Lamona HJA 8704
When I pressed the open door button on my machine, it went much further in than it is meant to, and is now stuck in a depressed position. I cannot open the door. What should I do? Is it possible to repair it?
4 Suggested Answers
  • 6277 Answers
SOURCE: Lamona Washing Machine HJA 8514 Half way through a
(no promises but try this!)
I would gently suggest as a first step that you clean the drain motor/pump lint tray/filter. So many 'faults' are caused by blocked filters and many machines will not even go to rinse or spin or release the door lock if there is any water still left inside.
Following are my complete and generic guidance notes for checking both the drain motor filter and the drain motor ;-0)
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT (alternatively use a wet vac as sensibly suggested by VinnyB1234!)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!). These panels are either held on by (plasic) screws or will just pull off. Most filters are held in by a round cover/knob. Sometimes the filter will not come out with the cover and you will have to persuade it to come out to play.
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. Using something suitable like a glove see if it is easy to briefly slow the motor down. If it is easy then the motor is malfunctioning.
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
Posted on Jul 27, 2011
SOURCE: My Lamona integrated washing machine
Hi Guys,
My Lamona washing machine is also stuck on rapid wash? Dis you get it resolved?
Kind Regards
Posted on Sep 02, 2011
SOURCE: I was using my Lamona
Hi Karl
Did you get this issue resolved as I have the same problem?
Cheers
Posted on Oct 02, 2011
How do you remove and adjust the oven door to sit squarely on the rubber seal Its a Lamona HJA 3220
open door half way,pull out on the door,it will slide off the hinges
May 09, 2015 | Ovens
Lamona hja8630
How do I remove the integrated door af a lamona hja 8630
Jan 01, 2014 | Dishwashers
Have misplaced manual for lamona washer dryer HJA 8704. How do I find the setting for tumble drying only
I have scanned my HJA 8704 Manual and put it here
https://docs.google.com/open?id=0By3DbWv5t3T-WHR4OGJMMkZ5Tk0
Jun 21, 2011 | Dryers
Washing Machines Logo
Top Washing Machines Experts
