Question about DeLonghi Pinguino PACL90 Portable Air Conditioner
Exclamation mark and triangle - DeLonghi Pinguino PACL90 Portable Air Conditioner
Exclamation mark in facebook chat
There's an error.
I suggest that you close your facebook or browser and open it again. It just needs a refresh.
I hope this helps!
Carlo
Dec 18, 2012 | Computers & Internet
What does the triangle with the arrow round it mean and what does the triangle with the exclamation mark in mean please
The triangle with the arrow around it is for the wheel speed sensor. The triangle with the exclamation point is for tire pressure. Low tire pressure would set both of these lights off.
Oct 13, 2012 | Cars & Trucks
Warning light with triangle with exclamation mark and brake lights apperaing on dash
The waring kight with the triangle and exclamation mark is waring you that the brake pads are close to tuoching the disc's the waring sensor on the brake pad has shorted. It's so you do not scrap the disc's.
Feb 09, 2011 | 2001 Volkswagen Passat
Exclamation point in triangle blinking on dashboard
Hi, The exclamation point in triangle blinking is the "Emergency Blinker" This blinker turns on all all of the turn signal lamps at all four corners of the car. Left and Right, Front and Back. The triangle represents the European symbol for roadside emergencies. In fact on European Mercedes and other cars there is a triangle shaped reflector you can put behind the car so that other drivers know you have an emergency. THAT TRIANGLE ON YOUR DASHBOARD IS A BUTTON. PUSH IT ONCE. THE BLINKING SHOULD STOP. If you have a roadside emergency, and are broken down by the side of the rode. Push the Red Triangle and your lights will blink on and off ouTside to say, in effect "help".
Hope this helps.
Best,
Mark
Jan 13, 2011 | 2005 Mercedes-Benz C-Class
I have a light on my dash with an exclamation point enclosed in what looks like parenthesis with verticle lines underneath. It's yellow. Do you know what it is?
If it looks like a deflating tire with an exclamation mark inside, its the check your tire pressure light.
If its a triangle with exclamation mark inside its the check engine light.
Oct 03, 2010 | Volkswagen Jetta Cars & Trucks
The exclamation mark in the triangle is on after installin g a new 12 volt battery
You need to buy a multimeter tester in order to reset this kinda exclamation mark, you could use this one right here EN61010-1 600V CATIII.
Dec 18, 2009 | 2008 Toyota Prius
Caution light on dash board
red triangle with ! is the vehicle stability control not the ebattery prolly a bad sensor
Aug 23, 2009 | 2004 Toyota Prius
Flashing orange light with exclamation mark
Just talked to a mate of mine who said its the ASC that has been turned off. I flicked the ASC switch and problem solved.
Dec 09, 2008 | 2002 Mini Cooper
Heating & Cooling Logo
18 people viewed this question
Top DeLonghi Heating & Cooling Experts
Paul Carew
Donni Steen
Are you a DeLonghi Heating and Cooling Expert? Answer questions, earn points and help others
