Question about Lands Phones
Gigaset repair C300 crackling - Lands Phones
Hi, lost the caller ID on my Gigaset C300 since changing from BT to Vodafone who say it's been enabled- any suggestions please? UK
Does it pick up caller display on another phone? If it does, you may have a compatibility issue. If not, Vodaphone have not switched it on yet.
Feb 16, 2017 | BT Lands Phones
Where can I get manual for gigaset AS185H
Hi Val I found a free download for you
http://www.directutor.com/repair-user-manuals/SIEMENS-GIGASET-AS185-DUO-TRIO.PDF
Jul 07, 2016 | Lands Phones
I need a manaul for an AS300 Gigaset
User manual for this unit can be downloaded from this link, just click HERE.
Aug 12, 2011 | Siemens Gigaset C300 Quad Cordless Phone
Siemens sl30 phone wont charge. Just blinks the last part of the battery. When I turn on the speakerphone to dial the phone dies and shuts off. when regular dialing can hear crackling static
I have similar problem with my gigaset 4000 micro, i bought 600mah NiMh bettery and when I start charging it charges cca 3 min and displays that battery is full and it doesnt charge it any more. I can speak max 12 minutes and phone starts beeping that battery is empty. What should i do to make phone to charge this battery properly.
Aug 08, 2008 | Siemens Lands Phones
Problem Siemens Gigaset 4000 and 4200
You did get spiked from the power company, and your system needs repair. Go to www.cordlessrepair.com for help.
Jun 23, 2008 | Siemens Gigaset 4000 Phone
If you had a storm, and the only handset that works shows line in use, then your base has gone bad and needs repair. The reason the phones are flashing base 1 or something to that effect is because they don't see the base anymore, which typically means no phones will see your base, so its odd that one phone is actually seeing the base. Either way, you can try re-registering the phones to the base, but if you get the line in use after they register (if they will register), then your base is bad. If they won't register, your base is bad. For additional assistance you can go to www.cordlessrepair.com
Jun 15, 2008 | Lands Phones
Lands Phones Logo
Top Lands Phones Experts
David Burbee
David Burbee
Are you a Lands Phone Expert? Answer questions, earn points and help others
