Question about Garden
Craftsman 580.752060 replaced unloader valve and it worked for a while. but now there is low pressure again. What is next?
  • 174 Answers
SOURCE: clean and unloader valve on Karcher hd3500
Hi:
Cleaning it is not enough. You need to make sure the o-rings are in good shape and grease it with a very very good waterproof grease. Here is a schematic of the pump. The unloader is parts 7 to 13 on D-2
Posted on Sep 10, 2009
SOURCE: Unloader Valve - Karcher Pressure Washer
where is the unloader valve locaed on a Briggs Stratton pressure washer?
Posted on Oct 03, 2009
kel1guy2002
  • 3740 Answers
SOURCE: very low pressure after a few seconds
These pumps are notorious for seasonal problems.
Tip the unit to the point you can pour engine oil into the water inlet connection. What your attempting to do is free up the ball seats in the pump. They get corroded when they sit and lock in place. Adding the oil or a vast amount of WD 40 to the water inlet often does the trick for loosening up the seat balls and springs.
After you add the oil (3 - 4 ounces) or WD 40 to the water inlet line just slowly pull the engine through with the ignition switch off. As the water inlet cavitates add more oil.
Let it sit over night and then take a block of wood and a hammer and tap on the power head. Don't over do it and do it in such a manner your not going to shear off any bolts or break anything. But... be serious with the hammer and block of wood.
Then connect inlet water hose, the pressure hose and test the unit. You may want to purge the oil lubricant into a bucket before you start the engine.
Give it a try and see what happens. This works more often than you would think.
Thanks for using FixYa,
Kelly
Posted on May 04, 2010
Testimonial: "thanks I will try that it makes since because when I start it up I hold the trigger to relieve the pressure and have good pressure until I let go and the next I pull the trigger nothing but regular house pressure"
  • 404 Answers
SOURCE: Karcher G2600 VH - low water pressure
If the spill valve activates is "spills" water under the washer. There is a restriction or the pump has become inefficient and will not pump the volume and pressure it should at full RPM.
Posted on Jul 20, 2010
wmpcs
  • 100 Answers
SOURCE: I have a Karcher HD
Yes, the unloader needs to be lubed. Send me a email at justin@wmpcs.com with a discription of what you just listed and I will send you a pdf file on how to repair it.
Posted on Nov 01, 2010
Do the spring end caps inside the 315747GS unloader valve face the spring or the ends of the valve
This parts diagram for the pump should answer your question http://lawnandgarden.manualsonline.com/manuals/mfg/craftsman/580751651.html?p=22
Jun 08, 2014 | Craftsman 2500 PSI Briggs & Stratton...
Air compressor not unloading
Check the pressure switch. The unloader valve is actually in the pressure switch where the small air line from the tank check valve attaches to it. When the pressure switch turns the motor off it then lets the head pressure bleed off so the motor can restart the next time pressure drops in the tank. If it's not working and bleeding off the head pressure the cold start valve (the one with the pin in it) also won't open so the motor can restart and warn up properly.
Sep 09, 2012 | Dewalt D55153 1.1 HP Continuous 4 Gallon...
I have a vt631401aj campbell hausfeld compressor. when it builds pressure to 135 psi, the compressor shuts down and immediatly starts dumping air until it goes down to 90 psi. It then stops dumping the...
John: I had a similar problem with a brand new CH-made compressor. The problem was not with the unloader valve, but with the check valve located where the air from the pump enters the tank. The check valve was not seating correctly due to brass filings from manufacture. The defective check valve was allowing air to escape back the wrong way from the tank to the pressure switch and through the unloader valve. This backflow from the tank would start to happen when the pump stopped after reaching high pressure. The back flow would continue until the pump restarted at the low pressure point. This cycling would continue as you described. Once I cleaned the check valve, everything (including the unloader valve) started working correctly. I hope this helps. And remember, don't work on these when they are under pressure and always wear safety glasses.
Sep 18, 2011 | Campbell Hausfeld Air Tools & Compressors
I have a Craftsman compressor Model # 919-15292 2. The compressor stopped building pressure because air was continually being released through the unloader valve. I have replaced the unloader valve,...
you must have wired the new pressure switch incorrectly .when the pressure switch opens it will release the head pressure so your compressor must be running with the pressure switch contacts open should be 4 connections 2 marked motor which is from your compressor and 2 marked line which is your power coming in
Jun 15, 2011 | Craftsman 33 gal Air Compressor 6 hp...
I have craftsman 20 gallon five horse compressor. It pumps up to a certain psi and then it bleeds the pressure until it reaches a certain point and then pumps up again. The way its lets the pressure out...
The operation of that compressor is that the pressure switch will open when it reaches its set pressure, usually about 125 psi. when the switch opens and the motor comes to a stop the little valve on the side of the switch is meant to unload the pump head of pressure for the next start up. the pressure in the head and the tube leading to the tank is what is relieved, to prevent tank pressure leaking back there is a check valve where the discharge line enters the tank. what it sounds like is that check valve is not closing when the pump stops, and should be replaced.
Aug 26, 2010 | Craftsman 20 gal Horizontal Compressor
2.5hp 40ltr unloader prob?
Motor stalling during the fill cycle would indicate problems with the intank check valve, weak capacitor or low power to compressor. The unloader generally opens only when compressor reaches set pressure. Easy test. Unplug compressor with air in tank and remove the small airline at the checkvalve (brass valve in tank). Listen for air leak. Checkvalve is ok if no leak at brass valve. Test capacitor for 95% rated value. Replace as needed or test for low power. Good luck.
Jul 30, 2010 | Craftsman Air Tools & Compressors
25 gal horizontal craftsman air compressor is leaking at the pressure control valve. Can I replace the valve or repair it?
Unloader valve probably needs to be adjusted. Should be two jam nuts holding the unloader to the pressure switch. Loosen the jam nuts and adjust the unloader slightly away from the lever. Tighten the jam nuts and try it again.
May 21, 2010 | Air Tools & Compressors
Craftsman 1 HP 8 gal vertical compressor.919
Sounds like the unloader valve is not working properly. The unloader typically is at the end of a tube going to the pressure switch. The unloader is tripped when the pressure switch cuts off. The purpose of the unloader is to bleed the pressure from the cylinder when the compressor cuts off so the next time the compressor cuts on it will be starting in an unloaded condition.
when the compressor cuts off you should hear a discharge of air for about 3 to 5 seconds if the switch is working properly. The unloader can be adjusted if necessary by loosening the jam nuts and adjusting the unloader towards the lever on the pressure switch.
Apr 05, 2010 | Air Tools & Compressors
Compressor fly wheel not hung up unit starts operation soon fly wheel starts to slow down like it is laboring then stops and motor overloads and trips protection switch
It sounds like the unloader valve it not working correctly. The unloader valve bleeds off the pressure between the pump head and the tank check valve. Without it every time the compressor starts the piston would be working against the max tank pressure. This would cause what your describing. However when the unloader valve is not working the pump will shut off with in a couple seconds. If your pump is working longer then that I would guess that the unloader valve may be bleeding off some but not all the pressure.
On most smaller craftsman compressors the unloader valve is comprised of a piece of tubing running from the cylinder head or the check valve to the switch. At the switch you will see a plastic tip with a pin running to a small trip lever. Make sure that it's moving freely and moving through it's full range of motion. It's impossible to describe how this looks and feels to someone who has never messed with one of these.
After you have checked it and made sure it's working, if you still has trouble after this please let me know.
Oct 15, 2009 | Craftsman 3 gal. Air Compressor, 1.5 hp,...
Garden Logo
195 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
