Question about Konica Minolta Office Equipment & Supplies
Abort code 0x00f00201 - Konica Minolta Office Equipment & Supplies
2 Suggested Answers
paand
  • 147 Answers
SOURCE: what is code 0x00f00201
Your RAM is corrupt. It means machine memory is corrupt
Posted on Jul 01, 2009
Tip
COMMON FTP ERROR CODES
~~~~~~~~~COMMON FTP ERROR CODES~~~~~~~~~~
# Description
110 Restart marker reply. In this case, the text is exact and not left to the particular implementation; it must read: MARK yyyy = mmmm where yyyy is User-process data stream marker, and mmmm server's equivalent marker (note the spaces between markers and "=").
120 Service ready in nnn minutes.
125 Data connection already open; transfer starting.
150 File status okay; about to open data connection.
200 Command okay.
202 Command not implemented, superfluous at this site.
211 System status, or system help reply.
212 Directory status.
213 File status.
214 Help message.On how to use the server or the meaning of a particular non-standard command. This reply is useful only to the human user.
215 NAME system type. Where NAME is an official system name from the list in the Assigned Numbers document.
220 Service ready for new user.
221 Service closing control connection.
225 Data connection open; no transfer in progress.
226 Closing data connection. Requested file action successful (for example, file transfer or file abort).
227 Entering Passive Mode (h1,h2,h3,h4,p1,p2).
230 User logged in, proceed. Logged out if appropriate.
250 Requested file action okay, completed.
257 "PATHNAME" created.
331 User name okay, need password.
332 Need account for login.
350 Requested file action pending further information
421 Service not available, closing control connection.This may be a reply to any command if the service knows it must shut down.
425 Can't open data connection.
426 Connection closed; transfer aborted.
450 Requested file action not taken.
451 Requested action aborted. Local error in processing.
452 Requested action not taken. Insufficient storage space in system.File unavailable (e.g., file busy).
500 Syntax error, command unrecognized. This may include errors such as command line too long.
501 Syntax error in parameters or arguments.
502 Command not implemented.
503 Bad sequence of commands.
504 Command not implemented for that parameter.
530 Not logged in.
532 Need account for storing files.
550 Requested action not taken. File unavailable (e.g., file not found, no access).
551 Requested action aborted. Page type unknown.
552 Requested file action aborted. Exceeded storage allocation (for current directory or dataset).
553 Requested action not taken. File name not allowed.
on Dec 03, 2009 | Computers & Internet
Does anybody know how to overcome this error on a Konica Minolta c200? Also what does it mean?
Found on another site:
Re: C200 abort code 0x06006015
With abort codes a good place to start is always the MFBS board. Swap it it with a known good one and that will likely fix the problem
http://www.konicaminolta.com/
Found you a service manual:
https://www.google.com/url?sa=t&source=web&rct=j&ei=WWOSVIWYBtGvogT37IHoCg&url=http://www.manualslib.com/manual/90079/Konica-Minolta-C200.html&ved=0CCYQFjAE&usg=AFQjCNH61aztogU0Td0ShHkzwq_8fxzosA&sig2=b-NoLa6PfTCInqzptQkprw
Dec 16, 2014 | Office Equipment & Supplies
C-FE07 error on a Konica-Milolta C250
The machine displays an abort code CFXXXX on the control panel as it becomes unable to process tasks properly trough its software control.When the sistem program is aborted,check the electrical componenet,unit,option and connection to the specific type of the abort condition.
CFE07 - ASIC 10 timeout number of DMA under operation and transfer completion line=0:DMA_D.Relevant electrical componenets MFP control board.Try to reset:
Turn OFF the copier.
Press and keep pressed the Utility key and turn ON.
Keep pressed the Utility key while the Trouble reset message displayed.
Release the Utility key and touch the message and turn OFF the copier.
Wait 1 minutes and turn ON.
Apr 18, 2013 | Konica Minolta Office Equipment & Supplies
Wont boot up code 0x00f00201
Recommde that you have a tech come out look at it the abort code that what there are called when they look like that normally have to do with one of the circuit boards in the machine or the firmware the copier is running.
Feb 19, 2013 | Minolta DI-2010F Copier
Abort code
contact service use go to www.konicaminolta.com
Oct 06, 2012 | Genuine Konica Minolta Konica Minolta...
Can not shutdown /CPU fan allways working
Try the following command......
shutdown [-i | -l | -s | -r | -a] [-f] [-m \\computername] [-t xx] [-c "comment"] [-d up:xx:yy]
No args Display this message (same as -?) -i Display GUI interface, must be the first option -l Log off (cannot be used with -m option) -s Shutdown the computer -r Shutdown and restart the computer -a Abort a system shutdown -m \\computername Remote computer to shutdown/restart/abort -t xx Set timeout for shutdown to xx seconds -c "comment" Shutdown comment (maximum of 127 characters) -f Forces running applications to close without warning -d [u] [p]:xx:yy The reason code for the shutdown
u is the user code
p is a planned shutdown code
xx is the major reason code (positive integer less than 256)
yy is the minor reason code (positive integer less than 65536)
Do reply me if it sort out your prob
Sep 30, 2009 | Abit SG-71 Motherboard
What is code 0x00f00201
Jul 01, 2009 | Konica Minolta bizhub 350 All-In-One Laser...
Adobe 9 flash keeps running even after I abort it
Open up task manager by pressing CTRL+ALT+DEL, switch to processes tab, look for Flash, right click -> terminate.
Dec 08, 2008 | Adobe Photoshop 7.0 for PC
78 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Ben
Ben
David Burkhart
David Burkhart
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
