Question about Garden
Poulan Pro 300Ex Manual how to adjust the deck?
2 Suggested Answers
  • 6468 Answers
SOURCE: poulan pro 300ex riding lawn mower
pull the top cover and see if the starter gear broke if so napa has them for about $10
Posted on May 08, 2012
Where can i find the serial number on riding mower Poulan Pro 300EX
Usually under the seat.... Sometimes around the battery area as well... older ones would have them on the frame up close to front tires.
Oct 13, 2015 | Poulan Garden
I have a Poulan pro 300ex that chokes out everytime you throttle up I've cleaned the Carb and don't know what else to do please help
fuel starvation at high speed is most allways a filter/hose problem sometimes it can be a problem on the high speed jets in carb ,but post 2010 models are c.a.r.b. compliant and the jets are sealed from ever getting them out to clean them , new walbro carbs are only about fifty/sixty bucks online
have you tried car fuel cleaner ?
Apr 21, 2015 | Poulan Garden
Poulan pro 300ex riding lawn mower
May 06, 2012 | Garden
Need a manual for poulan pro tractor 42in 17.5hp model number is 960120110
Go to www.managemylife.com and get your free manual. Poulan and Craftsman are same. Built by company too.
Mar 03, 2012 | Poulan 42-Inch Steel Deck 17.5 HP Briggs &...
Poulan pro front wheel drive 22 inch mower. With height adjuster set to highest level, right front wheel keeps slipping out of the adjuster notch. Is there an adjustment screw somewhere?
Is the height adjuster tight on both sides? if loose the bolt holes may be elongated, both sides set the same? any wheel wobble indicating worn out wheels?.if it checks out as good put the machine an a known hard level surface such as a garage floor and check the clearance by turning the wheels by hand without putting pressure on them, If the wheel still slips the mowing deck may be warped or bent. if all wheels are original there shouldn`t be a question of mismatched wheels ie:different sizes.
Jul 03, 2011 | Poulan Pro " Pro" Self Propelled Mower
We changed the blades, changes a spindle and checked the deck and tire pressure on our Poulan Pro Mower. It is still cutting uneven. What else should we check.
Well the plane of the spinning blades obviously is not parallel to the ground. While the ground will never be level, do what you can and first get the mower on a good piece of flat concrete. Measure distance between each corner of the mower deck to the concrete. You have had the deck off, the deck hang mechanisms have some adjustment so you can lower the front of the deck relative to the rear and vice versa, and lower the left relative to the right side, and vice versa. Look for threaded rods with adjusting nuts, pins which can go into different holes, etc.
As a last resort you could google "poulan, mower, manual" which would take you to their website and you can download the manual for the mower. All my mowers, MTD, Husq, Simplicity, came with a manual and had explicit instructions for this process. Most all these mowers are made by Roper or AYP and you may find information by googling those companies.
Aug 25, 2010 | Poulan 42-Inch Steel Deck 17.5 HP Briggs &...
Starter
Take the part with the info you have to a Briggs authorized parts place ... they can help you .
Jun 01, 2010 | Poulan 42-Inch Steel Deck 17.5 HP Briggs &...
Transmission on a 18.5 poulan pro is not engaging properly any ideas? or anyone know where to find a poulan service center near olean ny?
Look up mtd's site as the are the mfg of this. Should be able to download full manual and locate service center. Otherwise if this has alot of hours, may need fluid change or linkage adjust.
Jan 15, 2010 | Poulan 42-Inch Steel Deck 17.5 HP Briggs &...
Garden Logo
63 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
