Question about Dryers
Maytag Neptune electric dryer 63407280 B no power
There is no lights on panel and dryer will not operate. How to remove dryer top and replace fuse? There is power to the outlet.
SOURCE: dryer will not turn on
i've had my maytag dryer since 2002. it just stopped in the middle of a cycle. i think it's the motor. isn't maytag guaranteed for life???
Posted on Mar 14, 2008
SOURCE: How to remove a back panel of maytag neptune dryer?
You have a choice for which side front door should be on this model. There are 4 screws on front door. Take all 4 screws and pull down the front panel. You will see two metal parts each side which holds top panel. Remove two screws and metal parts. Now you can push up the top panel.
Posted on Mar 19, 2008
Illeagle
  • 525 Answers
SOURCE: maytag neptune electric dryer
Warning! Disconnect power before servicing!
1.Open the door and remove the screws holding the door, then pull outward on the door to disengage the hinges.
2, Remove the screws on the opposite side of the door opening.
3. Pull outward on the lower part of the front panel to disengage from the top.
4. Remove the screw from the top left and right corner top retainer bracket.
5. Rotate the retainer brackets toward each other to disengage the top from the side panels.
6. Lift top.
Posted on Jun 03, 2008
Catriver was right on the mark. Took a little bit of doing but I was able to fix the problem myself within 30 mins, and saved some money. Many thanks. I'd like to expand Catriver's solution a bit.
I found a layer of lint on the inside bottom of my dryer. With the face off of the dryer, it proved to be a good time to vacuum the lint out and reduce the potential of fire.
Posted on Sep 07, 2008
SolutionGuy
  • 331 Answers
SOURCE: How do I remove the lint housing of Maytag Neptune dryer
Hi Kate,
Gaining access to the lint housing sounds more difficult than it is. As a matter of fact, I could get to it and have it back together in the time it takes me to type out the instructions!
Tools needed;
1.) Phillips screwdriver
2.) 5/16" nut driver or socket
UNPLUG THE DRYER FIRST!!! Or risk a funky new hair-do...
Open the door and remove the four screws at the hinges then remove the door. Opposite the hinges, you'll see 4 more screws, remove these too. Now grasp the front panel on both sides near the top and pull it toward you. Lean it out to about a 45 degree angle and lift it off the clips that are holding it (at the bottom).
Now you'll see the lint trap housing. Look around the housing, you'll probably see a yellow wire near the 5 o'clock position, remove it. Now, on either side, you'll see four 5/16" screws... Don't remove the top ones, just remove the three below the top ones. You can now pull the entire panel off of the frame for cleaning.
Rebuild in the reverse order (and don't forget to re-connect that yellow wire!)
There ya go! Please don't forget to rate this as "FixYa", OK
SG
Posted on Apr 11, 2009
Maytag Neptune Dryer, Light inside with door open, but no lights up on top and does not run, can you please help me out, or where to start?
Check the breaker or fuse box. Sounds like one leg of the 220 volts is tripped. Reset it or replace the fuse if so.
Oct 19, 2014 | Maytag Neptune MDE5500AY Electric Dryer
Neptune dryer 5500 no power
This dryer has 2 thermal fuses. One next to the control stat on the blower housing and another on the heater element. You could quite possibly have a bad blower wheel or simply a lint build up cauing over heating. To get inside this dryer you remove the door first. The you can remove the front. Once that is removed you can pop the top and get the front shroud off. You cannot work from behind.
Sep 17, 2012 | Maytag Neptune MDE5500AY Electric Dryer
.8.8 error message on my neptune electric dryer
sounds like a serial connection problem or glitch in the c.c.u.,first try removing power to the unit for 5 to 10 minutes to clear the memory on the c.c.u.,if this doesn't resolve the issue you may need to replace this board you can power it down by unplugging at the wall or if not easily accessible,then at the power panels breaker or fuse
Jan 01, 2011 | Maytag Neptune MDE5500AY Electric Dryer
Maytag neptune dryer won't start has power lights will come on but ut won't run flashed PF before it quit
Hello & Welcome to FixYa
PF error code means power failure and is displayed when the circuit board also known as the electronic control board goes bad and needs a replacement. Before replacing the control you can also check the thermal fuse which is inside the rear panel on the blower wheel housing and replace if it reads no continuity. Please get back to me if you have any other questions.
Kevin
Dec 02, 2010 | Maytag Neptune MDE5500AY Electric Dryer
The beater bar in my Neptune dryer modeL # MED5500AYW has come off and needs to be replaced.
It sounds like you are referring to the drum baffles when you say "beater bar". If that is so, you need to remove the front panel then raise the top cover to access the baffles mounting screws outside the drum. Below is the link to the procedure I posted previously.
Maytag Neptune Dryer Front Panel and Top Cover Removal
Sep 09, 2010 | Maytag Neptune MDE5500AY Electric Dryer
How to remove the front panel of a maytag neptune gas dryer
Removal of the front panel requires the removal of the top cover and the console. Disconnect power to the dryer prior to servicing to avoid the risk of electric shock.
Remove the 2 screws attaching the top cover to the rear of the dryer then slide it rearward to clear the screw head from the top cover flange and lift the cover off the dryer cabinet.
Remove the screws securing the heater PCB board and disconnect the black and white wiring harness connectors from the board.
Remove the four screws attaching the console to the washer cabinet and rotate the console down to remove it from the dryer.
Remove the four screws attaching the top of the front panel to the cabinet and the two screws at the bottom of the door opening.
Pull the front panel forward and disconnect the interior light wiring harness then lift the front panel off the tabs across the bottom and move it away from the dryer.
Reinstall the front panel, the console, and the top cover in reverse of the removal steps.
Apr 21, 2010 | Maytag Neptune MDG5500AW Gas Dryer
Maytag Neptune MDE3000 electric dryer replacement of belt
The top comes off then the front panel is next.
remove the drum by pulling it out to replace the belt. replace the tensioners pully as well for it has a bearing that wears out then squeals loadly when old and dried up
Mar 27, 2010 | Maytag Neptune MDE4000 Electric Dryer
If i was to replace the thermo fuse is it hard and what do i need to accomplish the repair?? thanks for the help on diagnosing that i need the fuse because the lights won't light up on the control panel
remove top cover then access the front cover and just below the drum the heat tube is visible off to the right and the thermal fuse is on left side of outer tube housing on a bracket
Sep 19, 2009 | Maytag Neptune MDE5500AY Electric Dryer
My maytag will not run
My neptune dryer electric mde5500ayw will not start the button seemed too be struck, and how can i take the side panel off to check the fuses inside
Nov 20, 2008 | Maytag Neptune MDE5500AY Electric Dryer
Maytag neptune electric dryer
6. Lift top.
May 24, 2008 | Maytag Neptune MDE5500AY Electric Dryer
Dryers Logo
47 people viewed this question
Top Dryers Experts
