Question about Microtek ScanMaker 9800XL Flatbed Scanner
Error code : -180 - Microtek ScanMaker 9800XL Flatbed Scanner
Master reset code Taskalfa 180
Kyocera mita task alfa 1800..error code 0800
Jan 18, 2012 | Kyocera TASKalfa 180 Copier
My kyocera taskalfa 180 showing c6400 error please help.
C6400 is a fixing unit error.
To reset -
Try this, enter "10871087" from keypad, You should now be in maintenance mode.
Enter "163"press "Start / Print" key.
You should see a screen that says "Execute".
Cursor / highlight "Execute".
Press "Start / Print key.
The machine will turn off and should come back to ready. If not then you need to replace the fixing unit.
I hope this is helpful,
Shawn
Feb 25, 2011 | Kyocera TASKalfa 180 Copier
I´m P-08 code
Code P8
Error detail Abnormality of pipe temperature.
Inspected unit Indoor.
Due to short of gas/evaporator & air filter blocked/less rpm of blower motor.
Remedy: Find leak and arrest and do gas charging/clean filter & coil/replace B.Motor capacitor.
Jan 03, 2011 | Mitsubishi Mr. Slim MXZ30TN Air...
Free service manual with code for kyocera TASKalfa 180
Pls. send Free service manual with code for kyocera TASKalfa 180.
My email itechf2@gmail.com
Especially interisuet off hibernation.
Aug 05, 2010 | Kyocera TASKalfa 180 Copier
Canon IR 3100cn Copier Error Code E00002-12
E002 Insufficient temperature rise of the fixing unit
0002 The non-contact thermistor fails to
reach 70 deg C within 180 sec after
reaching 50 deg C.
Check on connection of the thermistor, Replace the
fixing unit
To recover from the error: In service mode ( * 2 8 * )
COPIER>FUNCTION>CLEAR >ERR
0003 The non-contact thermistor fails to
reach 100 deg C within 180 sec after
reaching 70 deg C.
0004 The non-contact thermistor fails to
reach 120 deg C within 180 sec after
reaching 100 deg C.
0005 The non-contact thermistor fails to
reach 140 deg C within 180 sec after
reaching 120 deg C.
0006 The non-contact thermistor fails to
reach 160 deg C within 180 sec after
reaching 140 deg C.
0007 The non-contact thermistor fails to
reach 180 deg C within 180 sec after
reaching 160 deg C.
0008 The non-contact thermistor fails to
reach standby temperature (normally
190 deg C) within 180 sec after reaching
180 deg C.
0101 The non-contact thermistor fails to
reach 120 deg C within 300 sec after
power-on.
0102 The non-contact thermistor fails to
190 deg C) within 300 sec after reaching
120 deg C.
Jun 06, 2010 | Canon iRC3100 Printer
Code error -180
Check your USB cable.  I was getting the exact same error and I found out I was using an older USB 1.0 spec cable.  When I switched to a USB 2 cable it began working fine.
Todd
Oct 27, 2008 | Microtek ScanMaker 9800XL Flatbed Scanner
Microtek ScanMaker 9800XL Flatbed Scanner Logo
Top Microtek Office Equipment & Supplies Experts
Tony
shelmnot
Are you a Microtek Office Equipment and Supply Expert? Answer questions, earn points and help others
