Question about HP LaserJet 5L Printer
Replaced rollers and still have a paper jam
I replaced the rollers and guides because of my paper jam, but now it doesn't even recognize there is paper in the printer and I still get a paper jam light. What are the paper path guides you referred to?
  • 20 Answers
You need to check if you put it back together correctly. The sensors need to move up and down with the paper.
Posted on Aug 29, 2007
Fi-6130z fujitsu scanner jamming repeatedly
Hello Meg,
To troubleshoot your scanner issue, yuo are advised to perform the steps provided below:
1.Remove all documents from the ADF paper chute.
2.Open the ADF while pressing down the ADF open lever. If your has the imprinter option attached, please open the imprinter and then open the ADF.
3.Remove the jammed papers from the ADF.
4.Close the ADF pushing the center part of the ADF carefully.
If document jams occur frequently, then please check the followings:
1. Do the documents satisfy paper specification?
2. Have the documents been jogged?
• Align the edge of documents for stable paper feeding.
• Remove documents with crease or dog-ear.
• Scanning different width of documents may cause skew and result in paper jam.
3. Are Chuter Unit (ADF paper chute),Guide P ASSY (Sheet guide), Feed roller cover (plate guide) and Brake roller cover installed correctly?
4. Clean the Feed rollers, Eject rollers,Plastic rollers, glass surface and paper feeding surface, and see if the error is resolved.
5. Check the consumable counter from the TWAIN driver screen. When the counter exceeds the values, replace Pick roller or Brake roller see if the error is resolved.
6. If the issue still persists, then you are recommended to contact the nearest Fujitsu service center for further assistance.
Hope the above information is helpful.
Thanks & regards,
ScanCare
Nov 26, 2013 | Fujitsu Fi6130z Sheetfed Scanner
Error J1
Hello Sharon,
When a document jam occurs, "J" and "1" will display alternately on the function number display panel of the scanner.Please perform the following:
  1. Remove all documents from the ADF paper chute.
  2. Open the ADF while pressing down the ADF open lever. If you are using fi-6130 with the imprinter option attached, please open the imprinter and then open the ADF.
  3. Remove the jammed papers from the ADF.
  4. Close the ADF pushing the center part of the ADF carefully.
If document jams occur frequently, please check the followings:
resolved.
5. Replace Pick roller or Brake roller, and see if the error is resolved.Check the consumable counter from the TWAIN driver screen or from the built-in Maintenance mode. When the counter exceeds the values, replace Pick roller or Brake roller.
Thanks & regards,
ScanCare
May 03, 2013 | Fujitsu Office Equipment & Supplies
Paper does not feed properly, slips, skids
Make sure the paper guides are properly aligned and spaced if they are adjustable.
The pickup roller may be worn out or loaded up with dust. If wiping it with a damp cloth doesn't help, replace it. (I tried rubber conditioner on one once. While the stuff normally works wonders, in this case, it made the pickup roller break out with little flaps of material all over, and it was still useless.)
Normally a problem with a roller farther into the printer causes the paper to crumple up in an accordion fold and jam, so I don't think these need more than a cleaning, and they probably aren't the problem.
It's also possible you have a foreign object in the paper path such as a shred of torn paper, but a good pickup roller would normally jam the paper into it before the printer halts with an error.
Jun 17, 2011 | Dell 926 All-In-One InkJet Printer
Printer doesn't send paper all the way says paper jam, rollers are moving doesn't print
Possibly the sheet detector sensor, that had become bent out of true alignment, which is telling the printer that there are a number of sheets going through and indicating a jam situation. You need to inspect the guide roller, make sure it is free to move and touches the sheet of paper when it is loaded. If it is bent out of alignment, GENTLY try to bend it back downwards (make sure the paper thickness setting is set to paper not to card when doing so,)
Jun 13, 2011 | Canon PIXMA MP240 All-In-One InkJet...
Comes up with paper jam. Open cover, remove drum and removed jammed paper. Had a look no jammed paper, looked at the back fuser area, no jammed paper. Removed paper try, no jammed papper. Can u help
If your printter is showing the message even after you have made sure that there is no paper inside the rollers , it is sure that the sensors- optocouplers- or the input amps for the sensors are defective. Youmay need to check on these individually to confirm. Identify them justt placed beneath the rollers take in guides. Check if thedetector is emitting even without the paper. use a multimeter to check of rvariation of votage with paper or without paper to confirm. hope you try this out and confirm. Good day,
Aug 11, 2010 | Brother MFC-8460N All-In-One Printer
I keep getting a paper jam message even though the paper is not jammed.
There's a sensor arm under the white guide plates behind the platen roller that gets bent or broken when you remove a jam, especially if you pull paper backwards to remove a jam. If you can't straighten it you need a shop to replace the sensor arm.
Sep 14, 2009 | Canon PIXMA MP150 All-In-One InkJet...
False Paper Jam Signal Canon MF5730
Try changing the quality of your paper.
Roughen up the rollere guides a little to you get better grip. Clean rollers with alcohol and use a green scrub mit to lightly rub the surface of the guide reels.
Hope that helps yours work too
Please rate our help to keep service online
Aug 19, 2009 | Canon imageCLASS MF5730 All-In-One Laser...
Paper jam
Try cleaning the rollers of the printer. If ever it wont work then there is a problem with its sensor. It should be service.
Aug 25, 2008 | HP PSC 750 All-In-One InkJet Printer
False Paper Jam Error
Make sure the paper tray guides are set against the paper more likely to be the back guide not pushing the paper to the front of the tray. If you have the guides set correctly then place one sheet of paper in the tray and blot some methylated spirits on the leading edge along the page width and close the tray and try printing something.
You will have a jam repeat process 3 or 4 times then open tray and remove paper. Where you soaked the spirits into the paper there should be a grubby mark where the feed roller has rubbed and cleaned. Wipe the tray dry and put fresh paper in then hopefully you will now be able to print. If you cannot then the likely thing is that the paper feed pickup spindle is broken and will need replacing.
Hope this helps you and please rate me
Thanks J
Dec 14, 2007 | HP LaserJet 2420 Printer
Paper jam
There are several things that can cause a paper jam error, even though there is no paper stuck. The most common is that the paper pickup rollers are worn or dirty, and can't grab paper. Even though there is no paper jammed in the machine, it will show the error message. The solution is to clean the roller with alcohol and a lint-free cloth (don't use paper towels). If the roller is very worn, you will need to replace it.
Feb 04, 2007 | Canon Image Runner 1630 Copier Copier
HP LaserJet 5L Printer Logo
59 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
