Question about Dryers
Maytag Neptune electric dryer 63407280 B
The panel has no lights and dryer will not operate.
Illeagle
  • 525 Answers
SOURCE: maytag neptune electric dryer
Warning! Disconnect power before servicing!
1.Open the door and remove the screws holding the door, then pull outward on the door to disengage the hinges.
2, Remove the screws on the opposite side of the door opening.
3. Pull outward on the lower part of the front panel to disengage from the top.
4. Remove the screw from the top left and right corner top retainer bracket.
5. Rotate the retainer brackets toward each other to disengage the top from the side panels.
6. Lift top.
Posted on Jun 03, 2008
SOURCE: How to remove a back panel of maytag neptune dryer?
Catriver was right on the mark. Took a little bit of doing but I was able to fix the problem myself within 30 mins, and saved some money. Many thanks. I'd like to expand Catriver's solution a bit.
I found a layer of lint on the inside bottom of my dryer. With the face off of the dryer, it proved to be a good time to vacuum the lint out and reduce the potential of fire.
Posted on Sep 07, 2008
TheMobilian
  • 8220 Answers
SOURCE: Can the Maytag Neptune Gas dryer converted to electric?
A gas dryer is dedicated to the use of gas to supply its heating function. It works on 125 volts. No way can a gas dryer become an electric one. UNLESS!
you just want to hang out yer clothes under the sun and use the dryer as a way to fluuf up yer clothes OR you could place the dryer into a box and make a condenser dryer out of it. Like cool hand luke you will toss that dryer into a rigid metal box in direct sunlight so that it can be an unbearable 140 degree up in there. then grab yer clothes and toss em in there and close that tar paer lined tin box up my friend.Let the sun do its thang. I think i just invent the redneck dryer! we don't need no stinking gas. Green power to the people! LOL
Posted on Apr 08, 2009
  • 351 Answers
SOURCE: Maytag Neptune Dryer smells like burning rubber or plastic...
could be the board, could be a motor, could be a belt but i would run it intill something just stops or try your best to take it apart and look through things and see if you can see an indication.
Posted on May 09, 2009
milten1
  • 1304 Answers
SOURCE: Maytag Neptune Dryer Won't Heat up
these particular dryers have issues with the heat coils,
it probably has a bad element
Posted on Oct 03, 2009
I have a Electrolux EDV 605 dryer all lights on panel are operating but dryer is not working
I have fixed a lot of these Dryers with that same problem.
The control board needs three relays to be replaced.
You need to get the same type relays.
Aug 04, 2017 | Electrolux Dryers
My dryer ran through the dryer cycle turned off. Hours later I noticed the "control locked" light is on and the dryer will not even light up to set program.
Hello. I really need the make/model number to help you accurately. However, depending on the model dryer you have, look on the control panel for a button or buttons that have a "key" symbol or the word "lock" underneath. Normally, you would hold the button down for 3-5 seconds until the lock light goes out. This is the indication that the control panel is unlocked and normal operation can be initiated. The manufacturers put a panel-lock feature on the units to prevent "busy little hands" or others from changing settings, for unattended safety, etc. Dishwashers, ovens, ranges, and other appliances also have locks for the control panel. If your dryer initiated a control lock by itself, this would indicate a shorted button on the control panel--soft touch buttons and glass touch-control panels are notorious for doing this. If I have the model number, I can usually provide the part number and/or procedure for getting into diagnostic mode to see any stored error codes(if any) which would help pinpoint a problem. I hope I helped you!
Oct 03, 2015 | Dryers
Wires fried at connection with dryer. Interior light works but no panel lights
You are lucky it didn't catch fire. Replace block and and put fresh terminals and connections.
Feb 20, 2013 | Maytag Neptune MDE5500AY Electric Dryer
The interior light will light BUT the control panel will not light to operate the dryer. What is the problem????
The Drum Light is powered by L2 The Display and Motor are powered by L1 Visually inspect the Terminal Strip and check to see if all the Nuts are tight. If the terminal looks good, you will need to replace the control board.
Sep 28, 2011 | Maytag Neptune MDE5500AY Electric Dryer
Kenmore Dryer light comes on but control panel not operating
Your thermal-fuse is located on the back side of the bulkhead upper right hand cornerb68bc9a.jpg
Electrolux family of dryers newer models Dryer Service manual
I have repair photos and more HERE
Jun 15, 2010 | Dryers
Control Panel Kenmor Elite HE4
that sounds weird to have all those lights on...
first thing is to try and remove the "lock"light...
push and hold the button, for 5 seconds, below the "lock" light,
that should get the control back to normal operation. then if you still cant get the unit to turn on, try to unplug the dryer for a few minutes.
if you still cant get it to turn back on, call sears "customer service" and complain since your machine should not have failed at this early in its life.
Sep 15, 2009 | Kenmore Elite HE4 Electric Dryer
No light on the control panel.
The new dryers need both hots(red & black) and the white plus ground to operate the control panel properly do you have a three prong or 4 on the dryer out let? try a new cord & plug before calling someone
Aug 29, 2008 | Whirlpool GGW9200L Gas Dryer
Whirlpool Duet GEW9250
more than likely a short in the user interface
Jan 28, 2008 | Whirlpool GEW9250 Electric Dryer
Does the Maytag LSE7806ACE require a 220 plug?
If you hook it up to 120 volts (by connecting L2[red] to common [white] the dryer will operate, but your heating element will only produce 25% of the heat it would on a 220v circuit. The drying time would be about 3 hours, and the auto dry setting may not work. Heat difference is about 5000 watts of heat on 220v, vs 1250 watts on 120v circuit.
Dec 19, 2007 | Maytag LSE7806A Top Load Stacked...
Dryers Logo
65 people viewed this question
Top Dryers Experts
