Washing Machines Logo
Anonymous Posted on Jul 11, 2013
GLWN5050MOWS Machine wont start cycle.this happened before and I think i reset machine with troubleshooting codes.Not sure.
5 Related Answers
Anonymous
  • Posted on Dec 30, 2007
SOURCE: LOC code flashing on washing machine
Pressing the options and select buttons simultaneously for 5-10 seconds worked. For me it happened this way: on the first attempt, with the indicator lights already "timed-out" and off, pressing and holding the options and select buttons simultaneously for 5-10 seconds caused the lights to come back on and flash the "LOC" code again. But holding the options and select buttons together for 5-10 seconds a second time caused the indicator lights to stop flashing, and allowed me to start the cycle.
aborcass
Ron Coons
  • 2651 Answers
  • Posted on Mar 01, 2008
SOURCE: Machine wont start
oohhhh. gwl10 os asearly as my knowledge about these machines go, placing a call to manufacture migh be helpfull . do any indicator lights blink when washer stops??? those are the codes so write down which ones are blink, if i had to guess though id lean toward an ou-of-balance switch failure. on my gwl10 thatslocatedunder console on right side, white bar hanging down measuring time tub hits into it. the switch usally corodes out. hope thats somthin anyway
s_4u_11
sandip panchal
  • 535 Answers
  • Posted on Sep 16, 2008
SOURCE: Whirlpool Cabrio High Efficiency Top-Loading
PROBLEM RESOLVED!!!
The best I could find by scouring the internet was that it was a communication problem between the central control unit and the electronic control box. I was getting F1 codes that would stop the wash, then diagnostics showed F68 and F41 codes.
Sears wanted to charge $65 just to come out and diagnose it themselves, and these appliance sites wanted to charge their own fees to offer solutions. So I took a chance and ordered a new electronic control box ($146.00 + S&H) and installed it myself.
There are three long screws behind the control unit "hood", in the back-top of the washer, facing straight up and down. After unscrewing, I lifted up the hood up and forward, and there was a black box - the electronic control. First, you should check all the wires and make sure the connections are ok. If that still doesn't fix it, unplug all the wires, and take the electronic control out by unscrewing one 1/4" bolt. Put the new one in and re-wire everything (it shows what wires go where on the electronic control box - named by colors). No more error codes!
This washer is only a year and a half old as well, I guess it will pobably be my last Kenmore/Whirlp
rafiqahmad
  • Posted on Dec 01, 2008
SOURCE: AEG LAVAMAT 74620 - Washing Machine CE error code
Replace Water distributor (Dispenser Drawer) then will be Ok
Rafiq
Anonymous
  • 145 Answers
  • Posted on Dec 18, 2008
SOURCE: washing machine makes buzzing noise
Check the water pump for an obstruction in the chamber area, your pump may be sticking and that will cause the buzzing sound. The water pump runs during the fill portion of the cycle on several of the selected wash cycles to recirculate the water.
Daiwoo DWD1222 washing machine. Starts ok but never advances past 11 minutes to finish
Here are a few general troubleshooting steps you can try:
1. Check the water supply: Ensure that the water supply to the washing machine is turned on and that the water inlet hose is not kinked or blocked. If there is low water pressure, it may affect the washing machine's operation.
2. Clean the filter: Check if there is a filter in your washing machine and clean it if necessary. A clogged filter can cause issues with the machine's performance.
3. Check for any error codes: If your washing machine has a digital display, check if there are any error codes being displayed. Refer to the user manual for information on what the error codes mean and how to resolve them.
4. Reset the machine: Turn off the washing machine and unplug it from the power source. Wait for a few minutes, then plug it back in and turn it on again. This can help reset any temporary glitches.
5. Run a test cycle: Some washing machines have a test cycle option in their settings. Running a test cycle can help identify any specific issues with the machine's functionality.
If none of these steps resolve the issue, it might be best to contact Daiwoo customer support or consult a professional technician for further assistance. They will be able to provide specific troubleshooting guidance for your model of washing machine.
Bosch Avantixx6 VarioPerfect problems
If your Bosch Avantixx6 VarioPerfect washing machine is beeping and the light is cycling through the spin cycles without any other noise or action, it could indicate a potential issue with the machine. Here are a few troubleshooting steps you can try:
  1. Check for error codes: Some Bosch washing machines display error codes on the control panel when a problem occurs. Look for any error codes or error messages that may be displayed. Refer to your washing machine's manual or the manufacturer's website to understand what the specific error code means and how to address it.
  2. Check the door/lid: Ensure that the door or lid of the washing machine is securely closed. If the door is not closed properly, the machine may not start or may display an error. Open the door and close it firmly, making sure it latches properly.
  3. Check water supply: Ensure that the water supply to the washing machine is turned on and there is an adequate water supply. If the machine doesn't detect sufficient water, it may not start or may display an error. Check the water inlet hoses and the water supply valves to ensure they are properly connected and not blocked or kinked.
  4. Power cycle the machine: Turn off the washing machine and unplug it from the power source. Wait for a few minutes, then plug it back in and turn it on. This power cycle may help reset any temporary glitches or errors in the machine.
  5. Contact customer support: If the issue persists and you are unable to identify the cause or resolve it on your own, it's recommended to contact Bosch customer support or a qualified appliance repair technician.
Eratic, sometimes door lock doesnt activate, when it does wahser starts but stop mid cycle and wont continue. Replaced door switch and pump
Repair needed on Maytag Neptune washer - Home Improvement ...
www.dslreports.com > ... > Home Improvement
DSLReports
Aug 5, 2007 - 19 posts - ‎8 authors
Forum discussion: We have a Maytag Neptune front-loader washing machine that ...the drain/spin cycle after a wash even though the timer continues to ... related circuit board failure" their Neptune washer will lock the door, turn on the ... then will either not start tumbling or will stop operation mid-spin cycle.
How To Fix A Washing Machine That Is Not Spinning or ...
removeandreplace.com/.../washing-machine-or-washer-dryer-is-not-spin...
May 13, 2013 - The absolute first thing to do to your washing machine that will notspin or drain (whether it. ... I was so fed up with the machine sometimes refusing to spin or drain the .... I just did a load and it stopped midcycle with e and f error codes.... I tried different cycles but all that happens is the door lock engages ...
Maytag Washer Troubleshooting - YouTube
Start/Pause light flashing but machine won't start
Unplug machine and wait a few minutes and replug it in again! This usually resets the computer on the washer but be prepared if it happens on a regular basis you may need to call a qualified repairman that can troubleshoot the problem!
1helpful
Ge washing machine glwn5050mows loud spin noise
Replace the "tub damping straps" on the unit. Here are the parts to order and the is a video on that same page to show you how to access it. I think there are 4 straps on that unit.
LG Tromm washer wont spin through the spin cycle and reads error ue. I have tried to balance the load several times and still get the same error.
This error generally happens when people try to run a bulky load, like a coat, rug, pillow, etc., using a high speed spin. For these loads, choose the low speed spin. After the cycle completes, if you think the clothes are too wet, power up the machine again but instead of choosing a cycle, just push the spin speed button until it shows the next higher spin speed (usually about 14 minutes will show on the display) and push start. The machine will usually be able to get to a faster speed now, as the clothes have some of the water spun out of them from the earlier low speed spin, allowing the machine to reach a higher spin speed without the Unbalance Error code showing up. Of course, you want to make sure the machine is on a solid floor with all the legs adjusted properly also.
5helpful
6answers
My Whirlpool Duet Font Loader Washer stopped 1 minute before the end of the spin cycle; and I need to know how to reset it so that I can start another load of laundry.
Remove the front panelfbee677.jpg and check the pump filterd05d32e.jpg for objects8b65c4c.jpg then grab the tech sheet behind the white box and use the diagnostic instructions.
You have any non-HE soap in there or 2 much the machine will overamp and act all weird and then shut down with error code flashing. If it is an F-21 it means a Long drain. Possible cause: Clogged filter, clogged/failed pump.de495ab.jpg
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
1helpful
2answers
My hoover galaxy washing machine stops when clothes are not balanced properly.i have to even out the clothes then start the machine.if the clothes are balanced it finishes its cycle.if not the machine...
Hi
It is normal for the drum to sway excessively and hit the balance switch if the load is not evenly distributed around the drum or if you have excess cloths.
Once the balance switch is trigerred, you can reset by openning and closing the door. It is a safety mechanism which stops the spin cycle if the drum sways excessively.
If this tends to happen often, then you need to make sure the machine is properly balanced and not leaning too much to the back.
Also the drum suspension rods do tend to wear out over time and loose their firmness, causing the drum to sway excessively. You can check this by opening the lid. Pushing down and from side to side onto the agitator, and seeing if their is a firm bound on the drum. Also making sure the drum returns to centre position. If the suspension springs feel loose and wayward, then they will need replacement.
Regards
Ash
Whirlpool Duet washing machine will not start a cycle.
sounds as if its a door latch/lock issue, not recognizing the door closed will simply beep 3 times when the start button is depressed. try unplugging and replugging after 2 min.
Top Washing Machines Experts
john h
