Question about Sewing Machines
Instruction manual for Tronic Z17489 - Sewing Machines
WHAT NUMBER NEEDLE I NEED FOR SINGER TRONIC 2010
If you have the Singer 2010, here is an instruction manual:
Product Manual Results
Perhaps this will help with needle selection:
Machine Needles
Dec 13, 2016 | Singer Sewing Machines
Noisy Singer Touch Tronic 2010 sewing machine
the noise could be from the needle /hook timing, or bobbin carrier
take it to a service center for a service and to find out the worn/ loose parts
Dec 21, 2015 | Singer Sewing Machines
Singer touch tronic 2010 only sews in reverse
Here is a link to the owner's manual.
http://www.manualslib.com/manual/154331/Singer-Touch-Tronic-2010.html
Was this running ok, the poof?
There might be a reverse option on one of the selections switches.
If it has sat for a while, it might need servicing; gummed up inside.
Feb 05, 2015 | Singer Sewing Machines
I have a singer touch tronic sewing machine. I need to fill the bobbin and I cannot get it to work. where can I buy more bobbins that have already been filled to fit my machine
Has the bobbin winder worked in the past and now faulting. Or are you unsure on how to use it?
There is a manual for a Touchtronic 2000 here http://www.singerco.com/uploads/download/432_touchtronic.pdf there may be more than one model Touch Tronic so plse check the serial number plate on the side of your machine to establish the actual model number, usually near the power inlet plug. then search for the appropriate manual at http://www.singerco.com/accessories/instruction-manuals. This excerpt shows that you wind the bobbin insitu in the bobbin case.
I'm not a fan of prewound bobbins, far better to deal with the bobbin winder issue. Winding your own thread means you can get far better colour matching to the fabric, and ensure you've got quality thread on the machine, and same thread top and bottom. (I prefer a quality cotton wrapped polyester or a polyester thread, Guttermann, Molynecke or Sylko Supreme). All of these factors affect stitching quality and the finished appearance of a seam.
Did you know that you can buy a freestanding unit to wind bobbins? Link to this item is here. http://www.sewingpartsonline.com/universal-automatic-bobbin-winder.aspx You may well find that this is the better solution to winding bobbins for this machine as winding them inside the bobbin housing doesn't give you a lot of control over the way the thread feeds onto the bobbin.
Jun 27, 2011 | Sewing Machines
I need a singer touch-tronic 2010 manual
I can't find any free downloads for a 2010, but I did find one for a touchtronic 2000. When the model numbers are close, very often the manuals apply to both machines pretty well. It should at least give you some info. Go to http://safemanuals.com/user-guide-instructions-owner-manual/SINGER/TOUCH-TRONIC%202000-_E. You'll need to give them a rating of your machine, but that's all. This site and it's downloads have been checked for viruses and such, and it is a safe site. It doesn't ask you for, nor does it take any personal information.
If you are willing to pay something for the manual, leave me a comment back. I know of a lot of sites that have manuals available for a charge, and I can quickly search those and get back to you as to which ones have your manual and an idea of the costs. The ones you can download from are, obviously, less expensive than the ones you get mailed a hard copy from.
May 29, 2011 | Singer Sewing Machines
Looking for a manual
I couldn't find you a free download, but here's a threading diagram. The same site has the manual available for purchase. Hope this gets you going!
Mar 08, 2010 | Sewing Machines
Sewing Machines Logo
80 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
