Question about Garden
RYOBI PLT 2543 can i get a replacement spark plug wire for this model its the cable that goes over the top of the spark plug and connects to the engine
4 Suggested Answers
57 varieties
  • 1653 Answers
SOURCE: My Ryobi PLT 2543 strimmer will run, but cuts out
I had this problem twice in the past. I solved it the first time by replacingthe plug and setting the plug gap with a feeler guage. The next time it was a decoke of the cylinder (squirting through the plug hole) replacing the plug and leaving it overnight and then cleaning the air filter. It runs like a dream and has worked in Australia, Europe and the UK with no further problems. Also the fule mix has to be just right, I actually use 22:1 instead of 25:1 and do not use any petrol / gas with additives in (like Shell).
Posted on Aug 29, 2009
chris12456
  • 3 Answers
SOURCE: ryobi plt 3043yw, wont start.
Hey www_mike350,
Just fixed my Ryobi 3043YW. I got this given to me not working and didnt even need it. I already have one. I decided to have a look over it, see if I could get it going.
To my surprise everything looked clean. I checked for spark, that was good, compression seemed good. I took the spark plug out and tipped some fuel in the cylinder, put the plug back in and tried to start it.
If it started I would have suspected the carby, but it still didnt start.
I was really annoyed because everything looked clean but it still wouldnt start. There was fuel, spark and compression, I didnt know what else could make this thing not start.
I pulled it completely apart and found the rotor assembly was the problem. It was causing a timing issue, meaning that it was sparking at the wrong times, when there was no gas in the cylinder.
On the inside of the rotor is a pin or a key that lines up on the shaft and gives the spark its timing. That key was made of cast iron and had broken off, causing the rotor to spin on the shaft out of alignment. This through the timing out.
I lined it up and tightened it and its working again. I couldnt believe it when it started, I have spent hours on this thing.
I will have to try and replace the rotor (Part no. 300952001), otherwise it will slip on the shaft again sooner or later and do the same thing.
Unfortunately I need to replace the gaskets too now as most came apart when I was pulling it apart.
Hope that helps someone out there!
chris12456@hotmail.com
Posted on Apr 30, 2011
  • 6468 Answers
SOURCE: spark plug wire install on ryobi ss26 edger
if the clip on the end broke off that can be replaced but if its on the coil end you need to replace the coil
Posted on Apr 08, 2012
Where can i get a piston ring for ryobi strimmer,its a 25cc,model number PLT 2543.
Some of these small engines have very limited parts availability so that part may not be available. Try www.jackssmallengine.com
Oct 27, 2016 | Ryobi Garden
Spark Plug Cover keeps popping off Spark plug when under load causing trimmer to cut out on my RYOBI RBC254FSDSN
Sounds like your spark plug boot has gotten soaked with oil or some other contaminent. Replace spark plug boot with a new one.
Jan 03, 2015 | Ryobi Garden
Head assembly diagram
Australian Website
Ryobi PLT3043YW Spare Parts
The owners also refers to RY70103 as another model number this unit's IPL available thru USA Website.
www.ereplacementparts.com RY70103
Nov 16, 2014 | Ryobi Garden
What is the 2 stroke petrol mix for a garden strimmer, Ryobi 25cc PLT 2543 please?
hi there keithprobert
the ratio to use if using top quality 2 stroke oil is 50:1 that is 20 mills of 2 stroke oil per 1.0 litre of petrol that you mix.
but if not using top quality 2 stroke oil use ratio 25:1 that is 40 mills of 2stroke oil per 1.0 litre of petrol that you mix.
cheers pauly46
dont forget the thumbs rating
Jun 02, 2011 | Garden
Spark plug wire on Ryobi 700r broke. How to
Spark plug wire on Ryobi weed Eater broke off. How do you fix it? Thanks
Sep 30, 2009 | Garden
My Ryobi PLT 2543 strimmer will run, but cuts out when the throttle is opened
Aug 29, 2009 | Ryobi Garden
Cannot start ryobi 3043 yw grass edger
Check the spark plug and sheck the gap on it then check the wire
Oct 19, 2008 | Garden
Garden Logo
50 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
