Question about Digital Audio Audio Players & Recorders
Koss hg857 The cassette player on this system speeds up the sound to make the songs really high pitched and annoying. How do I fix this problem?
    New Friend:
    Problem Solver:
  • 5 Answers
The unit probably has rubber belts, like mini fan belts that can stretch and wear out. I had a similar problem with a TEAC dual cassette. Good luck finding the parts.
Posted on Jul 12, 2013
5 Suggested Answers
SOURCE: high-pitched sound when using surround sound
I had the same problem, check your wires on the back of the tv and make sure your, red, yellow and white wires are in the correct holes. What kind of tv do you have, as I have an Ilo, and it has like 15 different plugs in the back, you may have to get you book out and make sure you have it in the correct hole on the back of the tv... I hope this helps....
Posted on Jan 11, 2009
SOURCE: Philips Home Theater - Annoying high pitch sound while on standby
I have the same problem with the same model, so obviously it's not a single-unit problem. My only solution, since taking it back isn't feasible at this point, is to have a DVD on play-pause so that it's not on standby. Waste of energy, so I don't do it all the time, only when I'm sitting in the room late at night making the high-pitched noise hard to ignore.
Posted on May 06, 2010
SD Tech
  • 14553 Answers
SOURCE: What's your problem?need power cord for my Koss HG835 Radio
Google the model number to see if you can find a "power cord" but it should be generic enough some electronics shops will have one.
Posted on Jun 15, 2012
kmt_52
  • 13 Answers
SOURCE: LG ht 303 no sound, internal high pitch sound
Search on Google its Good sarch Engine.Try It after cant solve than post on this sites .Ok//
Posted on Jul 29, 2012
Ii need Instructions for a Koss Remote Control HG857 for a RADIO
If you wish to get more; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. One among it has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily.
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Search the site by type in the brand name of your device, in the "Search box at the top right of the Home page display" to see the set-up codes to your device, with different brand remote controls.
Nov 15, 2015 | Koss Remote Control HG857 p/n:HG857
No sound, but high pitch noise
Sounds like a bad RCA connection
Jan 21, 2013 | Koss KS3102 System
Apr 17, 2010 | Philips HTS-3555 System
Can I record from a cassette player to the koss
should be able to go directly from tape out of cass deck to input of your koss, as long it has line level inputs (which it should). from there its play on the tape and record on the cd rcrdr. seems the simplest solution
Jan 30, 2010 | Koss CDR200 2-Disc CD Recorder
1991 Ford 350 truck, in dash cassette player high pitch noise
Hi rayc
sounds like the motor that pulls the tape mechanism is probably about to give problems and is getting electronically noisy. The cb may need to hooked up some where else to power so you get away from dirty power as well as maybe move the cb farther away from the tape player. hope this helps.
Ray
Aug 31, 2009 | Maxon MCB-40 40-Channels Handheld CB Radio
Sony Walkman cassette tape player operating at slower speed
If this is the WMD6C then it is servo locked and can be fine tuned with the pitch control on the back of the unit just turn the switch to on then adjust to preferred speed.
Dave, Electronic Doctors email eledocs@hotmail.com
Mar 31, 2009 | Sony Walkman WM-D6C Personal Cassette...
Tascam portastudo 414
Hi musicman
Anything you recorded with the old belt/c90 may have been recorded slow, so now that you have replaced the belt, it will play back fast. Couple of questions that may help sort things totally for you...
  1. How do recordings you have made since changing the belt sound.
  2. does the pitch control pot have any effect at all?
  3. what is the pinch roller condition like-it should be nice and flat with no raised bits across its width.
If the pinch roller is worn, you may have poor speed regulation problems with the unit and it will need to be replaced. I have fixed heaps of these over the years and not had any pitch pots fail. If it has issues, it may just need a careful squirt of CRC 2-26 into it to clean up its action a bit. Disconnecting it may well cause the unit to run flat out or at low speed so I Don't recommend that. These days, any metal or chrome tape(high bias) you can get will do, tape is getting hard to find :) Normal bias will not sound as good, and you may get some bleed problems between channels. Dont be too concerned about it being a 60 but I Dont recommend a 90 as the tape starts to get real thin, and pinch roller control(speed regulation) becomes an issue. This may even be affecting you here. Happy to talk it up further with you. A FixYa is an excellent reward for my efforts to help you out. Cheers
regards
robotek
May 12, 2008 | Tascam Starter Pack for 4-Track Cassette...
29 people viewed this question
Top Digital Audio Audio Players & Recorders Experts
Terry Hair
Tom Chichester
Are you a Digital Audio Audio Player and Recorder Expert? Answer questions, earn points and help others
