Question about Panasonic Lumix DMC-FX30 Digital Camera
Perrier (Mineral Water) + DMC-FX30 = No Work.
Hi all, I read all there is to read about water damage to cameras, but still didn?t find anything that helps me out. I got a Panasonic DMC-FX30 Black digital camera. While I was on my vacation (with my sister), my camera got wet. My sister put Perrier (mineral water) in her back. The bottle was close or so we thought, and when it came time to take a picture, is when we seen that her bag was wet. I reached for the camera. When I pulled it out, the switch was in ON possession and it did not turn on. We immediately went to the hotel, where I took the battery out and my SD card. The battery was dried and recharged, and my SD Card was working fine. I set the camera on a fan and it was getting dried. Next day I tried the camera but through a USB cable, not the battery and nothing happened. My questions are as follows. Will Panasonic fix my camera? Should I just go and buy a new one? (Bought it at $300, now valued at $225) Can I fix this myself? If yes then where can I get the service manual or how to do it? Someone help. I like this camera; a new model came out, DMC-FX33, this month. Do not want to see this baby go.
RE: Can I fix this myself? If yes then where can I get the service manual or how to do it? That doesn't sound too good that you're camera was switched on when it was wet. If you are very technically skilled and know what you're doing then you probably could fix it. For a free Panasonic digital camera service manual go here:
Posted on Sep 04, 2007
Unfortunately you said the camera was on when you pulled it out of the bag...sometimes when an electronic gets wet, get it dry as quick as possible not turn on the unit...leave it drying for a dry..if you have a compressor blow out with air to accelerate the drying time and remove the liquid..
Posted on Aug 27, 2007
  • 2,985 Answers
Wet and camera do not mix - wet onto the circuit board will cause a short and blow stuff. There is nothing to repair- cameras like other small electronics are machine made in a single piece. You can ask Panasonic via the support site - but I fear it is new camera time.
How can I fix the screen on my Lumix DMC-FX30 which does not illuminate?
First, check the display settings.
Next, the camera usually switches back to its default when the shutter release is touched. Check those settings, too.
Aug 20, 2014 | Panasonic Lumix DMC-FX30 Digital Camera
Do NOT attempt any potentially damaging repairs before consulting with the manufacturer. For one, it might void your warranty. You can start off by checking out the user manual for your device:
Panasonic DMC FX30 manual
Aug 20, 2013 | Panasonic Lumix DMC-FX30 Digital Camera
Lines in pictures when view picture
Try turning the camera on and off, as well as removing the battery and placing it back in. It could also be that the camera itself is faulty. Try checking the user manual for a solution that might be relevant to you:
Jul 13, 2012 | Panasonic Lumix DMC-FX30 Digital Camera
Mode dial is not in the proper position
i had the same problem try this tap the outside of the dial lightly while turning the camera on it should basically "pop" right out if it didn't work it needs to go to a panasonic service technician. most likely the lens is damaged and the mode switch
Feb 13, 2011 | Panasonic Lumix DMC-FX30 Digital Camera
Hi, How can i use my dmc-fx30 as webcam ? Jan The
I know this probably isn't the answer you wanted to see, but here goes.
The Lumix was designed as a camera, storing images (and videos) to a memory card. It was not designed to stream video live to another device. It's a camera, and cannot be used as a webcam.
Jun 11, 2010 | Panasonic Lumix DMC-FX30 Digital Camera
Hi, I have a DMC-FX30. When i turn the zoom
mera Digital Camera Hi, I have a DMC-FX30. When i turn the zoom Answer Failed: retry Hi, I have a DMC-FX30. When i turn the zoom swithc it is stiff and goes to full zoom and cannot be... (More) (More) Hi, I have a DMC-FX30. When i turn the zoom swithc it is stiff and goes to full zoom and cannot be stopped - only when i switch the camera off. Can you help?
Feb 11, 2010 | Panasonic Lumix DMC-FZ28 Digital Camera
My dmc-fx30 When i turned it on the camrea shut down and is tuck in an on posion when its off so i charged my batterie and put it back in And nothing
Your problem may be due to weak/worn out batteries or corrosion on the battery contacts inside the camera which can prevent the full power of the batteries from flowing into the camera. Try this free fix before you do anything else: remove the batteries and wipe the camera contacts firmly with a dry cloth (heavy corrosion may require cleaning with a wire brush, steel wool, or sandpaper). Remove any residue that may have fallen into the battery compartment during cleaning, then wipe both ends of the batteries and place them back in the camera. This cleaning clears the problem about 90% of the time. If it doesn't work for you, your batteries may need to be replaced, or the camera may have a problem that requires professional repair.
Nov 07, 2009 | Panasonic Lumix DMC-FX30 Digital Camera
I have a DMC-FX30. I can't get it to auto focus. It stays blurry. What to do?
I have same camera as you but it is currently set in Japanesse and want it set in English??? can you help????
Apr 03, 2009 | Panasonic Lumix DMC-FX30 Digital Camera
Panasonic Lumix DMC-FX30 Digital Camera Logo
330 people viewed this question
Top Panasonic Cameras Experts
Are you a Panasonic Camera Expert? Answer questions, earn points and help others
