Question about Westinghouse Televison & Video
Digital tuner reset - Westinghouse Televison & Video
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Westinghouse Master
  • 102,366 Answers
What model Westinghouse television?
Posted on Jul 12, 2013
Lg 26lh2000 wont auto retune, help please.
There is the digital tuner (DTV) and the analogue tuner (TV). Make sure you are tuning the digital side as there are no longer any analogue TV broadcasts in the UK.
Sep 04, 2014 | LG 26LH2000 26 in. HDTV LED TV
No digital channels or menus
Yes, the main tuner is likely bad.
Jun 13, 2012 | Televison & Video
Does this model DVD/VCR recorder have an analog tuner or a digital tuner?
Is there a manufacture date on the back of it. The Commission's digital tuner rule specifies that as of March 1, 2007, all new TV sets must include digital tuners. I believe that rule follows when it comes to DVD players with built in tuners. If you bought this before that date then most likely its analog. I see in the owners manual has no listing for a digital tuner. So I would come to the assumption that its analog tuner. Hope this helps!!
Jan 14, 2011 | LG LRY-517
My Sony Bravia television froze on a digital picture today and now when I change channels there is no picture and no sound. I tried to do a digital scan and it picked up no digital signals,. The analogue...
Your TV has a dual tuner - one for analogue and one for digital although they are contained on the same tuner board. It's possible that the digital tuner has failed, in which case the tuner board will most likely need to be replaced, but often this problem can be resolved with a "hard" reset. Turn the TV off and unplug it. Remove all the cables from the back, leave it for at least 5 minutes and then re-connect only the cable from the tuner source. i.e aerial/antenna. Make sure you are in Digital TV mode (DTV), then run the channel scan again.
If it works turn the TV off, re-connect all of your other devices and you should be able to resume using the TV as normal.
If this doesn't work, you may need to have the digital tuner replaced. The analogue and digital channel feeds are from the same source. As the analogue channels are working there is no obvious fault with the feed or cables.
Please try this first and then post back for further assistance if needed.
Regards,
BElectric
Dec 23, 2010 | Sony BRAVIA KDL-40S2010 40 in. LCD...
Toshiba t/v model 155R9B how to set channels to correct numbers The channels are coming up to the wrong nos. for instance BBC1 could be on no. 3. how do i set them to correct channels?
Digital tv channels use analog carrier frequency of old system then changes to digital tv numbers later in the tuner memory. Leave tv on or standby at all times to have tuner set the digital tv numbers in its memory. You can reset the memory by pull the plug on the wall for 5 minutes then reconnect to the wall plug.
Oct 18, 2010 | Toshiba Televison & Video
Can the tuner be upgraded to get digital signals?
There is no way to directly change the internal tuner to receive digital/HD signals. I would simply purchase an external tuner unit, but be sure to get one that has at least component signal outputs and is HD. You want to be able view HD & not just digital. One of the small tuner boxes would get digital, but not HD. I personally have a Digital Stream tuner with a set I own and have been very pleased with it. The tuner has many extra features and also has an NTSC output I use for recording with a regular vcr. Shop for an HD tuner unit. You will be impressed by the kind of performance you will get from this set.
Nov 09, 2009 | Sony FD Trinitron WEGA KV-34HS420 34" TV
Reset code for digital tuner
Is the Tv a multi standard Tv?  And as you know most countries around the world are converting to digital Tv. A converter box will likley solve the problem.  Try this web site , ramelectronics.net  also type in , standards converters , in a search box.
Jul 05, 2009 | Televison & Video
Digital tv
Unless it says HDTV it is not digital.
Feb 16, 2009 | Hitachi 60SBX78B 60" Rear Projection...
Digital tuner frozen will not scan
While the TV is turned on, perform the following steps to hard reset the TV:
  1. Press and hold the Input Source button.
  2. Press and release the Power button.
    The TV turns off.
  3. Press and release the Power button.
    The TV turns on.
  4. Wait 10 seconds.
    A message appears saying the TV has been reset.
  5. Release the Input Source button.
Jan 04, 2009 | Dell W3706MC 37 in. LCD HDTV
Has integrated digital tuner?
This tv looks to old for that. Tv's only had digital tuners put in them, starting in 2006. All tv's in 2007 had digital tuners.
Sep 10, 2008 | Durabrand DWT2704 TV
Televison & Video Logo
49 people viewed this question
Top Westinghouse Televison & Video Experts
Jaime Hernandez
Are you a Westinghouse Televison and Video Expert? Answer questions, earn points and help others
