Question about Samsung 4 Channel Dvr
Playback on Samsung SHR-1040
I am unable to playback anything I record, I get "NO DATA" on the screen.
  • Anonymous Feb 28, 2009
    Same here for mine,records but no data
You need a new hard drive.
Posted on Mar 21, 2009
SOURCE:
Samsung SHR-1040 Digital Video Recorder
it sound like the system is locked up or your hard drive is going bad. write down all the info on the unit and reset and reprogram the unit. this may solve your problem if not you my need to send it in for repair.
•Factory Reset Hidden Key :
Mode Key + CH 2
•The Password and all setting
value will return to the initial
default value.
•Default Password is ‘4321’ .
mj
May 18, 2009 | Samsung SHR-2082 8 Channel Stand Alone Dvr...
I changed the passwors of samsung shr-1040
Mode Key + CH 2
default value.
mj
Apr 08, 2009 | Samsung 4 Channel Dvr
Samsung shr-1040 playback is blocky
Sorry, but there is no way to turn off the compression. That is the just the way a quad works. It compresses the 4 video signals to 1 channel. The only way to get around it is to buy a 4 channel unit. 1 channel per camera.
Rob
Jan 24, 2009 | Samsung SHR-2082 8 Channel Stand Alone Dvr...
Trying to get hooked up
I made a hook up from the shr 1040 to a pc monitor using a VGA converter box. Cost less then 40 ( check amazon) and simple to use as well as still use your pc on your monitor,
Aug 27, 2008 | Samsung 4 Channel Dvr
Vidio recorder when i record it wont play back what is recorded but it will play pre recorded tapes Is it campatable for LG television please model no VR550/07
If it plays back pre recorded tapes then there is nothing wrong with that section of the unit. Does it playback audio and not picture or does it not playback anything.
Also, when trying to playback a recording what is seen of the screen? Snow(black and white dots or wiggly picture?
The unit uses two separate circuits to record and playback tapes. Is any thing else connected to the unit while you are recording? If you are using anything plugged into other ports on the recorder it may not see the camera input causing it to not record anything..
Feb 03, 2008 | Dishwashers
Search
Having the same problem. Just spoke to samsung [1-800-samsung] They told me to reboot and if it doesn't solve the problem would have to replace the hard drive. They said press mode, 4 and zoom all at the same time and hold for 12 seconds to reboot entire system. Use buttons on unit not remote. Didn't help mine, good luck with yours.
Oct 23, 2007 | Samsung 4 Channel Dvr
Connecting the recorder to the security system
If you are hooking your cameras into the SMO-151qn then you can use the pigtail cable to connect to the Shr-1040. Make sure the video out from the SMO-151qn goes into the video in of the Shr-1040. If there is a choice use CH1. On the Shr-1040 hold down the mode button and press CH2 for about 10 seconds. The Shr-1040 should reboot. Once it comes up press the record button. After recording for a feww minutes stop the recording. On the SMO-151qn press the button on the front Live/Vcr. You should see the screen from your Shr-1040. IF you hit play you should see what you recorded. Good Luck!
Jun 11, 2007 | Samsung SHR-2082 8 Channel Stand Alone Dvr...
Samsung 4 Channel Dvr Logo
284 people viewed this question
Top Samsung Home Security Experts
Bill
Level 1 Expert
JonSnell Electronic
JonSnell Electronic
Are you a Samsung Home Security Expert? Answer questions, earn points and help others
