Lexmark ms310dn won't print to the feed tray
New machine will not print to the feed tray for avery lables etc
SOURCE: Lexmark E232 - Tray-1 Paper Problem
Have the same problem after 1,500 pages! This was Lexmark's solution (and it worked)...
Take the paperfeed tray out and you will see a red lever , press it
downwards and you will see the paperfeed rollers coming down , you need to
pull the rubber tyres off those rollers and place them inside out over
them and then try printing any document. Check the paper weight and
the paper type you need to use 20 pounds regular paper and try runnning a
can of compressed air inside the machine.
If rubber tyres on the paper feed rollers are totally worned out you
need to replace the feed rollers.
Posted on Nov 21, 2007
  • 54 Answers
SOURCE: paper feed problem
Check all this-----
1.check the printer paper feed roller jam.
2.check the paper sensor, It is working or not.
3.check the paper tray(clean it)
4.service the printer, (If possible).
Goodluck
Posted on Mar 10, 2008
efs_perpends
  • 1996 Answers
SOURCE: With HP Photosmart D7260 Printer, I get
Perhaps you are loading too much paper into the tray. Please try to work through the steps in this troubleshooter and see if it has any effect. If not, please report back with the results and someone will be happy to assist you.
HP OOPaper
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread. If I've managed to answer your question or solve a problem, please take a moment to kindly rate this post....thanks!
Posted on Apr 02, 2009
  • 53 Answers
SOURCE: Feeding-problems
you need to calibrate. hold the feed button down intill it flashes 4 times in a row and the quickly let go. it will feed some labels to calibrate and should stop at the tear off. you also have to set label size in the driver to keep from losing calibration.
Posted on May 19, 2010
matandacosma
  • 66 Answers
SOURCE: The machine won't print. It won't feed paper, The
Your machine needs to be serviced.
replace the cartridge with the original one.
it can not print if one cartridge is missing or not original.
Posted on Jul 13, 2011
I have a BROTHER MFC-8480DN all in one printer which I just purchased. My avery lables do not work right as the first 2 rows are okay and then the text does not fit right on the following labels. I use it...
Lables are slick some time the feed rollers will slide on them. Try to find lables that are course with no shine on them . The rubber that the tires are made of is of poor quality. Just dont have the grip . Hope this helps
Aug 12, 2010 | Brother Office Equipment & Supplies
Paper goes through tray 1 the image prints landscape on portait
Try placing the business card sheet in the main paper bin instead of the manual feed or adjusting the print orientation from Portrait to Landscape or vice versa.
Sep 25, 2009 | Computers & Internet
Lexmark won't print on Avery labels
The printer is expecting the label stock to be loaded into the manual feed tray, not the regular paper tray. If it does not sense anything in the manual feed tray it will not continue. If you are loading the stock in the tray, it may need to be pushed further into the try to trigger the sensor.
Jul 05, 2009 | HP LaserJet 4650 Color Printer
Printing on business card stock
goto avery website and download designpro for free it has all the templates for avery stationary
Mar 18, 2009 | Lexmark X6570 InkJet Printer
Printing labels on bizhub C450
Hi nwillett,
Yes and no, sorry if that doesn't make much sense.
For years Minolta recommended Avery labels, but these days they recomment labels manufactured by Howard Smith Papers, their website is http://www.hspg.com/
The thing with labels is always to use the one your copier service company suggests. Otherwise they'll invalidate you contract and you'll be liable for callouts and repairs caused by using Avery labels.
However, Avery labels are good and I have experienced very few problems with them I pressume you using the lables in the correct orientation and also using the manual bypass to feed them.
Regards
Taminol
Mar 11, 2009 | Konica Minolta bizhub C450P Laser Printer
Printing Labels
The MPF is simply the "Manual Paper Feed".
Your printer is set by default that the MPF paper type is "plain paper". Since you are telling the printer that you are trying to print lables, the printer is simply telling you that you need to load the MPF with lables.
If you say "ok", the printer sould continue and print the lables.
If you only print lables, the you can change the default paper for the MPF tray to "lables", and then you will no longer be prompted to load the tray.
Sep 25, 2008 | Dell 5100cn Laser Printer
Printer Jam - when i put a sheet of Avery labels, printer jams
When you say TOP TRAY, do you mean a paper drawer, or the BYPASS TRAY? If the labels won't feed into the bypass but bond paper does, check to see if your labels are made for inkjet printers. Go to www.avery.com and contact Avery customer support to see what product they recommend for your MFC. Labels made for plain paper printers sometimes do not work for inkjets, and vice-a-versa.
Aug 29, 2008 | Brother MFC-5840CN All-In-One InkJet...
Just trying to print 2181 Avery Laser Labels - "Paper Size or type is incorrect"
I have had this same problem trying to print DVD lable sheets.
I spent hours trying to work it out, HP support said it was the software(hmmm)
The answer to the problem is, the printer senses the printed block colour band on the preprinted lable sheet. I am using Fellowes - Neato DVD tempate sheets which have a black, block of colour on the leading edge, I'm not sure about Avery.
I found the quick fix is, turn the sheet around end for end against the manufacturers instructions. The opposite end is plain and goes through OK. You may have to calibrate the software to compensate if the printing starts in a different position this end, my sheets are the same within about 1mm.
You could also cut the block colour off the sheet if the direction was critical, and make allowance for the starting position.
I find the printer is good apart from this problem.
I hope this helps, it worked for me.
Regards, Rob.
Feb 18, 2008 | HP Photosmart C7180 All-In-One InkJet...
254 people viewed this question
jasbo
jasbo
