacement (535 cc (32.6 cu.in.)
Crankcase Capacity w/o oil filter (1.6 L (1.7 qt.)
Crankcase Capacity with oil filter (1.9 L (2.0 qt.)
Cylinders (One
Stroke/Cycle (Four
Fuel System
Fuel (See Fuel in the Service Miscellaneous section
Fuel Filter (Single Stage, 60 Micron
Fuel Pump (Vacuum Operated-Diaphragm
Fuel Delivery (Gravity Feed to Fuel Pump)
Fuel Tank Capacity (19 L (5.0 gal.)
Drive Train Mower Deck (36-inch)
Blades (2
Blade Bolt Torque (81 N·m (60 lb-ft.)
Cutting Heights (25-114 mm (1-41/2 in.)
Weight (86.7 Kg (191 lb)
Overall Width (chute up) (927 mm (36.5 in.)
Mower Deck (48-inch)
Blades (3
Blade Bolt Torque (68 N·m (50 lb-ft.)
Cutting Heights (25-127 mm (1-5 in.)
Weight (83.6 Kg (184 lb)
Overall Width (chute up) (1308 mm (51.5 in
ower Deck (54-inch)
Blades (3
Cutting Heights (25-127mm (1-5 in.)
Weight (86.7 Kg (187 lb)
Overall Width (chute up) (1460 mm (57.5 in.)
Recommended Lubricants
Engine Oil (John Deere PLUS-4
Grease (John Deere MOLY HIGH Temperature EP
Transmission Oil (HY-GARD-J20C (TURF-GARD-SAE10W-30 (PLUS-4-SAE10W-30 (TORQ-GARD SUPREME-SAE30
(Specifications and design subject to change without notice.)
Sep 28, 2016 | John Deere Garden
Belt routing diagram for a LTR 180 John Deere
Ian, John Deere LTR 180 Belt routing diagram. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
https://jdparts.deere.com/partsmkt/document/english/featbene/fb_MaintSheet_LTR180_42RearDischargedeckLawnTractor.pdf
https://groundscare.custhelp.com/app/answers/detail/a_id/264/~/mower-drive-belt-routing---170,-175,-180,-and-185
John Deere LTR 180 Belt routing diagram Google Search
Aug 14, 2016 | John Deere Garden
John Deere D105 Lawn Tractor will not go forward
does it go in reverse ??? if no, suspect the belt, or did you have the wheels off of it recently ??? if yes then still suspect the belt or a bad transmission
Nov 23, 2013 | John Deere Garden
How to change the Belt on a John Deere L130 with 48" mower deck? Is there a Belt diagragm that show proper routing?
Try the John Deere parts website https://jdparts.deere.com or give sullivans a call they are a john deere dealer and are garden machinery experts they will be able to explain to you what to do. you can find their contact info on their website http://www.sullivansgardenmachinery.co.uk
Sep 18, 2010 | John Deere Garden
Garden Logo
15 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
