Simplicity air conditioner 43-5411-0 sac 5206
Fly get inside the house wen air c one
koolbreezes
  • 540 Answers
SOURCE: Goldstar Air conditioner
How old is this unit cause the drain pan back in the day , was made of metal and rust. also most of the time, the drain line get full of slime-bacterias -mold pluggs the line . Find the drain line tapp on this to unlodge sludge. If this is pvc pipe,try to introduce bleach into the system to kill the nasty(#$!@*&$'s) Thank-you- very -much!
Posted on Aug 23, 2008
  • 52 Answers
SOURCE: maytag M3X05F2AK air Conditioner -BLACK CHUNKS FLYING OUT
remove front cover and clean the coils off with a nylon brush. make sure filter is clean. with front cover off take it outside hook it to an extension cord and set it on the floor. then let it run till the stuff stops coming out. if you want to open the whole thing up you could clean it out even more example being the inside fan area behind the coils, but the first option should work.
Posted on Jun 10, 2009
  • 4 Answers
SOURCE: fan inside air conditioner won't turn on
there are many problems it could be. first off check the breaker box to make sure hasn't tripped. call 254-722-1891 for Dallas area A/C service.
Posted on Jun 18, 2009
SOURCE: Air Conditioner isn't making the house cold at all
My AC works great, cold air coming out of the vent (about 63*) intake working well also. (about 76* in the middle of the day)
Think it could be the insulation?
Posted on Jun 22, 2009
flatech
  • 111 Answers
SOURCE: TCL model tac 24chs/k air conditioner is leaking from the
You will want to remove the panel in front of the air handler, usually a few 5/16 screws.
Once open then with a flashlight look down inside where the water collects in the condensate drain pan.
Verify that the pan is not full of water or algae build up.
If it is, then attach a wet vac to your drain outside and while it is pulling on the drain line spray some water inside till it is fully clean.
If it is not full of water then check the pvc pipes that are attached to the drain pan, they may have came loose and may need to be teflon taped and reconnected to the pan. Also verify there are no cracks in the pan.
Lastly inspect the bottom of the evaporator coil (Not the top) pull out the filter and make sure the coil is clean or water could drip down past the pan into your dwelling. Make sure as well that the insulation on your panel that covers the unit is intact and not worn away.
Good Luck!
Posted on Nov 14, 2009
Need to fix leaking on my simplicity portable air conditioner 6077 and how the drain works
If it is water in a thru window installation you will need to tilt the unit up a little so the condensate water drips outside. I hope this helps! Thank you and please leave feedback.
Jul 11, 2016 | Heating & Cooling
Where can i get a manual for a Simplicity Spac7088 air conditioner ?
On the device itself, you should see a customer service number. They should be able to help you order a new one. If they don't offer it, you might be able to go to the manufacturer's website. They might be able to help.
Elisa Jed ' http://www.foxrefrigerationandair.com.au/commercial-and-industrial
Aug 03, 2014 | Heating & Cooling
Why is my appartment getting cooler ???
An air conditioner really just moves heat from one place to another. Normally there is an inside unit and an outside unit, or in the case of a window unit, half is inside the room and half outside the window. In either case, it takes the heat from in the room and moves it outside. This portable unit apparently takes the heat from one room and dumps it into another. There is no magic heat elimination - it has to go somewhere.
Jul 01, 2014 | Simplicity 6,000 BTU Portable Air...
Water leaking inside the house
The air conditioner should be mounted in such a way that there is a slight tilt outside to direct condensate away from the inside. Your air conditioner may be level or slightly tilted toward the inside. The installation instructions should have made this point clear
Aug 04, 2013 | Haier hwr10xc6 Air Conditioner
Danby sac-8400 D coming up with e 1
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Here is a tip that gives a further explanation of that E-1 code. The causes of the E-1 code can be varied depending or the brand of your air conditioner.
Read through this tip... it will help you understand what is happening with your window air conditioning unit and give you some things to try to help you get your problem resolved.
E-1 Code on Window Air Conditioning Units
heatman101
Sep 02, 2010 | Danby DPAC8020 Air Conditioner
Voltas vertis gold-i 1.5 sac manual required.
you can visityour nearest Voltas delarship and ask for the mannual or call the customer care for the mannual.
Mar 15, 2010 | LG L1204R Air Conditioner
I need to find a user manual for the proline sac 100 portable air conditioning unit
Check out ebay.co.uk and search for "Manual for Proline SAC 100E". I've seen manuals offered for sale on ebay.
Jun 11, 2009 | Heating & Cooling
Maytag M3X05F2AK air Conditioner -BLACK CHUNKS FLYING OUT
Jun 05, 2009 | Heating & Cooling
Heating & Cooling Logo
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
