Question about Bissell PowerForce PowerBrush Deep Cleaning System
I lost the manual to my Bissell powerforce powerbrush. Do I put the cleaning solution into the clean water tank with the water
SOURCE: my bissell powerbrush won't **** up the water
had same problem - carpet soaked with dirty water and very little, if any, cleaning fluid used. Easily remedied. Removed water resevoir and found that the rectangular shaped washer at the top of the front cover (the bit you had unscrewed to give a good clean) had become dislodged. It has small lugs on either size which lock on to the plastic opening when pushed down firmly. Resevoir then sits on top and makes full connection, also ensure that grey locking handle is fully pushed down.
Seemed to me that the water wasn't being sucked up as there was air getting in and this has down the trick. Sorry if this is difficult to follow but all will become clear when you look for the black washer! Good luck
Posted on May 04, 2009
  • 8 Answers
SOURCE: Bissell PowerForce Bagless Upright
belt need to be replace
Posted on Jun 11, 2009
  • 13 Answers
SOURCE: No suction on Bissell Powerforce Bagless. Have thoroughly cleaned
Make sure you unplug before cleaning turn vaccum upside down check roller
for hair and strings wrapped around brush if this does not help clean out cylinder gently knocking dust out or use a duster to stick up inside lightly cleaning and check filter
Posted on Oct 04, 2009
Vac Belts
  • 701 Answers
SOURCE: Bissell pro heat steam carpet cleaner, not releasing water.
That means that you need to replace the pump belt. Here is the belt you need and a manual you can view:
Bissell 7901 Belt and Manual
Posted on Mar 02, 2010
Testimonial: "just what I was looking for thank you"
heatman101
  • 43501 Answers
SOURCE: FILLING INSTRUCTIONS. I HAVE A BISSELL PROHEAT
Here is a tip that will give you all the information you need to fix your Bissell Proheat Vacuum Problem.
Bissell Proheat Upright Wet/Dry Vacuum Problems
heatman101
Posted on Sep 23, 2010
Why is the solution coming out of both lower sides of my Bissell carpet cleaner
First try cleaning the filters. One under the water tank cap (looks like a screen) remove it, clean and replace it. The other is a Flow Indicator Filter = unscrew the Flow Indicator remove the rotor and pull out the filter. Clean it and reinstall in reverse order. If that doesn't work the call the Consumer Care at 1-800-237-7691, Hope that helped.
Oct 08, 2014 | Bissell Carpet Cleaner Powerbrush Deep...
I don't have any suction with my bissell dirtlifter powerbrush...how can i fix it?
Check the Water Tank Filter on the cap of the tank (it looks like a screen) If clogged then the tank holds air and can't suck up water. You may want to check your User's Guide to see if there are any other filters that may need cleaning after each use. Hope that helps. If not Bissell has a Consumer Care service at 1-800-237-7691
Aug 25, 2014 | Bissell Vacuums
Cleaning liquid drains out whether trigger is squeezed or not
I put the soap tank on . Then went & got get the other holding tank it wasn't even on but all the cleaning solution was drained all over my carpet. What can I do to fix it or does it need to be returned to Wal-Mart
Mar 09, 2014 | Bissell PowerForce PowerBrush Deep...
Replace power cord Bissell Powerforce Powerbrush
Hey Shelly! Sorry to hear the dog chewed the power cord.
You may want to contact one of our Authorized Service Centers for assistance.
Here's a quick link to locating one in your area:
http://www.bissell.com/service-centers/?cid=ccsocial
Mar 09, 2013 | Bissell PowerForce PowerBrush Deep...
My Bissell Pro Heat 2X steam cleaner is not releasing the water
Have you tried cleaning out the small filterfrom the reserve tank? Also, check the tank/resevoir valve is operating properly, when you take it out to fill try to make water release from tank.
Apr 29, 2010 | Bissell Carpet Cleaner Powerbrush Deep...
My bissell powerbrush won't **** up the water
Mar 18, 2009 | Bissell Carpet Cleaner Powerbrush Deep...
Bissell PowerForce PowerBrush Deep Cleaning System Logo
102 people viewed this question
Top Bissell Vacuums Experts
Jim Parker
Jim Parker
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
