Price of a new washer.unimat.35 - Washing Machines
United airlines intranet login
Try installing the latest version of Java (obvious but worth a try)
Jan 19, 2014 | Computers & Internet
Tip
Price Pfister 3pc h/c & diverter leak
If you have the Price Pfister stems they leak or will , even after replaced with a new seat washer . Try switching factory flat washer with cone shape washer and always check the brass seat in manifold for cracks, very seldom replaced very cheap pack of 10 5$ save that water we take for granted!
on Nov 06, 2010 | Price Pfister Diverter 16050A
Weber unimat wtn 22-555 switch
I need another switch Can you send to me the switch 22-555?
Aug 25, 2013 | Saws
Need parts for Lescha Zak 1800 Chipper/shredder
I have a used lescha zak 1800 chipper. It does not have the stand. I have the motor with the on/off switch and most of the chipper housing. IThe motor runs strong. Reply at asm3davis@yahoo.com.
Sep 02, 2012 | Yard Machines Electric Chipper/Shredder
How much will a Ctc Laser Grip Glock 17/22/24/31/34/35 cost on average?
Prices for Laser Grip Glocks really dependon the supplier. Prices seem to be around $200 upwards. Look out for the sitesthat have special offers on but be careful to check for any hidden shipping costs.
Jul 17, 2012 | Crimson Trace Ctc Lasergrip Glk...
I have a kenmore washer top load model#22442100 it needs a new switch for the spin cycle but i can figure out how to get the top off to change it
Welcome to FixYa.
Here`s a helpful link for changing it out, and it covers most whirlpool built washers including Kenmore and removing the screws...locating them can be tricky on some models...this helps.
http://videos.wittysparks.com/id/3098139337
If this gives you any trouble I will try to help in any manner I can of course, let me know. Good luck.
Regards,
Macmarkus :)
May 22, 2011 | Kenmore 22422 Top Load Washer
The circuit board on my 9 year old neptune washer went up in smoke. Do I replace the circuit board or by a new washer? Thank you!
Check the price of a new circuit board against the price of a new machine. Take into consideration that installing a new circuit board yourself might see the new one go the way of its predecessor due to some other fault. Have a qualified technician give you a quote on the repair and again compare prices.
Jan 25, 2011 | Maytag Neptune Washer
I have a Kenmore stackable washer/dryer (apartment size) and the washer will shut off when it goes into the spin or rinse cycle. If I turn the control knob to rinse or spin, nothing happens. The washer...
try looking at your pump or you need a cupler that goes on the back sid of the motor price range for the pump is 120 dollars and the cupler is 35 dollars dont quote me on the price of the parts please but that should fix the problem.
Jan 31, 2010 | Kenmore Washing Machines
The lid switch was broken apart on a kenmore washer.Can it be reinstalled?
Not likely. You really should replace it. This is not an expensive part and its a fairly simple repair. The following link explains how to replace one:
http://www.fixya.com/support/r385198-replacing_lid_switch
A replacement can be purchased on line at searspartsdirect.com, pcappliancerepair.com, repairclinic.com, appliancepartspros.com. All these sites offer competitive pricing, so shop all of them for the best price.
This is a very simple repair, that usually costs about $25 to $35 to repair yourself. If you have questions, or require additional assistance, please let me know. I hope this helps you.
Oct 02, 2009 | Washing Machines
Clothes still wet after spin cycle
the first 2 things you need to check is:
  1. if it is spinning as fast as it used to
  • if not it needs a new clutch assembly ($35 + labor)
  1. if it is draining as fast as it used to
  • if not then it needs a new water pump ($30 + labor)
there is no filter that would cause this problem. prices are from repairclinic.com
  • if none of this describes the problem then let me know and i will help you figure it out. i know these machines well.
Mike
Jul 01, 2008 | Kenmore 24032\24036 Top Load Washer
Washing Machines Logo
Top Washing Machines Experts
