Question about Candy CN146 Front Load Washer
Hi, where will I find the internal fuse for Candy CN146 T-80 and do I need to remove the top or the back please?
My Candy CN146 T-80 plug melted! I have fitted and new plug and fuse but no power to the machine. I want to check the internal fuse but not sure where this is sited...would it be behind the on/off switch and if it still doesn't work when I replace this..any other ideas please?
5 Suggested Answers
  • 46 Answers
SOURCE: CANDY AQUAVIVA WASHER/DRYER
its either the motor or element gone, remove the back of the machine and remove the wires from each component mentioned. try the element first , MAKE SURE U TAPE UP THE REMOVED WIRES BEFORE TURNING THE MACHINE BACK ON , U WILL GET A SHOCK IF U DONT!!!. if it does not trip , then the element is gone. like wise do the same to the motor. just one more item to check is where the mains cable enters the inside of the machine. good luck
Posted on Feb 07, 2008
  • 1462 Answers
SOURCE: heating element Candy DQW150 Where is it please?
i think you amy have 2 faults. the elements for wash and dry are completely separate.
Posted on Jun 26, 2008
emissionwiz
  • 76630 Answers
SOURCE: Replacing Door Seal on AQW130 Candy Washer Dryer
JUST THE SEAL IS ALL THAT IS REQUIRED AND A GOOD SET OF TOOLS AND MECHANICAL SKILLS, i AM IN THE USA SO CAN'T RECOMMEND ANY PLACE TO BUY IN UK
Posted on Jul 28, 2010
  • 58 Answers
SOURCE: candy grand o go482/2-80 very noisy when spinning
The manufacturer, "Candy Products" http://www.candy-domestic.co.uk/about_us/Default.aspx is more likely to provide an authoritative answer than anyone else. They seem to manufacture their own machines, answers based on experience with other makes and models are of no value to you in regard to this question.
the foregoing aside, what one man has made, another man can also make, or repair. It is extremely unlikely that Candy paid to have an exotic one of a kind bearing made for this washer. However, even if the bearings are a common industrial part, that doesn't mean that removing and replacing them is easy or cost efective, or even the cause of the noise.
Unless you have more expertise than your question implies, perhaps you should ask to have a Candy repairman diagnose the noise and if your diagnosis is confirmed give you seperate prices for the bearings and the installation of same. From that you can discern how long the professional repairman familar with the machine would require to do the work, and you should double or triple it to estimate how long it will take someone unfaniliar with the machine to do it
Posted on Feb 12, 2012
Got sticky stuff in mic, cant hear phone ring
you need to disassemble the phone and clean the little hole of the mic
Dec 03, 2011 | Samsung Cell Phones
Hi , I recently purchased your machine and would like to know how to flavour and colour the cotton candy. I did not receive any sugar in the box , so I'm not sure what to use. Please help. P.S - Can I...
Hi pandoramagic...
This is not the company that you bought your machine from, it is an "Answer Company" we supply answers to questions people have.
You need a special sugar in the machine (read below), and you can use liquid food coloring to color the sugar/cotton candy and different liquid flavors to flavor the cotton candy.
Typical machines used to make cotton candy include a spinning head enclosing a small "sugar reserve" bowl into which a charge of granulated, colored sugar (or separate sugar and food coloring) is poured. Heaters near the rim of the head melt the sugar, which is squeezed out through tiny holes by centrifugal force. Precolored sugar packaged specially for the process is milled with melting characteristics and a crystal size optimized for the head and heated holes; granulated sugar used in baking contains fine crystals which spin out unmelted, while rock sugar crystals are too large to properly contact the heater, slowing the production of floss.
The molten sugar solidifies in the air and is caught in a larger bowl which totally surrounds the spinning head. Left to operate for a period, the cottonlike product builds up on the inside walls of the larger bowl, at which point the machine operator twirls a stick, cone, or their hands around the rim of the large catching bowl, gathering the sugar strands into portions which are served on stick or cone, or in plastic bags. As the sugar reserve bowl empties, the operator recharges it with more feedstock. The product is sensitive to humidity, and in humid summer locales, the process can be messy and sticky.
Webpage for cotton candy supplies: http://www.epopcorn.com/cotton-candy-machines-cotton-candy-supplies.html
Please take time to rate me
Aug 31, 2011 | Helman Group Nostalgia Electrics RCM605...
Melted candy in dryer
Hi mcdo3800...
You will need to disassemble the dryer to remove the melted candy...
I will send you instructions on how to replace the belt, it will include all the instructions you will need to disassemble the dryer for cleaning and to do some maintenance.
ALWAYS UNPLUG YOUR DRYER BEFORE ATTEMPTING TO DO ANY WORK ON IT.
Note: This method workds for most front loading machines.
If you have to check/replace/repair your drum motor,drum seals,belt,rollers, etc.
If replacing drum seals be sure to use a good grade of weather proof cement to hold the seal/s in place, some seals are furnished with the cement to glue it in place.
Remove the electrical console that holds the timer switch,start switch, etc. from the top of the dryer if necessary. Be real careful not to knock any of the wires off of the timer switch or other electrical connections.
Remove the lint filter and the two screws that hold the filter housing to the top of the dryer lid.
Then remove the top of the dryer by inserting a screwdriver between the top and frame on each side of the dryer to pop the lid up from the retaining clips.
Note: Some of the tops tilt backwards on a type of hinge and do not have to be removed completly.
Remove the front of the machine by disconnecting the door switch and removing the two screws located on either side of the dryer frame.
Move the door and front of machine forward to remove.
This will expose the belt,idler bracket and drum, remove the drum and belt and this will expose the drum rollers, idler arm bracket with pulley, and motor with pulley. Pay attention to the route of the belt, this will come in handy when you go to reinstall the belt and drum.
Sometimes the belt will slip off of the idler arm or motor causing the drum not to turn.
Note:The way the belt goes back on is, as the belt comes off the drum has to be doubled (pushed together to form a loop) and goes under the idler pulley then to the motor pulley.
While you have the drum out, I would recommend that you lubricate the drum rollers at the shaft of the roller with a good grade of machine oil like 3 in One oil or a vasoline type of lubricant. This will save you a problem later with the rollers getting noisy, also check your drum rollers for flat spots, if they have flat spots on them this will cause a thumping type noise. You will need to replace the drum rollers if they have flat spots on them.
This is a FREE answer, Please take time to rate me
Jul 08, 2011 | Kenmore Dryers
Error E11 in the machine Candy Alisé GO W 264 D, could you please tell me what this error means, and how to solve it? Thank you! Manuela
Open top cover of the machine. From the back on top there are 3 screws, remove them and slide back top cover to remove it. You will see a metal part with 2 thin red wires(sensors) atached. One is probably loose and the machine shows error code e11 and will not centrifuge. Make sure it holds and try to run the machine again.
Jan 08, 2011 | Candy Washing Machines
Washing machine tripped main fuse breaker, now won't work
Yes. It may be an internal safety fuse or switch. RJ
Sep 29, 2017 | Candy Washing Machines
Brake lights blows fuses
Please check the brake light wiring there must be somewhere where the live wire is touching the body (earth -) and thus the blowing of the fuses.
Since the plug in had melted so must have the wires insulation top melted somewhere and its now shorting.
Hope this helps.
May 22, 2009 | 1996 Lincoln Continental
No power to tv
Replaced internal fuse. Need to remove back.Fuse type T3.15 A. This blew again.
Mar 28, 2008 | Bush 5693D 24" TV
Internal fuse
HI
Check that you use another power outlet,see that the power cord pins are clean,and not burnt or use a new cord,the connection at the projector makes a GOOD connection with the new cord.
You will need a multimeter to check if there is voltage at the inside of the projector cord connection.You will have to remove the internal fuse before you check the the voltage inside.If all looks good then you will have a fault on the circuit board-shorted component on power supply side or further in on the circuit(need an electronic tech for this).Hope this helps--Jay
SAFTEY FIRST ALL TIMES--NOT SURE DO NOT DO IT
Oct 16, 2007 | Hitachi Performa CP-RS55 Multimedia...
Candy CDI 1012 Dishwasher
providing its not under guarantee remove mains plug and remove door skin from front of door carefully, as it has to go back on, look for any broken wires just above the door hinge, there will be about 10 or 15 wires, its possible that if you have checked what you said have checked properly that one of these wires has got hot and broken (very common fault of all dishwashers aver 3 year old) replace wire with care etc, work safely,
Oct 06, 2007 | Candy 17 in. CS455 Built-in Dishwasher
Candy CN146 Front Load Washer Logo
14 people viewed this question
Top Candy Washing Machines Experts
Gerry Harvey
Gerry Harvey
Are you a Candy Washing Machine Expert? Answer questions, earn points and help others
