Canon ir5000 horizontal white line 4mm thick any suggestions about this problem
Ir 5000 canon
5 Suggested Answers
checkitright
  • 1362 Answers
SOURCE: printer prints white thick blank lines
1- black lines are from the drum: it has burnt out on that particular spot and rotates
2- the white horizontal gap space if it is not you skipping space is also from the drum
3-the white Vertical is most likely from the developper (unit that has the toner and is against the drum, look at the roller it should be solid black, maybe there is something on it : hair paper etc....
Posted on Aug 26, 2008
checkitright
  • 1362 Answers
SOURCE: Canon ir5000
assuming it is a black patch of toner, the drum blade needs changing or the waste toner mechanism needs to be looked at
Posted on Aug 27, 2008
MacD7
  • 67 Answers
SOURCE: put new black canon 3-e ink in canon Pixma ip 5000
The clean heads option should be in the Preferences/Maintenance tab where you go to do other things, e.g. alignment, ink counter reset, etc. If you cannot see this, you mmay need to reinstall the driver for the printer. You could also ask Canon. Finally, if the catridge is a refill or compatible, try a genuine Canon black cartridge.
Posted on Apr 25, 2010
  • 13 Answers
SOURCE: Canon Pixma MP620 problem. It
You probably need to run maintenance on the printer.
On the LCD do the following: (1)Select Settings on the HOME screen, and press the OK button. (2) Select Maintenance, and press the OK button. (3) Select Nozzle check pattern, and press the OK button. (4) Select Yes, and press the OK button. The nozzle check pattern will be printed and two pattern confirmation screens appear on the LCD.
This will tell you if the nozzles are out of alignment or not.Regardless you should not run the deep cleaning on the print heads. From the LCD do the following and make sure you have several sheets of paper in the printer;
(1) Select Settings on the HOME screen, and press the OK button. (2) Select Maintenance, and press the OK button. (3) Select Deep cleaning, and press the OK button. (4) Select Yes, and press the OK button. The machine starts cleaning the Print Head deeply. Do not perform any other operations until the machine completes the deep cleaning of the Print Head. This takes about 1 minute 30 seconds. (5) Select Yes, and press the OK button. The nozzle check pattern will be printed. (6) Check the nozzle check pattern. See Examining the Nozzle Check Pattern. - If a particular color is not printed properly, replace the ink tank of that color. See Replacing an Ink Tank. - If the problem is not resolved, turn off the power and clean the Print Head deeply again after 24 hours. - If the problem is still not resolved, the Print Head may be damaged. Contact your Canon service representative.
Posted on Mar 05, 2011
E599 error code on canon IR5000
I can't find anything about e599,here is your manual,you might want to call canon,I have spent too much time on it and am frustrated,sorry,there isn't much about that printer
http://downloads.canon.com/cpr/software/ir/PCLDRV_G.PDF
canon downloads, imageRUNNER 5000
Aug 09, 2012 | Office Equipment & Supplies
Whether Canon IR5000 printer can be a tool, through the com settings (data). how do I to connect the cable to the machine copies com IR5000.butuh lan similar devices or other connector?
If I understand what you are ask???? You need to know where the ethernet cable goes in to the copier?? The conector is above the main power switch on the right side of the copier.... The print funcation is a option with a IR-5000...... Do you have a ether net PCB installed???? If you do not, you need to get a new boot rom & more ram & the ether port and lastly, you need to have your hard drive flashed to print...... Good Luck
May 18, 2011 | Canon imageRUNNER 5000 Copier
Sisa toner di sekitar cleaning blade mesin canon ir 5000 mengeras apa penyebab dan solusinya
bagaimana cara mengatasi kode error 804 pada canon ir5000, lampu scanner kedip-kedip pada saat mesin start.
Nov 21, 2010 | Canon imageRUNNER 5000 Copier
Ir5000
sst itu Service Support Tool kl sm apa ya? kalo mau sst nih linkya
http://techchatter.servehttp.com/yabbse/index.php?topic=356.0
n nih frmware ir 5000-6000
http://rs147.rapidshare.com/files/197499533/__304_R5000-6000.rar
Feb 01, 2009 | Canon imageRUNNER 5000 Copier
Help me.....faster....
Errors commencing with E3---- means that something to do with the reader unit,,,, apart that error mentioned does not exist. If youhave plenty of parts that you can try out I will try to replace the reader board....
Dec 15, 2008 | Canon imageRUNNER 5000 Copier
Canon ir5000
Aug 27, 2008 | Canon imageRUNNER 5000 Copier
23 people viewed this question
jasbo
jasbo
