Question about Navman Fish 4150sx GPS Receiver
Navman 4150 paddlewheel
Where can I buy a replacement paddle wheel
FISH4431 was damaged whenyacht was taken out4antifouling.The FISH4431 box is fine. Its a discontinued product but can a alternative in production,one that can be sourced become available for our unit.
I would guess that your paddlewheel transducer is an ST850 and manufactured by Airmar.
Check the link below, the top two on the page are ducers for temperature and speed. (First one is a plastic housing, second one is brass)
Any chandler should easily be able to help you out.
Hope this helps.
-Steve
Displaying 23 matches for Navman
Apr 01, 2015 | Boating
Replacement fly wheel airmar DST800
This is an easy fix. You can get a replacement paddlewheel kit at just about any chandlery. If not in stock, they'll certainly be able to order you one.
Hope this helps.
Apr 23, 2014 | Garmin AIRMAR DST800 ThruHull Smart Sensor...
Does the same apply for the NavMan S100T battery as you can buy replacement batteries for this model?
No. From the manual: "Your Navman contains a non-replaceable internal lithium-ion polymer battery."
Mar 05, 2012 | Navman GPS
My roomba 4150 is running very slow. It is fully
may need to clean inside.the wheels pick up trash and deposit it on and near motors.also try to take ends of roller brushes off and clean hair ect.
Jul 09, 2009 | iRobot 4150 Roomba Vacuum
Polaris 380 wheels not moving
Here are some things to check: 1.  There are belts inside the unit that drive the wheels.  These belts often fail (shred) and must be replaced. 2.  There is a paddlewheel that drives the turbine that turns the wheels.  If the jet that drives the turbine is clogged, then the paddlewheel will not move and the wheels will not turn. 3.  There is a water management system inside the bottom of the unit.  It looks like a bunch of little hoses.  If one of these hoses comes loose, then the water pressure will escape inside the unit and will not be sufficient to drive the wheels.
Hope this helps
Jan 09, 2009 | Polaris 380 In Ground Pool Cleaner
Problem with navman 4150 fish finder
I installed my Navman 4150 depth finder along with the Navman GPS unit when I purchased my Bayliner Trophy 20Ft. Offshore model. Everything was ok for one year and it has been downhill since then. Losing signal, unbelievable high depth ranges, blank periods, etc.. I now can't even get a reading tieded up at the dock. I am now giving up and shoping for a quality unit.. Cape Disappointment.........
Jan 07, 2009 | Navman Fish 4150sx GPS Receiver
Navman 4150 sx
Go to the Website of Pertec.co.za and download the manual for the 4150 and 4150sx
Hope this will help
Regards
Albie Rossouw
albieros@mweb.co.za
Jul 20, 2008 | Navman Fish 4150sx GPS Receiver
Log and trip function not registering
It is unlikely the problem is in the A65 screen.....most likely it is an issue with the paddlewheel itself, its circuit in the depth/speed transducer, or least likely, in the DSM25 sounder module.
Both the log and the trip functiions are read from the paddle-wheel sensor of the connected DSM25 sounder module and transducer.
1. Make sure you have a DSM25 sounder module and transducer with a paddle wheel (the A65 is available without the DSM25 option.)
Double check the connections between the DSM25 and the A65, as well as the transducer connection to the A65. There is an indicator light on the DSM25 to confirm it is on.
2. Make sure the paddle wheel turns freely. They tend to get fouled easily with debris and growth.
3. Make sure the A65 is giving to a reading for SPEED when underway or when having a buddy spin the paddlewheel by hand. Do not confuse SPEED with SOG. SPEED is from the paddlewheel.....SOG (Speed over ground) comes from your GPS sensor and is not used by A65 for log or trip purposes.
If you get npo speed reading at all the paddle wheel may be defective or the depth/speed transducer may be defective. See your dealer about a replacement.
Nov 06, 2007 | Raymarine A65 Combo GPS...
Navman 4150 fishfinder
Depth: Could be for a number of reasons, too deep for the sounder - check the manual for it's max depth. Dirty water, sounder unable to penetrate through to the bottom. Weed or other debris covering the transducer. Transducer on a swing mount & being pushed out of alignment then dropping back in once stopped.
Speed: Is the speed readout controlled by a GPS or paddlewheel? If it's GPS, check the power connection of the sounder, may be loose which would also cause the depth to 'drop out'. If it's paddlewheel, you're down to bad connections or faulty unit.
Oct 16, 2007 | Navman Fish 4150sx GPS Receiver
Navman Fish 4150sx GPS Receiver Logo
Top Navman GPS Experts
Neil Gossage
Level 1 Expert
Are you a Navman GPS Expert? Answer questions, earn points and help others
