Question about Garden
Leak in pressure washer system
Have a leak in the water pump of my pressure washer simoniz s1500 - 39-8655-4
SOURCE: Simoniz S1400 Electric Pressure Washer
try momarch
Posted on Jul 01, 2008
  • 33 Answers
SOURCE: water leaks out at water pump and i just replaced the o-ring
you may have cut o ring when you replaced. coat with vaseline next time before assembly.
Posted on Apr 21, 2009
  • 174 Answers
SOURCE: Troy Bilt pressure washer model 020209 will not
A leaking gun will kill all the pressure. You may need to repair or replace the gun
Posted on Sep 17, 2009
SOURCE: Where is the pressure switch located on a simoniz
There is a pressure switch to cut the motor once target pressure is reached. I.e. when the nozzle is closed. It's a black cheap plastic thing, right in front of the pump body. It has a white plastic lever to trip the switch. It was sticking intermittently on mine. the simoniz 1600 is quite a cheap peace of ****, needs fiddling around every time I use it
Posted on Apr 29, 2010
SOURCE: I would like to take apart my Simoniz pressure Washer
I have simoniz 1750 less than 2 years old it works,no leaks,but water is not coming out ,thank you for any tip.
Posted on May 02, 2010
Motor runs but not alot of pressure
Make sure you re-leave any stored water pressure before performing a repair! (UNPLUG THE HYDRO OR DISCONNECT THE SPARK PLUG) SAFETY FIRST Valve 200344GS Order now for same day shipping 365 day return policy... If you can find these parts within the pump body they are probably being held open by calcification debris. http://www.simoniz.ca/en/images/support_buttons/general_pw_troubleshooting.pdf
Apr 13, 2014 | Karcher 1750 psi Electric Pressure Washer
Simoniz wand
Pressure washer use special ORINGS not the round ones and a high pressure stream of water will cut skin! Did you purchase the oring from a simonize dealer or a box store?
Apr 04, 2014 | Garden
Gun leaking when i use my simoniz 1900 pressure washer
The simoniz 1900 gun is very poorly designed. It is held together by a dozen small screws.
First open the gun by taking all the small screws out. No worries, it is much more simpler and worse constructed than a 5-year-old toy gun.
After opening the gun, you will see there are only two parts inside. One at the front connecting to the wand, and one at the back connecting to the hose. The trigger is looped over the joint part.
Make sure the back part is firmly fitted into the slot properly, otherwise it leaks. And be careful don't lose the spring, because there is no object to hold it in place.
Now all you need to do is to put all one dozen small screws back in. Don't over tight the screws, otherwise they will punch through the plastic cover.
Now your simoniz 1900 gun is fixed but it leaves you wonder which 10-year-old designed it?
Jul 30, 2012 | Honda Water Pump 2 Inch IntakeOutlet 5 Hp...
Mar 31, 2010 | Garden
Where is the pressure switch located on a simoniz 1600 electric power washer?
Sep 16, 2009 | Coleman Powermate DuraBuilt 1400 PSI...
I have a Simoniz 1900 presure washer and had to take it apart to fix it. I need to know how to put it together again as it has been awhile since I have had a chance to work on it. Can anyone tell me how to...
i took my pressurewasher simoniz s1900 apart, i had to take off the pump and all oil leaked out.
how and where can i fill the oil in to the pump
and what type of oil would i use
thanx ernte
May 17, 2009 | Garden
Looking for Owners Manual for Simoniz S2600
Hi my simoniz electrc power washer will not go off when I release the trigger , leaks trough the water inlet hose , I replaced the O rings but keeps leaking ..THANKS
Apr 21, 2009 | Garden
Simoniz s1900 electric power washer with no water pressure
What a jacka$$ response.
Do you think its the seals? wow that describes f**Kall!!!
Aug 19, 2008 | Electrical Supplies
Garden Logo
117 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
