Question about Toshiba 27DF46 27" TV
Brown spot in picture
My 1-year old Toshiba 27DF46 has had a brown spot or brown patch in the upper left corner of the picture for some time. The spot is most noticable against light colored backgrounds. I had called a local repair shop and described the problem to them in the hopes of getting it fixed under the warranty period and I was told there wasn't much they could do to fix it. No lie, that's what they said. Any ideas on what the problem is and how to fix it? Other than the spot, the picture is pretty good. Thanks.
  • 45 Answers
You might have a couple of dry joints, and you might also have a bad PTC inside that degauses the screen when tv starts up. Please try another good tech for a service. Patrick
Posted on Aug 27, 2007
How to Crimping Network Cables
Tools and Materials You Will Need
Crimper with RJ-45 die.
Wire stripper
Wire cutter
RJ-45 plugs
Cat-5 UTP cable
Optional Tools
Wire Tester
1. Strip off insulation
2. Untangle wires
3. Place wires in correct order &
4. Trim wires to desired length.
If the wires are too long the plug will not
crimp onto the insulation for strength.
5. Slide wires all the way into the plug.
Make sure not to disrupt the color
6. Crimp plug.
7. Repeat steps 1-6 for the other end.
8. Test wire using optional test equipment
or between working computer and hub
for patch (straight through) cables ,or
between switches for crossover cables.
Wire Color Scheme
Pin Color Diagram
1. Orange / White
2. Orange
3. Green / White
4. Blue
5. Blue / White
6. Green
7. Brown / White
Patch Cable
(Straight Through)
Both ends follow this
8. Brown
Pin Color Diagram
1. Green / White
2. Green
3. Orange / White
4. Blue
5. Blue / White
6. Orange
7. Brown / White
Crossover Cable
One end as a patch cable
and the other as follows
8. Brown
on Dec 08, 2009 | Computers & Internet
Looking fo wiring diagram for harness from pioneer deh- 2800mp to 1999 dodge dakota
Hello my name is Israel and I will be glad to help you. Please be sure to rate the solution. Good Luck. The diagram for the 99 Dodge Dakota:
Constant 12V+ Red/Blue Switched 12V+ Red/White Ground n/a Illumination Black/Yellow Dimmer Orange Antenna Right Front Front Speakers 6 1/2" Doors Left Front (+) Dark Green Left Front (-) Brown/Red Right Front (+) Brown/Yellow Right Front (-) Brown/Light Blue Rear Speakers 5 1/4" Rear Corners Left Rear (+) White Left Rear (-) Dark Blue/Red Right Rear (+) Brown/White Right Rear (-) Brown/Orange
This is for the stereo:
Sep 13, 2011 | Pioneer DEH-2800MP CD Player
I Have a Toshiba 27DF46 The Picture is shifted to the right about 3 inches or so. other than that the picture is fine but I can't see the right edge on the picture. Any thoughts
Try going into the picture settings in the options. Many Toshiba TVs have the option to move the picture up, down, left, and right. See if you are able to position the TV to the left more.
Also, see if there is a reset button in the options. A setting may have been switched that caused this.
Mar 02, 2011 | Toshiba 27DF46 27" TV
I need the wiring colour codes for 2002 santa fe car stereo
Basically the wiring of the large harness corresponds to the pins like this.
Starting in the upper right hand corner and working down the right side from A12 down to A1.
1=Left rear output-red
2=Left rear output-blue
3=Right rear output-black
4=Right rear output-yellow
6=Left front input-black
7=Left front input-yellow
8=Left rear input-orange
9=Left rear input-green
10=Amp 'ON'-blue&orange
12=Amp sensor-black&orange
Back up to upper left hand corner on the large plug
13=Right front tweeter output-red
14=Right front tweeter output-blue
15=Left front tweet output-red
16=Left front tweeter output-blue
18=Right front input-red
19=Right front input-white
20=Right rear input-blue
21=Right rear input-red
23=Right front sub (+) output-yellow
24=Right front sub (-) output-black
The small harness is the same above with the upper right position being pin 1 going down to pin 4 then back up to the top for pin 5 down to pin 8.
1=Memory Power-Lrg White
2=Amp Ground- Lrg Black
3=Left front sub (+)output-yellow
4=Left front sub (-) output-black
5=Left front mid (+) output-white
6=Left front mid (-) output-brown
7=Right front mid (-)output-brown
8=Right front mid (+) output-white
Hope this will help you.
Thank you
Jan 04, 2011 | 2002 Hyundai Santa Fe
LG washer - loud noises & brown spots on clothes.
The drum bearing has perished this wild cause the noise and the brown spots on your clothes is probably the grease from the bearing
May 05, 2017 | LG WM2077CW Laundry XL Front Load...
5 year old RCA 50 inch projection tv. Picture went off.
If you are using component cables make sure they are all connected properly( pushed all the way in and in the correct input). I have seen the red cable come loose several times and cause no red color in the picture. When you change the lamp it is easy to pull on one of those cables and cause it to come loose.
Jan 30, 2009 | Toshiba 50H72 50" Rear Projection...
No picture No sound
how did you remove the stand attached to the tv? But i have heard of this happening before too..They tend to just die..
Dec 23, 2008 | TruTech PM1919BXA1 19 in. LCD TV
Blue snowy pixel areas on my plasma
some of these panels were mis-calibrated from the factory after not aging long enough. Let the TV run for atleast 2 hours and adjust the Vs and Vscan voltages. When it is blue in the left I have found generally the Vs is about 10 volts too high.
Jun 16, 2007 | Samsung SP-R4232 42 in. Plasma HDTV
Toshiba 27DF46 27" TV Logo
77 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
