Question about Logitech 2.1 Speaker System Z313
Z313 speakers no sound
I have the Z313 3 piece speaker set plugged into wall and the cord (green coded) into the plug hole in back of my hard drive (green) but I get no sound can you help me set up in my control panel?
2 Suggested Answers
bronk50
  • 27725 Answers
SOURCE: connected up z313 speakers. have
if your computer came with a motherboard disc the sound drivers could be on it
you might have to uninstall then restart your computer then reinstall both the sound drivers and the sound card make sure you have both of these devices backed up to a disc before uninstalling
a yellow? question mark means you need to install/update driver to do this
right click to install driver also
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question mark? Right click to reinstall drivers
click start control panel sounds and audio,volume,advanced,speakers select appropriate speakers also audio you will find 3 drop down lists make sure you have the correct settings there
also
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar
if his does not fix the problem
have you tried this control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable)
hope this helps
Posted on Jan 31, 2011
Logitech Z313 Sound System Failure
On the basis of your description, you can conclude that your Logitech speaker system has failed.
Mar 18, 2014 | Sun -115H Computer Speakers
Logitech Z313 Speakers stopped producing sound, I have tried playing music, the green bar showing music is moving (under the speaker button on windows 7), but the speakers are not giving off a sound.
Pretty much the same happened to me. There are two wires coming from the wired remote control. One has a green plug which plugs into your sound system (computer sound) and the other connects to the Sub Woofer assembly. Feel this later cable for a harden section. It will probably be closer to the Subwoofer, but may be anywhere along it. This cable will have been cooked by overheating (Playing sound at full volume for over long periods of time.) . You will feel probably a 6" to1' section that is a tad stiffer and the plastic will crumble. You will need to cut a few inches into the normal cable and remove the bad section. Then strip and tin, the cables and connect them individually . Connect (tin, solder and seal them individually: ground to ground, white to white, red to red, blue to blue, green to green, purple to purple). Depending on the electrical tape you use- there will be a thick bulge in the cord, but it should work fine... or you can connect the severed cable to the original source to avoid the bulge ... but I did not want to shorten my remote any more than I had to.
Aug 26, 2013 | Logitech Z313
How do i hook up logitech speakers #z313 to my desktop i need a diagram
Phone jack on woofer goes into computer tower (should be color coded green) and power cable on woofer plugs into 120VAC. Speaker phone jack plugs into back of woofer. The speaker cable has an on-off switch and volume control as well as a phone jack for your headset.
Nov 14, 2012 | Logitech SPEAKER SYSTEM Z313 PC Multimedia...
Z313 no sound
Phone plug on subwoofer plugs into phone jack on back of tower! Plug and jack are color coded green. If you plug into wrong jack you get no sound or intermittent sound. Also speaker cables have an on-off swith so make sure you are switched "on" or you will not get sound.
Oct 30, 2012 | Logitech SPEAKER SYSTEM Z313 PC Multimedia...
My desktop cannot activate audio to the speaker
Are your speakers powered meaning do they plug in to the wall or have batteries? If the answer is yes look down at your task bar do you have a small picture of a speaker down at the bottom right hand corner. If so double click it and check your settings. also make sure your speaker jack is plugged into the green hole in the back most sound cards use light green as the speaker out jack.
May 04, 2011 | Computers & Internet
I have harman kardon speakers and I cannot figure how to connect with my computers, both desk top or laptop. There are two speakers with a cable with a light green plub and another plug that has me...
The green plug needs to be plugged in into either a green jack at the back of your computer or into your laptops earphone jack. And if the second cord is a USB cord then plug it into a USB port. If it is a power cord then plug it into a wall socket.
Mar 12, 2011 | Computers & Internet
Dell speaker connection color code needed
  • *Turn off your Dell laptop.
    *Connect speakers to the speaker control box. The speaker control box varies depending on the speaker system you have. Two-speaker systems will have a female jack on the back of one speaker that you plug the other into the second speaker. If your system has a sub-woofer, all of the other speakers will plug into it. The connecting cords are color-coded to the jacks on the back of the control box.
    *Plug an audio cable into the "Audio-In" port on the back of the control box. If the audio cable is color-coded, it will be green.
    *Plug the other end of the audio cable into the headphone jack on your laptop.
    *Plug the speakers' power cord into a surge protector to protect your system from power surges. *Plug the surge protector into a wall outlet.
    *Turn on your speakers and set the volume at a medium level. Be prepared to turn the volume up or down after you turn your laptop on.
    *Turn on your laptop and confirm that sound is coming from your speakers.
    Thanks for rating
    Good luck
  • Jan 25, 2011 | Dell Dimension 4600 PC Desktop
    I am a computer dummy...How to I connect speakers for sound like music in my computer?
    The end of your speakers should have a green plug, on the back of your computer there is a green port. Insert the green plug into the green port. If you have a power cord for your speakers you need to plug that into the wall.
    Please rate my answer, and good luck.
    Jan 20, 2009 | Computers & Internet
    No sound
    u have to plug the speaker in green hole only.
    Sep 02, 2008 | HP JBL Platinum Computer Speakers
    Logitech 2.1 Speaker System Z313 Logo
    21 people viewed this question
    Top Logitech Audio Players & Recorders Experts
    Michial Gueffroy
    Jerry Umali
    Are you a Logitech Audio Player and Recorder Expert? Answer questions, earn points and help others
