Question about Boating
350 chevy misfiring
Just put new head gasket on motor from over heating heating. I also put thru the hull exhaust on . It idles at 650/700 but as soon as I it around 1000 rpm it starts to miss the higher the rpm get the more it as a miss. rebuilt carb turn dist. cap some times it will even backfire so now that the rebuild is on its still there
  • Pete Bolt Aug 07, 2013
    found out one of the heads were cracked. put new head on runs great . thank you for your input
    Top Expert:
  • Boating Master
  • 42,655 Answers
Check the ht wires for a crossed set check the firing order as there are two wires that out of sequence will cause this problem. To check firing sequence go to google and type in firing order for chev/gm 350 engine and it will give all the details.
Posted on Aug 07, 2013
2002 Chevy venture; just started showing that it was overheating; but this was just after I ironically filled it all the way with gas and put more oil in it, fluctuates a lot, from low to almost in the...
First if it is over heating check coolant level,if okay make sure there is no air in the system. Because of age of the car check for wiring issues like exposed wires at connectors that maybe grounding.
Feb 12, 2015 | Chevrolet Venture Cars & Trucks
Rough idle chevy 350
Have you checked/replaced the O2 sensor(s). They produce the data that your computer reads. Bad/clogged O2 sensors will trick the ECU into running lean/rich.
Aug 23, 2014 | 1990 Chevrolet C1500
have you check converter clug and o2 sensor
vacuum leak check leak with w40 or else
rotor,cap.quality of fuel
hope it helps
Aug 23, 2014 | 1990 Chevrolet K1500
How is there No coolant in car where is it going
Check your oil, you could have a blown gasket and it is going into the crankcase. If the stick is over the full mark, of if you let it drip onto a piece of plastic like a credit card or something and you see some bubbles or what looks like water droplet being displaced by the oil, you have a problem. Or if it looks foamy on the dipstick, as oil and water do not mix, they will separate or foam if the mixture has been churning in the motor for a while. If the car seem to run fairly decent, it could be a water pump gasket or intake manifold gasket if you do indeed find water in the oil.
Jul 21, 2014 | 2005 Mazda 6
2002 Buick Century Limited 3.1L rough idle and P305 code shows up
You have an interference motor. If you had to replace the heads due to the valves possibly touching the motor, you have to consider rechecking the compression after you replaced the heads. I had the same motor that had an intake leak. I found frozen rings on the number 1 piston as well as a bent pushrod. Ultimately, the camshaft had broken due to coolant getting to the bearings. If the spark is good, the fuel is good, then the only other problem you'd have would be compression.
Jan 13, 2014 | 2002 Buick Century
1979 chevy pick up 350 quadrajet4bbl engine fires idles in park ...put it indrive....dies help
could most certainly be compression will run fine under no load but when u put in gear load is applied and kills motor get some sort of additive just to diagnose the problem something that claims to increase compression. does it smoke at all? could also be losing compression from head gasket
Apr 02, 2010 | 1978 Chevrolet C1500
Hey Chevy Minivan heater dont work properly
Chevy made some weak intake gaskets on 3.1 and 3.4. My guess is that the intake gasket is weak and/or leaking and it is letting pressure out somewhere. At idle maybe the system pressure is to little to push hot coolant into the heater core.
Dec 21, 2009 | 2000 Chevrolet Venture
Steam and water coming out of my exhaust
Sounds like a cracked cyllinder head
Aug 25, 2009 | 1986 Mazda 626 Coupe
2003 saab 9-5 replaced head gasket because of overheat
disconnect computer and drive it ,if it drives ok then nothing wrong with it,after test drive put your hand held plug in gizmo under wheels and drive over it for what use it is.Skimmed head and new head bolts ?you must have more money than sense didnt you check it with a straight edge first??then clean it with a flat bed sander.head bolts ?? more expense .only expense should have been head gasket and antifreeze with a tube of instant gasket.Have you put all the little vac pipes back on that open the flaps on the air con and left the one off on the valve between the inlet and exhaust manifolds.Also did you remove and grind in the valves ??
Dec 19, 2008 | 2003 Saab 9-3
Boating Logo
67 people viewed this question
Top Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a Boating Expert? Answer questions, earn points and help others
