How do i reset my winbook 37T1 tv
My tv display comes on a solid green then it blinks red then turns solid red
  • 899 Answers
SOURCE: Blinking Green Light on Mitsubishi DLP 52525
the circut that detects the bulb has been also failing in these sets
and the conversion chip that controls the picture , and the transformers are not putting out the full power they are supposed to.
this set will need to be tested to determine the exact cause or causes
Posted on Oct 18, 2008
tvguy171
  • 106 Answers
SOURCE: STATUS LIGHT SOLID RED ON 73 DLP MITSU MODEL WD73735
The colorwheel is your problem. To confirm this, unplug the tv, then listen thru the air vents in the back as you plug the tv in. You will probably hear a ticking sound. If you do, that is the colrwheel. If the colrwheel is working, youwill be able to hear it "spin up". It will be a sudden high pitch whine. Let me know if I can be of further assistance
Posted on Dec 19, 2008
SOURCE: kdf-60xbr950 - red light blinks 3 times for a minute and tv turns off
same problem as others 3 blinking green lights then orangey colors then 3 red blinking lights afterwards shuts down fan runs for about 2 mins solution check your door cover for warpage or deformed just a bit under set screw there is a push in switch try and push it in with q tip while holding turn on tv if it works then that door is deformed and defective change it
thanks for solving my issue tv works again very helpfull thanks
Posted on Jan 07, 2009
  • 16 Answers
SOURCE: WD-52525 - No picture, green status light then turns to red lamp
check the lamp
Posted on Jun 26, 2009
welcomejee
  • 10594 Answers
SOURCE: Sony Grand Vega green light blinks on and then blinks red
Please intimate exact model of your Sony TV and also mention how many times red light blinks as there would be pause of 3 seconds in blinks so count pause to pause and let me know to find out problem.
How old is this TV and did you replaced its lamp?
Thanks.
Posted on Sep 14, 2009
Testimonial: "You are on the right track even with my poor explanation. Thank you"
Tv light blinks green then solid then red
Hello:
From the sound of your description of your problem you likely have a defective lamp. Feel free to give us a call at 866-764-5822 and we would be happy to help you troubleshoot the problem over the telephone.
Best Regards
Dan
DLP Lamps Projector Lamps Specialty Lighting
Mar 31, 2014 | Mitsubishi WD Televison & Video
Runco flat panel tv displays solid green then blinking red light. What doe this mean?
How many times this standby/power light blinks at one time switch ON? Count it carefully. These blinks are fault indication, and known as blinking codes. From the number of blinks occur at one time switch ON; you can get an idea about the faulty circuit stage inside the TV. This will make repair easy. For more information, check the link http://electronicshelponline.blogspot.com/
Nov 14, 2013 | Runco Televison & Video
Lc320em1 digial control board
what does the set do when you press power? Does the Power indicator come on solid, blinking or etc.
Mar 18, 2013 | Emerson Lc320em1 TV
Mitsubishi projection T.V
check the lamp first to see if intact or shattered.
Mar 31, 2012 | Mitsubishi Televison & Video
Emerson LC320EM82 S red light will come on and when you go to power the tv on it blinks green and never turns on
Power supply board is dead,if green light on keep blinkings,notthing come on.Power green light is solid,nothing come on.Than ur Tuner signal board is dead.
Feb 09, 2010 | Emerson LC320EM8 32 in. LCD TV
Thanks.
Sep 14, 2009 | Sony Grand WEGA KF60WE610 60" Rear...
Turned on TV and had no picture. Now when I reset I get green blinking light then solid green status. After about 30 seconded red lamp light comes on. Is there a solution?
Your lamp is defective, incorrectly installed, or the cooling fan under the lamp is not cooling the lamp for some reason. Service that area.
Jun 26, 2009 | Mitsubishi WD-52525 52" Rear Projection...
The Power Light is Red
yeah, should stay red when unit is turned off, indicating there's power but it's doing nothing.
Per user manual:
Solid red - power off (standby mode)
blinking red - power off (now cooling)
blinking green - power on (preparing to light lamp)
solid green - power on
Mar 08, 2009 | Panasonic PT-40LC12 40" Rear Projection...
Televison & Video Logo
19 people viewed this question
Top Televison & Video Experts
Electro Med Services...
